Silicon solar cell degradation due to solar fluxes
In summary, to find the absorbed dose for Silicon cells on a geostationary satellite from 1996 to 2005, you can use the equation D(rad) = 1.68e-8 *((1/ρ)*dE/dx) * Phi, where D is the absorbed dose in 100 ergs/g or 0.01 J/Kg, (1/ρ)*dE/dx is in (MeV*cm^2)/g, and Phi is the incident fluence in particle * cm^-2. To convert the fluence from electrons/cm2-day-sr to particles/cm2, you need to multiply it by the number of particles in one electron (1.602 x 10
hamzaaaa
31
I am trying to find the Absorbed dose for Silicon cells on a geostationary satellite from a period of (1996 to 2005)
The Equation I have is:
Where: D is absorbed dose and units are (100 ergs/g or 0.01 J/Kg)
(1/ρ)*dE/dx = (MeV*cm^2)/g
Phi=incident fluence= particle * cm^-2
I have the following set of data as you can see in the attachments. And I want to calculate 'D' for Electron Fluence. In the text file the units of Fluence is given by Electrons/cm2-day-sr.
How to convert them to particle * cm^-2 ?
Is this the right approach by the way?
  • 1997_DPD.txt
Astronomy news on Phys.org
The answer to your question is yes, this is the right approach. To convert the fluence from electrons/cm2-day-sr to particles/cm2, you need to multiply it by the number of particles in one electron (1.602 x 10-19 Coulombs). This will give you the particle fluence in particles/cm2.
1. What is silicon solar cell degradation due to solar fluxes?
Silicon solar cell degradation is a process in which the performance of a solar cell deteriorates over time due to exposure to solar fluxes, which are the particles and radiation emitted by the sun.
2. What causes silicon solar cell degradation?
Silicon solar cell degradation is primarily caused by the exposure of the solar cell to UV radiation, heat, and moisture. These factors can cause physical and chemical changes in the solar cell, leading to a decrease in its efficiency.
3. How does solar flux affect the performance of silicon solar cells?
Solar fluxes, such as UV radiation and heat, can cause damage to the silicon material in solar cells, reducing its ability to convert sunlight into electricity. This can result in a decrease in the overall efficiency of the solar cell.
4. Can silicon solar cell degradation be prevented?
While it is not possible to completely prevent silicon solar cell degradation, it can be slowed down by proper maintenance and protection from excessive exposure to solar fluxes. This can include using protective coatings, keeping the solar cells clean, and using materials that are resistant to UV radiation.
5. How long does it take for silicon solar cells to degrade?
The rate of degradation for silicon solar cells can vary depending on the level of exposure to solar fluxes and the quality of the materials used. In general, it can take anywhere from 10-20 years for a solar cell to degrade significantly.
  • Materials and Chemical Engineering
  • Astronomy and Astrophysics
  • Nuclear Engineering
