Register to reply
Buoyancy, neutral or not?
by georgejeff
Tags: buoyancy, neutral
Share this thread:
georgejeff
#1
Jan15-14, 10:09 AM
P: 2
I believe that I am making this a bit harder than it should be.
An object is weighted so that it "hoovers" 5 feet underwater. It is neutrally buoyant. A diver drags the object even deeper without adding weight, she releases the object at a deepth of 100ft. Will the object stay put, rise up, or sink?
What do you think?
Phys.Org News Partner Science news on Phys.org
New type of solar concentrator desn't block the view
Researchers demonstrate ultra low-field nuclear magnetic resonance using Earth's magnetic field
Asian inventions dominate energy storage systems
Chestermiller
#2
Jan15-14, 11:04 AM
Sci Advisor
HW Helper
Thanks
PF Gold
Chestermiller's Avatar
P: 5,174
Quote Quote by georgejeff View Post
What do you think?
The question is, "what do you think?" and why.
georgejeff
#3
Jan15-14, 11:30 AM
P: 2
I think that buoyancy is not related to depth, yes the pressure on the object will increase overall at greater depth. However, the differential pressure (upward force - downward force) will remain unaffected. The weight difference is insignificant from the law of universal gravitation, furthermore, if we are talking about depths of less than say 4km, the density of the water in not a factor.
What do I think? I think that if the object "hovers" at five feet and we take it to a depth of 100 feet, it will "hover" at that depth as well. Is my logic sound?
sophiecentaur
#4
Jan15-14, 03:40 PM
Sci Advisor
Thanks
PF Gold
sophiecentaur's Avatar
P: 12,123
What is one major effect of great pressure? What will change? How will that affect the buoyancy?
(Dammit - why can't they just tell me the answer!!!!!)
Microwire
#5
Jan15-14, 04:20 PM
P: 2
I don't know that much about bouancy and water density but I've always beleived that the object would float up to or around to the 5ft mark.
If you were to test this it would depend greatly on what the object is made from as the preassue would compress the air inside and create a more dense object.
sophiecentaur
#6
Jan15-14, 04:23 PM
Sci Advisor
Thanks
PF Gold
P: 12,123
Quote Quote by Microwire View Post
An passive object that is floating, neutral at 5ft is actually unstable. It will go right up or right down, after a small perturbation. Fish and submarines need to adjust their buoyancy constantly to stay at a given depth. (See Fish Swim Bladder)
Chestermiller
#7
Jan15-14, 06:27 PM
Sci Advisor
HW Helper
Thanks
PF Gold
P: 5,174
If water were incompressible and the object were incompressible, it would hover at 100 ft just like at 5 ft. Assuming that the object actually is incompressible, the water will compress slightly with depth. So, at depth, the weight of the water displaced by the object (a constant volume) will be greater. This would cause the object to float back up to the 5 ft depth, where it would hover again. To answer this question properly, however, you would have to know the change in volume of the object with pressure.
Microwire
#8
Jan15-14, 08:08 PM
P: 2
Quote Quote by sophiecentaur View Post
Submarines are what I was thinking about, they have their balast which is adjusted depending on what depth they want it's not just set and then taken to any depth.
rude man
#9
Jan16-14, 01:58 AM
HW Helper
Thanks
PF Gold
rude man's Avatar
P: 4,827
Basically the answer to your first question is that it will hover at 100 ft same as at 5 ft.
A submarine has to be able to dive and rise on command. It can do so by increasing or decreasing the ballast. But when it's done changing depth the amount of ballast is essentially the same at all depths.
It's an interesting transfer function: the system is basically an open-loop integrator with two inputs: a command depth, and a depth pressure sensor subtracting the command. The integrator (flow of ballast) stops when the two cancel each other and the desired depth is reached. The rate of submersion is controlled by the gain of the integrator (intake valve setting).
The dynamic system response can be improved by a PID controller (advanced subject!).
rude man
#10
Jan16-14, 02:00 AM
HW Helper
Thanks
PF Gold
rude man's Avatar
P: 4,827
Yes.
Register to reply
Related Discussions
Can we use earth as neutral? Electrical Engineering 6
Neutral Buoyancy of a fish Introductory Physics Homework 3
Balloon neutral buoyancy + an interesting idea Mechanical Engineering 1
Buoyancy and Density and Buoyancy General Physics 1
H2S + xxx -> Neutral Chemistry 10
