A single pentacene molecule observed through an atomic force microscope
The IBM Research Zurich team made a breakthrough with their atomic force microscope (AFM), using a single molecule of carbon monoxide to create high resolution images of the pentacene molecule. This has huge implications for the field of nanotechnology, as the AFM can measure tiny forces with great precision and provide images of the smallest objects known to mankind. In summary, the team's discovery has paved the way for people to potentially use their iPhones to manipulate and study molecules on a nanoscale.
fourier jr
765
awesome! i guess it won't be long now before people will be able to do this with their iPhones:
The team from IBM Research Zurich said the results could have a huge impact of the field of nanotechnology, which seeks to understand and control some of the smallest objects known to mankind.
The AFM uses a sharp metal tip that acts like a tuning fork to measure the tiny forces between the tip and the molecule. This requires great precision as the tip moves within a nanometer of the sample.
'Above the skeleton of the molecular backbone (of the pentacene) you get a different detuning than above the surface the molecule is lying on,' Mr Gross said.
This detuning is then measured and converted into an image.
To stop the tip from absorbing the pentacene molecule, the researchers replaced the metal with a single molecule of carbon monoxide. This was found to be more stable and created weaker electrostatic attractions with the pentacene, creating a higher resolution image.
http://www.dailymail.co.uk/sciencet...n-times-smaller-grain-sand-pictured-time.html
That's so :cool:!
I am amazed by the advancements in technology that have allowed us to observe a single pentacene molecule through an atomic force microscope. This breakthrough has the potential to greatly impact the field of nanotechnology, allowing us to better understand and manipulate some of the smallest objects in existence.
The use of a sharp metal tip acting as a tuning fork to measure forces between the tip and the molecule is an impressive feat of precision. And the substitution of a single molecule of carbon monoxide for the metal tip, resulting in a higher resolution image, is a creative and innovative solution.
This type of research opens up new possibilities for studying and manipulating molecules on a nanoscale level, which could have huge implications for various industries such as medicine, electronics, and materials science. I look forward to seeing how this technology continues to advance and what new discoveries it will bring.
What is a pentacene molecule?
A pentacene molecule is a type of organic compound that is made up of five linearly fused benzene rings. It is commonly used in organic electronics due to its unique properties.
What is an atomic force microscope?
An atomic force microscope (AFM) is a type of high-resolution microscopy that uses a tiny probe to scan the surface of a sample. It can provide images with atomic-scale resolution and can also measure forces between the probe and the sample.
How is a single pentacene molecule observed through an atomic force microscope?
In order to observe a single pentacene molecule using an atomic force microscope, the molecule is first deposited onto a flat surface. The AFM probe then scans the surface, detecting the topography and structure of the molecule.
What can the observation of a single pentacene molecule through an atomic force microscope tell us?
The observation of a single pentacene molecule through an atomic force microscope can provide information about the molecular structure, arrangement, and properties of the molecule. It can also help in understanding the interactions between the molecule and its surroundings.
What are the potential applications of studying single pentacene molecules through atomic force microscopy?
The study of single pentacene molecules through atomic force microscopy can have various applications, such as in the development and optimization of organic electronic devices, understanding surface chemistry and catalysis, and studying molecular self-assembly and interactions.
  • General Discussion
