New Reply
pumping water versus expulsion
Share Thread Thread Tools
Feb24-13, 01:42 PM   #1
Does it take the same amount of energy to lift water out of a tank as it would to force it out using compressed air? For example if there is a cylindrical tank that is 14 meters tall, 10 meters wide and it is filled with water to a depth of 5 meters I know that it takes 44.3e6 joules to lift that water out of the tank. (9800 n/m^3, 25pi, dy, 14-5... solved using integrals) Is there a formula for how much compressed air it would take to force the water out a vent on the bottom of the tank, assuming the tank is surrounded by water (but attached to the bottom so it wouldn't start floating as you pump in compressed air)?
My thought was it would take less energy to force water out because distance traveled would be less. So if say your tank is 1000 feet down and you wanted to pump the water up and out through a pipe or force it out through a vent, the compressed air way might take less energy. How much force of resistance are you meeting from the water outside the tank?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Feb24-13, 06:00 PM   #2
mfb
Mentor
If the water ends at the same height and if we neglect all inefficiencies, it needs the same amount of energy. This is just energy conservation. In a real setup, that pressurized air will give significant losses.
New Reply
Thread Tools
Similar Threads for: pumping water versus expulsion
Thread Forum Replies
use of capillarity in pumping water General Physics 3
Work done by pumping water into a tank Calculus & Beyond Homework 1
Pumping Water from a deep mine Introductory Physics Homework 14
Water pumping calculation Mechanical Engineering 2
water pumping in tall buildings ? General Engineering 4
