Temperature of thermometer and temperature of material constituents
In summary, when measuring the temperature of a mixture of air, ice, and water using a thin-needle thermometer, it is not reasonable to assume that the temperature measured is the same as the temperatures of the individual components. The temperature measured will depend on what the thermometer is in contact with and it may take time for the components to reach thermal equilibrium.
nkinar
76
Hello--
Suppose that I insert a thin-needle thermometer into a porous material (such as snow) that consists of air, ice, and water. The thermometer is used to measure a temperature. Is it reasonable to assume that the temperature measured by the thermometer is the same as the temperatures of the air, ice, and water which are the constituents of the porous material?
Now suppose that I insert another needle into the snow at a distance d0 from the thin-needle thermometer. An electric current is passed through the metal needle, which functions as a resistor. The needle heats up, and transfers thermal energy to the snow. Note once again that the snow is a mixture of air, ice, and water.
Once again, I measure the temperature of this mixture using the thin-needle thermometer.
Is it still reasonable to assume that the temperature measured using the thermometer is also the temperature of the air, ice and water?
When I am writing this, I am thinking about the zeroth law of thermodynamics. Is my assumption reasonable, given this and other laws of thermodynamics?
Science news on Phys.org
aaaaa...might be, might be not...analysis of such non-homogeneous situations are pretty complex.
Usually air is warmer.
Definitely not.
It takes time for different constituents to gain a specific temperature...the rate of heat transfer, and ultimately rise in temperature is governed by Newton's laws of cooling and Fourier's law...also a function of specific heat capacity.
If situations are made static and given time, air, water, ice...or whatever materials are in contact will reach a common temperature, although the energy stored in terms of heat in each of the components might be different.
Thank you for your response, dE_logics! I think this makes things a little more clear.
If I set up an experiment, is there a way to measure the temperature of the constituents?
How would I know when the materials in contact have reached thermal equilibrium?
If I know the total temperature of the mixture and the specific heat of the constituents (air, ice, and water), then is it possible to be able to calculate the temperature of each constituent?
However, although it may not be physically reasonable to make the assumption that the temperature measured using the thermometer is also the temperature of the air, ice and water, isn't this the assumption that is being made when a measurement is made with the thin-needle thermometer?
Is it being assumed is that the air, ice and water are in thermal equilibrium with the thermometer?
Pretty difficult job, as said before analyzing such random heterogeneous mixture is pretty difficult.
By doing the thing that you want to do, as stated above.
Total temperature?...there's nothing like that.
Do you mean algebraic addition of the temperature of each component?
The temperature measured depends more on what the thermometer is buried into...for instance if it's buried in ice, it'll measure the temperature of ice.
If it's submerged in water, it will give you the temperature of water.
Depends highly on the situation. But given time and in an isolated system, they will reach a common temperature.
Okay, thanks dE_logics, this makes sense. Yes, when I say total temperature, I mean the algebraic addition of each component.
It is only when the system is in thermal equilibrium that all of the components (air, ice and water) will have the same temperature. This may take time, and it also depends on the situation.
1. What is the difference between temperature of a thermometer and temperature of material constituents?
The temperature of a thermometer refers to the reading or measurement displayed on the thermometer, while the temperature of material constituents refers to the actual temperature of the material being measured. The thermometer reading may be affected by factors such as calibration errors, environmental conditions, and the rate of energy transfer between the material and the thermometer.
2. Can the temperature of material constituents be higher or lower than the temperature of the thermometer reading?
Yes, the temperature of material constituents can be higher or lower than the temperature displayed on the thermometer. This can happen if there are calibration errors, fluctuations in the environment, or if the material is not in direct contact with the thermometer.
3. How do scientists ensure accurate temperature measurements?
Scientists use calibrated thermometers and follow standard measurement protocols to ensure accurate temperature measurements. They also take into account any environmental factors that may affect the thermometer reading, and make corrections accordingly.
4. Can different thermometers give different readings for the same material?
Yes, different thermometers can give slightly different readings for the same material. This can be due to variations in the quality and calibration of the thermometers, as well as external factors that may affect the thermometer readings.
5. How do changes in temperature affect material constituents?
Changes in temperature can affect material constituents in various ways. For example, an increase in temperature can cause the material to expand, while a decrease in temperature can cause it to contract. Changes in temperature can also affect the physical and chemical properties of the material, such as its color, density, and reactivity.
  • Thermodynamics
  • Thermodynamics
  • General Math
