Deriving parametric equations of a point for the involute of a circle
In summary: So if one extends the tangent line segment at angle t to the end of the string, if one measures the arc length of the extended line segment, how does that relate to the end of the string?In summary, the given problem involves finding the parametric equations for the point P(x,y) on the involute of a fixed circle (x^2)+(y^2)=1. The unwound portion of the string is tangent to the circle at Q, and t is the radian measure of the angle from the positive x-axis to segment OQ. The coordinates of the end of the string can be expressed as (x,y) = (cos(t) + t sin(t), sin(t) - t cos(t)).
JoeSabs
If a string wound around a fixed circle is unwound while held taut in the plane of the circle, its end P traces an involute of the circle. In the accompanying figure, the circle in question is the circle (x^2)+(y^2)=1 and the tracing point starts at (1,0). The unwound portion of the string is tangent to the circle at Q, and t is the radian measure of the angle from the positive x-axis to segment OQ. Derive the parametric equations
x=cost+tsint, y=sint-tcost, t>0
of the point P(x,y) for the involute.
I have no idea how to do this problem! The section it's in is "Arc length and the unit-Tangent vector," but the only things explained in the section are arc length and unit tangent vector! I don't see how this relates... If anyone can provide a detailed explanation, I'd be grateful.
The OP is dated Sep 30, 2008
It would help to have an image.
https://mathshistory.st-andrews.ac.uk/Curves/Involute/
If one were to draw a line with one end on the circle, at some angle t, and the other at some length perpendicular to the radius at the tangent point, then one should understand what is being ask with respect to the locus of the end of the unwrapped/unwound string. One is looking for the coordinates (x,y) of the end of the string. As t increases, the length of the string increases by the angle (t) times the radius (1 for a unit circle). And one can then write (x,y) = (x(t), y(t)), where x = cos(t) + t sin(t), y = sin(t) - t cos(t).
The length of an arc is just the product of the angle subtended by the arc and the radius. The circumference of a circle is 2πr, for a semicircle, the length of the arc is 1/2 of a full circle, or πr, and so on.
1. What is the involute of a circle?
The involute of a circle is a mathematical curve that is created by unwrapping a taut string from the circumference of a circle. It is closely related to the concept of a tangent line and has various applications in engineering and geometry.
2. How do you derive parametric equations for the involute of a circle?
The parametric equations for the involute of a circle can be derived by using the properties of a circle and the concept of a tangent line. By considering the length of the string as it unwraps from the circle, a set of equations can be obtained that describe the x and y coordinates of the point on the involute curve at a given angle.
3. What are the applications of the involute of a circle?
The involute of a circle has various applications in engineering, such as in the design of gears and pulleys. It is also used in the production of certain types of curves in art and design, as well as in the study of geometry and mathematics.
4. Can the parametric equations of the involute of a circle be simplified?
Yes, the parametric equations for the involute of a circle can be simplified by using trigonometric identities and simplifying the expressions. However, the resulting equations may not be as intuitive or easy to understand as the original equations derived from the properties of the curve.
5. Are there any other methods for deriving the parametric equations of the involute of a circle?
Yes, there are multiple methods for deriving the parametric equations of the involute of a circle. One method involves using polar coordinates and converting them to Cartesian coordinates. Another method uses the concept of curvature and the parametric equations for a curve's curvature to derive the equations for the involute of a circle.
