Simple problem in Mechanics, weird differential equation
In summary, The conversation discusses a problem involving a particle of mass m moving along a straight line and being acted upon by a retarding force. The differential equation that results from this is solved to get a function of v(t), which is a non-linear differential equation. The process of separating variables and integrating is explained, and the final solution should be in terms of a logarithm of t. It is also noted that due to the retarding force, the differential equation should be adjusted accordingly.
dujardin
There is a problem I couldn't figure out , it says :
it says that a particle of mass m moves along a straight line and is acted on by a retarding force (one always directed against the motion) F=b*exp(a*v(t)),
b, a are constants and v is the velocity.
At t=0 it is moving with velocity V
and I am aked to solve the differential equation that results from this to get a function of v(t).
I found that the differential equation that has to be solved is :
dv/dt = (b/m)*exp[a*v]
so this is like solving a non-linear differential equation of the form y'=exp(y)
How do you do that??
You have simply to re-write the equation in terms of differentials and you will be able to integrate:
[tex] \frac{du}{dt} = f(u)[/tex]
becomes:
[tex] du = f(u) dt[/tex]
and then
[tex] \frac{du}{f(u)} = dt[/tex]
you can then integrate:
[tex] \int \frac{du}{f(u)} = t + C[/tex]
which gives you [tex]u(t)[/tex] implicitly.
In your case you should get [tex]v(t)[/tex] in terms of a logarithm of t.
becomes:
and then
I understood everything. Thank you so much
Just a note! :smile:
Since you have a retarding force, the ODE should be
[tex]\frac{d\,v}{d\,t}=-\frac{b}{m}\,e^{a\,v}[/tex]
1. What is a simple problem in Mechanics?
A simple problem in Mechanics is a problem that can be solved using basic concepts and principles of mechanics, such as Newton's laws of motion or the principles of work and energy. These problems usually involve objects moving in a straight line or in a simple geometric shape, and can be solved using basic algebra or calculus.
2. What is a weird differential equation?
A weird differential equation is a type of mathematical equation that describes the relationship between a function and its derivatives. These equations often have unusual or unexpected solutions, making them difficult to solve. They can also describe complex systems or phenomena, such as chaotic behavior or non-linear dynamics.
3. How do you solve a simple problem in Mechanics?
To solve a simple problem in Mechanics, you first need to identify the relevant principles and equations that apply to the situation. Then, you can use these equations to set up and solve a system of equations, using algebra or calculus as needed. Finally, you can interpret the solution in the context of the problem to determine the answer.
4. What makes a differential equation "weird"?
A differential equation can be considered "weird" if it has unusual or unexpected solutions, if it describes a complex system or phenomenon, or if it is difficult to solve using traditional methods. These equations can often be challenging and require advanced mathematical techniques to solve.
5. How can I improve my problem-solving skills in Mechanics and differential equations?
To improve your problem-solving skills in Mechanics and differential equations, it is important to practice regularly and familiarize yourself with different types of problems and equations. Additionally, seek out resources such as textbooks, online tutorials, and practice problems to gain a deeper understanding of the concepts and techniques involved. It can also be helpful to work with a tutor or study group to discuss and solve problems together.
