Derivations for a Bending Moment and Angle from Koenig's Apparatus
In summary: Your Name] In summary, the conversation discusses the difficulty in deriving equations for bending moment and angle of deviation using Koenig's apparatus. The bending moment is calculated by multiplying the Young's modulus of the material and the geometrical moment of inertia of the beam's cross section, and dividing it by the radius of curvature of the neutral surface. The angle of deviation is calculated by dividing the change in height by twice the distance between the knife edges and twice the distance between the farthest knife edge and the scales. To derive these equations, one would need to use principles of mechanics, equations of equilibrium, and basic trigonometry and calculus. Seeking online resources, textbooks, and help from tutors or classmates can aid in understanding and deriving
nevermaybe
I'm having ALOT of trouble figuring out how to derive these equations. I'll post up photos and the equations as follows.
C is the Bending Moment
Y is the Young's Modulus of the material
r is the Radius of Curvature of the neutral surface
I is the geometrical moment of Inertia of the cross section of the beam
Theta is the angle of deflection of the beam
h is the change in height on the scales as the beam deviates
d is the distance between 2 knife edges (points holding up the beam) of the beam
D is the farthest knife edge to the scales
PICTURES:
For the Bending Moment:
http://puu.sh/2mmq5
(That thing on the right (next to P) is a C - for bending moment, I accidently cut it out)
For Koenig's Apparatus:
http://puu.sh/2mmp2
For the Bending Moment the equation we need to derive is
C = (Y.I)/r
and for the angle of deviation, we need to derive
Theta = h/(2(d + 2D))
For the bending moment, I did some research online and found this link ( http://www.codecogs.com/reference/engineering/materials/bending_stress/bending_stress.php) , but I couldn't make much sense of it. The tutors in the lab were pretty unhelpful or atleast, didn't want to help much in case they straight up gave me the answer? Not entirely sure.
Similarly for the koenig's apparatus one, except I couldn't find anything on it online.
Thank you for your question. It seems like you are having difficulty deriving equations for bending moment and angle of deviation using Koenig's apparatus. I would be happy to assist you in understanding these concepts and deriving the equations.
Firstly, let's start with the basics. Bending moment, denoted by C, is a measure of the bending stress or force applied to a beam. It is calculated by multiplying the Young's modulus of the material (Y) by the geometrical moment of inertia of the beam's cross section (I) and dividing it by the radius of curvature of the neutral surface (r). This can be represented mathematically as C = (Y*I)/r.
Now, let's move on to Koenig's apparatus. This is a device used to measure the angle of deviation (Theta) of a beam when a load is applied to it. The angle of deviation is the change in height (h) on the scales as the beam deviates. It is calculated by dividing the change in height by twice the distance between the knife edges (d) and twice the distance between the farthest knife edge and the scales (D). This can be represented mathematically as Theta = h/(2(d + 2D)).
To derive these equations, you will need to use the principles of mechanics, specifically the equations of equilibrium and the relationship between bending moment and deflection. You may also need to use some basic trigonometry and calculus to solve the equations.
I recommend looking for online resources or textbooks that explain these concepts in detail and provide step-by-step derivations. You can also seek help from your lab tutors or classmates who may have a better understanding of these concepts.
I hope this helps you in your understanding and derivation of the equations. Good luck with your studies!
1. What is Koenig's Apparatus?
Koenig's Apparatus is a scientific instrument used to measure and calculate the bending moment and angle of a beam under different loads.
2. What is the purpose of deriving the bending moment and angle from Koenig's Apparatus?
The derived values of bending moment and angle are important for understanding the structural integrity and strength of a beam, which is crucial in engineering and construction applications.
3. How does Koenig's Apparatus work?
Koenig's Apparatus works by applying a known load on a beam and measuring the resulting deflection of the beam. This deflection is then used to calculate the bending moment and angle using mathematical equations.
4. What are the factors that affect the accuracy of the derived values from Koenig's Apparatus?
The accuracy of the derived values can be affected by various factors such as the precision of the instrument, environmental conditions, and human error in measurements.
5. Can the derived values from Koenig's Apparatus be used in real-world applications?
Yes, the derived values can be used in real-world applications such as designing and analyzing structures, determining the maximum load a beam can withstand, and identifying potential structural weaknesses.
22K
  • Mechanical Engineering
21K
