Statistics, multiple choice, regression equation - 2nd question
In Summary, the regression equation was developed to predict gas mileage (mpg) for various car weights. The resultant equation was: Y = 35.2 - .0034 X. The explanatory variable is the weight and the response variable is the mileage. Heavier cars get lower mileage.
Calculator14
30
Statistics, multiple choice, regression equation -- 2nd question
A regression equation was developed to predict gasoline mileage (mpg) for various car weights (pounds). The resultant equation was: Y = 35.2 - .0034 X. Which two answers can be concluded?
A. The explanatory variable is the mileage and the response variable is the weight.
B. The explanatory variable is the weight and the response variable is the mileage.
C. Heavier cars get lower mileage.
D. Heavier cars get higher mileage.
y=mx+b
My answer is A and D, For they make the most sense to me, yet I am not sure:/
Hi Calculator14! Welcome to PF! :smile:
Do you have the definitions handy for the "explanatory variable" and the "response variable"?
Those should tell you which is which...
In your expression X would be the weight.
Suppose you fill in 2 values, say 1000 kg and 2000 kg, which result (mileage) would be the highest?
(Note that this problem is not about what is intuitively likely, but about what the formula says.)
Also since this is a statistics question, the very small slope, so close to zero, might give one pause concluding either C or D. You might take that into consideration if you are supposed to choose the "best" answer.
@LCKurtz: Good point! That slope is really small! :smile:
In my opinion that makes this question a bad question. :yuck:
Because without information how accurate the slope is, I think we still need to choose either C or D.
It's a trick question! :wink:
This is a simple problem. The regression equation was developed to predict (key word) gas mileage (the number of miles traveled on a gallon of gas) for a given car knowing its weight. It's reasonable to conclude that 'gas mileage', being what is predicted, is the 'response'. Therefore, one also concludes that the 'weight' of the car is the 'explanatory' variable, since different mileage predictions, according to this equation, are a function solely of different car weights.
Based on these factors, would you like to change your answer?
By looking at the slope of the curve, which in this case is negative, one concludes that a heavier car will have lower gas mileage. (Quick: what has higher gas mileage? A Toyota or a Tank?)
Guy's this is a very easy question and the two correct answers are very obvious.
The slope is not small when you consider that "x" is in pounds and that a typical car weighs around 3000+ pounds! If you were to take the weight of the car in tons then the slope would be about 7.6. For any linear equation you can make the slope as large or as small as you like, merely by choice of units. You cannot conclude the slope is small without considering the units involved.
Yes, I agree that the two correct answers are obvious. Truth is, I didn't notice at first that it wanted two answers so I was looking for a way to argue the second answer clearly not as sure thing as the first "best" answer about which there is (or should be) no doubt.
1. What is the purpose of statistics?
Statistics is a branch of mathematics that involves collecting, organizing, analyzing, and interpreting data. Its purpose is to help us make sense of the large amounts of data that we encounter in everyday life and to make informed decisions based on that data.
2. How is multiple choice used in statistics?
Multiple choice questions are commonly used in statistics to assess knowledge and understanding of statistical concepts and techniques. They can also be used to test hypotheses and evaluate the effectiveness of interventions or treatments.
3. What is a regression equation?
A regression equation is a mathematical model that describes the relationship between two or more variables. It is used to predict the value of one variable based on the values of the other variables.
4. How is a regression equation calculated?
A regression equation is calculated using statistical methods such as linear regression. This involves finding the best-fitting line that describes the relationship between the variables, based on the data.
5. What does the correlation coefficient represent in a regression equation?
The correlation coefficient, also known as r, represents the strength and direction of the relationship between the variables in a regression equation. It ranges from -1 to 1, with a value of 0 indicating no relationship, a value of 1 indicating a perfect positive relationship, and a value of -1 indicating a perfect negative relationship.
  • Set Theory, Logic, Probability, Statistics
