E=mc^2 states mass and energy are interchangeable but ?
In summary, E=mc^2 states that mass and energy are interchangeable, which applies to both nuclear and chemical reactions. However, in chemical reactions, the change in mass is very small and therefore negligible. This means that Dalton's law, which states that mass of products is equal to mass of reactants, holds true for all practical purposes.
jagdishdash
e=mc^2 states mass and energy are interchangeable but ??
But daltons law of constabt mass is voilated as states that while a reaction the mass of product = mass of reactant
any explanations?
Chemistry news on Phys.org
I think you're mixing apples and oranges here. Einstein's E=mc^2 applies to nuclear reactions whereas Dalton's law applies specifically to chemical reactions.
In a chemical reaction, electrons are interchanged, bonds are made, others are broken and energy is either given off or absorbed but no nuclear reactions are happening.
ok thankyou so much jedishrfu
my past 3 year doubt is now cleared thankyou so much
any explanations?
An oxygen molecule is also stable, which is another way of saying that it takes energy E to pull two oxygen atoms apart. So you could think of the animation as representing a stable molecule. However, the binding energies of molecules are much less than those of nuclei, and so the masses involved are smaller. A typical chemical reaction might involve a nett energy of 30 kJ per mole, or 5 x 10-20 J per molecule. So the change in mass is 5 x 10-37 kg, which is only .0001% of the mass of an electron.
http://www.phys.unsw.edu.au/einsteinlight/jw/module5_binding.htm
In other words that change in mass is very small and hence negligible for molecules (not the same for nuclei-see link.).
There is no violation because since mass and energy are equivalent, Dalton's Law is truly saying that the total of mass and energy remain constant (since they are equivalent), which it does.
You are wrong. E=mc2 is not about nuclear reactions, it is about mass and energy equivalence. Yes, it is most easily observable in nuclear reactions, but it doesn't mean it doesn't hold for other systems.
In chemical reactions - strictly speaking - mass of products is NOT equal to mass of reactants when we take mass energy equivalence into consideration. However, the difference is many orders of magnitude lower than the accuracy with which we can weight substances involved, so for all practical purposes Dalton's law holds.
1. What does E=mc^2 mean?
E=mc^2 is a famous equation proposed by Albert Einstein that states the equivalency between mass and energy. It means that mass and energy are different forms of the same thing and can be converted into one another.
2. How did Einstein come up with E=mc^2?
E=mc^2 was proposed by Einstein in his theory of special relativity, which was published in 1905. He derived the equation by combining the concepts of mass and energy from the work of other scientists, such as Max Planck and Henri Poincaré.
3. Can mass really be converted into energy?
Yes, the equation E=mc^2 has been proven through various experiments, such as nuclear reactions, which convert a small amount of mass into a large amount of energy. This concept is also used in nuclear power plants and atomic bombs.
4. Does E=mc^2 only apply to particles with mass?
No, E=mc^2 can also be applied to particles without mass, such as photons. In this case, the equation is modified to E=hf, where h is Planck's constant and f is the frequency of the photon.
5. How does E=mc^2 relate to the concept of mass-energy equivalence?
Mass-energy equivalence is the principle that mass and energy are interchangeable and are essentially different forms of the same thing. E=mc^2 is the mathematical representation of this principle, showing the relationship between the two quantities.
  • Other Physics Topics
