Is rainbow a prismatic spectrum or grating spectrum ?
In summary, a prismatic spectrum is a spectrum of colors produced by a prism, while a grating spectrum is produced by a diffraction grating. The main difference between the two is the way they disperse light. A rainbow is a prismatic spectrum caused by sunlight being refracted by water droplets, but a grating can also be used to create a similar effect.
mkbh_10
222
I think it is a grating spectrum as
Deviation Order(violet least and red most) is same as that of grating
Source is at infinity (sun)
Image is at infinity
A rainbow is not a grating spectrum.
It is caused by refraction as the light passes in and then back out of each drop of water.
1. What is a prismatic spectrum?
A prismatic spectrum is a spectrum of colors produced by passing white light through a prism. This results in a continuous band of colors, with red on one end and violet on the other.
2. What is a grating spectrum?
A grating spectrum is a spectrum of colors produced by passing light through a diffraction grating, which is a surface with closely spaced parallel lines. This results in a pattern of bright and dark lines, with the colors dispersed at specific angles.
3. What is the difference between a prismatic and grating spectrum?
The main difference between a prismatic and grating spectrum is the way in which they disperse light. A prism disperses light based on the different wavelengths of light, while a grating disperses light based on diffraction. This results in a continuous spectrum for a prism and a line spectrum for a grating.
4. Is a rainbow a prismatic or grating spectrum?
A rainbow is a prismatic spectrum. It is formed when sunlight is refracted, or bent, by water droplets in the atmosphere. This results in the separation of white light into its component colors, similar to a prism.
5. Can a grating be used to create a rainbow?
Yes, a grating can be used to create a rainbow. When white light is passed through a diffraction grating, it produces a spectrum of colors similar to a rainbow, but with distinct, separated lines instead of a continuous band of colors.
  • Other Physics Topics
  • Atomic and Condensed Matter
