Why is it called fluctuation conductivity in superconductors?
In summary, fluctuation conductivity in superconductors refers to the temporary decrease in electrical resistance near the critical temperature, caused by fluctuations in the superconducting order parameter. It is affected by temperature, magnetic field strength, and material properties, and can be measured using techniques such as four-point probe and AC susceptibility measurements. Fluctuation conductivity is significant in understanding the superconducting state and behavior of materials, and cannot be completely eliminated but can be reduced through optimization and application of strong magnetic fields.
AJS2011
Why is it called "fluctuation conductivity" in superconductors?
Hello,
In the work of Aslamazov-Larkin and many more, conductivity of a superconductor is calculated from the time dependent Ginzburg-Landau (TDGL) theory. They call it "fluctuation conductivity" bellow and above critical temperature. Then, this fluctuation conductivity must be added to the conductivity that comes from BCS theory known as Mattis-Bardeen complex conductivity to give the full conductivity.
Now my question:
Why is not that "fluctuation conductivity" the full conductivity?
Should not TDGL be able to give the full conductivity? Of course, considering the limitation of TDGL as an approximation. It seems that TDGL just gives the correction. Why?
Thank you!
Thank you for your question regarding the use of the term "fluctuation conductivity" in superconductors. The reason for this terminology lies in the underlying physics of superconductors and the theoretical framework used to study them.
Superconductivity is a phenomenon where certain materials can conduct electricity with zero resistance when cooled below a critical temperature. This behavior is described by the BCS theory, which explains that electrons in a superconductor form pairs and move together without any loss of energy. However, this theory does not fully account for the behavior of superconductors near the critical temperature, where fluctuations in the order parameter (a measure of the superconducting state) become significant. These fluctuations can cause temporary disruptions in the superconducting state, leading to a non-zero resistance.
To account for these fluctuations, the TDGL theory is used, which takes into account the time-dependent behavior of the superconducting order parameter. This theory predicts a "fluctuation conductivity" that contributes to the overall conductivity of the superconductor. This fluctuation conductivity is only a correction to the conductivity predicted by the BCS theory, and therefore cannot fully account for the behavior of the superconductor. Hence, the term "fluctuation conductivity" is used to differentiate it from the complete conductivity predicted by the BCS theory.
In summary, the TDGL theory gives a more complete picture of the behavior of superconductors near the critical temperature, but it is still an approximation and cannot fully explain all the properties of superconductors. Therefore, the term "fluctuation conductivity" is used to describe the contribution of these fluctuations to the overall conductivity, while the BCS theory gives the complete conductivity. I hope this helps to clarify the terminology used in this field of study.
1. Why is it called "fluctuation conductivity" in superconductors?
Fluctuation conductivity refers to the phenomenon where superconductors exhibit a temporary decrease in their electrical resistance at temperatures near the critical temperature. This decrease is caused by fluctuations in the superconducting order parameter, which is a measure of the strength of superconductivity in a material. This is why it is called "fluctuation conductivity" in superconductors.
2. What are the factors that affect fluctuation conductivity in superconductors?
Fluctuation conductivity in superconductors is affected by various factors, including temperature, magnetic field strength, and material properties. As the temperature approaches the critical temperature, the amplitude of the fluctuations increases, resulting in a decrease in resistance. The strength of the magnetic field also affects the magnitude of the fluctuations, with stronger fields suppressing the superconductivity and reducing the fluctuation conductivity. Additionally, the properties of the material can also influence the fluctuation conductivity.
3. How is fluctuation conductivity measured in superconductors?
Fluctuation conductivity in superconductors can be measured using various techniques, including four-point probe measurements and AC susceptibility measurements. Four-point probe measurements involve passing a small current through a sample and measuring the voltage drop, which can then be used to calculate the resistance. AC susceptibility measurements involve applying an alternating magnetic field to the sample and measuring the change in the sample's magnetization, which is related to the fluctuation conductivity.
4. What is the significance of fluctuation conductivity in superconductors?
Fluctuation conductivity is an important phenomenon in superconductors as it provides insights into the superconducting state and its properties. It is also crucial in understanding the behavior of superconductors near their critical temperature, which is important for practical applications. Additionally, the study of fluctuation conductivity can also lead to the discovery of new superconducting materials with improved properties.
5. Can fluctuation conductivity be completely eliminated in superconductors?
No, fluctuation conductivity cannot be completely eliminated in superconductors. This is because it is an intrinsic property of superconducting materials and is closely related to their critical temperature. However, by optimizing the material properties and applying strong magnetic fields, the magnitude of the fluctuations can be reduced, leading to a more ideal superconducting behavior.
  • Thermodynamics
  • Atomic and Condensed Matter
12K
  • Quantum Interpretations and Foundations
  • Art, Music, History, and Linguistics
