Optics: finding the width of an image produced through a lens
In summary: Your name]In summary, the equation for magnification (m = hi/ho = -di/do) can be applied to both the height and width of an object and its resulting image when using a convex or concave lens. The resulting image will have a negative value for both height and width, indicating that it is inverted due to the refraction of light through the lens.
randomperson
This is more of a general conceptual question.
When finding the image produced through a convex or concave lens, I know that you can use the equation magnification = (height of image/height of object) to find the magnification of the image produced. But does this proportion extend to the width of the object and image as well?
For example, if I had an object that was 5 inches tall and 6 inches wide, and the magnification was -2, what would be the dimensions of the image produced?
mag = hi/ho = -di/do
I know that the height of the image would be is -10 inches. Would the width of the image simply be -12 inches?
Also if that is how you find it, would width be given as a positive value or negative value? The height would be negative by convention because the image is flipped, but is width is negative as well? (I’m thinking yes, because when an image is inverted, you see an upside down and backwards image, so the left side of the object shows up on the right side of the image, etc.)
Thank you for your question. The equation for magnification, as you have correctly stated, is m = hi/ho = -di/do. This equation can be applied to both the height and width of the object and image. In your example, if the object is 5 inches tall and 6 inches wide, and the magnification is -2, then the resulting image will be -10 inches tall and -12 inches wide.
The negative values for height and width indicate that the image is inverted, as you mentioned. This is because the light rays are refracted at different angles as they pass through the lens, causing the image to be flipped. Therefore, the width will also be negative, as the left side of the object will appear on the right side of the image.
I hope this answers your question. If you have any further inquiries, please don't hesitate to ask. As scientists, we are always happy to help clarify any conceptual or mathematical questions. Keep up the great work!
1. How do you calculate the width of an image produced through a lens?
To calculate the width of an image produced through a lens, you can use the formula: image width = object width * (image distance / object distance). This formula is known as the magnification formula.
2. What is the magnification of an object through a lens?
The magnification of an object through a lens is the ratio of the image size to the object size. It is calculated using the formula: magnification = image distance / object distance. A magnification of 1 means that the image is the same size as the object, a magnification greater than 1 means the image is larger, and a magnification less than 1 means the image is smaller.
3. How does the focal length of a lens affect the width of the image?
The focal length of a lens is directly related to the width of the image produced. A longer focal length will result in a smaller image width, while a shorter focal length will result in a larger image width. This is because a longer focal length causes the light rays to converge more, resulting in a smaller image.
4. Can the width of an image through a lens be negative?
No, the width of an image produced through a lens cannot be negative. The width of an image is a physical measurement and cannot have a negative value. If the calculated width is negative, it means that the image is inverted or flipped.
5. How does the position of the object affect the width of the image through a lens?
The position of the object does not affect the width of the image through a lens. The width of the image is solely determined by the magnification formula and the focal length of the lens. However, the position of the object does affect the size and orientation of the image. A closer object will result in a larger image, while a farther object will result in a smaller image. Additionally, the orientation of the object (upright or inverted) will also affect the orientation of the image.
