Hey ,if we need to calculate time dilation with an accelerating frame
In summary, according to this expert, time dilation always refers to specific pairs of observers in a specific spacetime, and acceleration invalidates the principle of equivalence.
anantchowdhary
372
Hey ,if we need to calculate time dilation with an accelerating frame of reference,cant we simply use the lorentz trasnformations and use instataneous velocity in place of relative velocity?
Alsousing einsteins derivation of the lorentz transformations we get 2ct=0
Now how do we explain this?
time dilation+acceleration
IMHO the time dilation can be derived without using the LT. It relates a proper time interval in one of the reference frames to a coordinate time interval measured in the moving reference frame. In the case when the moving clock performs an accelerated motion (usually the hyperbolic motion) we should take into account that during the reception of two successive light signals the velocity of the receiver and the angle under which he receives the light signals could change. The best way to solve the problem is to use a relativistic space time and to intersect the world line of the accelerating observer with the world lines of the light signals.
the best thing a physicist can offer to another one are information and constructive criticism.
Wouldn't that violate the principle of equivalence?
wich situation the first or the 2ct=0 one?
Citation for standard treatment of uniformly accelerated observers
Hi, anant,
Hey ,if we need to calculate time dilation with an accelerating frame of reference,cant we simply use the lorentz transformations and use instantaneous velocity in place of relative velocity?
This doesn't quite make sense as stated ("time dilation" always refers to some specific pair of observers in a specific spacetime, in this case Minkowski spacetime).
I feel that I must caution you to make sure you study mainstream sources before investigating more idiosyncratic approaches. For the simplest mainstream treatment of accelerated observers (known as the Rindler chart for Minkowski spacetime), see the classic textbook Misner, Thorne, and Wheeler, Gravitation, Freeman, 1973.
It is easy to write down a generalized Rindler chart which will handle an arbitrarily accelerating congruence of observers. If, after reading MTW, you need some help finding that, ask a followup question.
1. How does time dilation occur in an accelerating frame?
Time dilation occurs in an accelerating frame due to the effects of special relativity. When an object is accelerating, its velocity changes, causing a change in its mass and energy. This change in mass and energy results in a change in the perception of time for an observer in a different frame of reference.
2. What is the equation for calculating time dilation in an accelerating frame?
The equation for calculating time dilation in an accelerating frame is t' = t / sqrt(1 - v^2/c^2), where t is the time in the stationary frame, t' is the time in the accelerating frame, v is the velocity of the accelerating frame, and c is the speed of light.
3. How does time dilation in an accelerating frame differ from time dilation in a stationary frame?
Time dilation in an accelerating frame is different from time dilation in a stationary frame because in an accelerating frame, the velocity is constantly changing, causing a continuous change in the perception of time. In a stationary frame, the velocity remains constant, resulting in a constant time dilation factor.
4. Can time dilation in an accelerating frame be observed in everyday life?
Yes, time dilation in an accelerating frame can be observed in everyday life. For example, astronauts on a spaceship experience time dilation as they accelerate away from the Earth. This can also be observed in high-speed transportation, such as airplanes and trains.
5. How does the curvature of space-time affect time dilation in an accelerating frame?
The curvature of space-time can affect time dilation in an accelerating frame by altering the perception of time for an observer in a different frame of reference. This is due to the fact that the acceleration of an object can cause a curvature in space-time, which in turn affects the perception of time for an observer in a different frame of reference.
