Help with Laplace Transformations and 2nd order ODEs
In summary: TFMindeed it is close.I think the only thing you did wrong is that you took over the +3 instead of the -3so,sY-Y=2/(s-1)-3then factorise Y and do the rest to get Y(s) In summary, Laplace Transformation can be used to solve ODEs by first converting the function into its Laplace transform and then using the Laplace transform formulas to find an expression for the transformed function in terms of s. This can then be inverted to find the original function.
  • #106
Okay so:
[tex] Y = \frac{\frac{1}{s^2 + 1} + s - 1/2}{s^2 + 1} [/tex]
[tex] Y = \frac{1}{(s^2 + 1)^2} + \frac{s}{s^2 + 1} - \frac{1}{2s^2 + 2} [/tex]
So, the Laplace tranformation of:
[tex] \frac{1}{(s^2 + 1)^2} = = \frac{1}{2} (-sin(t)- tcos(t)) [/tex]
and the Laplace transformation of:
[tex] \frac{s}{s^2+1} = cos(t) [/tex]
And finally, the Laplace Transformation of:
[tex] \frac{1}{2s^2 + 2} [/tex]
would this be similar to the first one, but require first shift theorem:
[tex] \frac{1}{(2s^2 + 2)^2} = = \left(\frac{1}{2} (-sin(t)- tcos(t))\right) e^2t [/tex]
Is this okay?
TFM
  • #107
The first two bits are perfectly fine.
what is the inverse laplace transform of 1/(s^2 +1)
It is ofcourse sin(t)
so that means the inverse laplace of 1/2(s^2+1) is just simply (1/2)sin(t)
so now you have the inverse laplace of each bit, now you can state what the function y(t) is.
  • #108
Okay, so now:
[tex] y(t) = cos(t) + \frac{1}{2}(-sin(t) - t cos(t)) + \frac{1}{2}sin(t) [/tex]
Is this okay?
TFM
  • #109
that's right
  • #110
Excellent. Thanks for all your assistance, sara_87
