Proof of Closed Sets: Cluster Points & Int. Pts
In summary, a set is closed if and only if it contains all of its cluster points. The definition of a closed set is that its complement is open. For metric spaces, a set is closed if it contains all of its cluster points or if the limit of every convergent sequence in the set is in the set. In topological spaces, the definition of closed is that its complement is open. To prove that a set is closed, one can show that its complement is not open by showing that there is a cluster point of the set in its complement.
ckr21
1. Prove that a set is closed if and only if it contains all of its cluster points.
2. Can I use part of the Lemma here that states: Every interior point of A is a Cluster point.
Also what exactly is the definition of a closed set other than a set is closed if its compliment is open.
3. Just by using the definitions i feel like I should be able to prove this. It seems so simple yet I don't know where to start exactly. I just need some direction...and maybe better definitions.
For metric spaces, "E is closed" can be defined as "the limit of every convergent sequence in E is in E". I like this definition, because it ensures that "closed" means "closed under limits". Unfortunately this definition isn't equivalent to "Ec is open" when you're dealing with topological spaces that aren't metric spaces. I guess "Ec is open" has turned out to be a more useful definition, since it's the one that's used in all the books.
Suppose that there's a cluster point of E in Ec. Can Ec be open?
If there is one cluster point in Ec I think it could be open but not all cluster points. Ummm, but you said a cluster point in E also in Ec, how could it be in both.
I have a hard time understanding all of this to begin with sorry if my reasoning and questions do not make since.
The definition I have for cluster point is: Suppose A [tex]\subseteq[/tex] [tex]\Re[/tex] and x [tex]\in[/tex] [tex]\Re[/tex] then x is a cluster point of A if every neighborhood contains a point of A other than x.
So that's why i don't think a cluster point could be in E and Ec
No, I said a cluster point of E in Ec. I don't have time to answer more than that right now.
I don't understand than. Oh well thanks for trying
I don't understand. What is unclear about the sentence "Suppose that there's a cluster point of E in Ec."?
Edit: OK, I think I see the problem. You think the definition of "cluster point" means that a cluster point of a set is a member of that set. It doesn't. 0 is a cluster point of {1/n|n positive integer}, and every real number is a cluster point of the set of rational numbers.
How can it be of and not in...the wording to me just doesn't make sense, this whole subject does not make sense to me. its not logical to me.
Topology is pretty difficult. What makes it worse is that when you study functional analysis, you're expected to know these things perfectly.
This exercise wouldn't make sense if "of" implied "in", since every set would contain all of its cluster points.
ok how you explained cluster point to me helps a little bit. Yeah topology is very difficult and i don't think i like it...
Did you understand that "There's a cluster point of E in Ec " is the negation of "E contains all its cluster points"? If you can prove that this assumption implies "Ec is not open", you have proved that if Ec is open, E contains all its cluster points. (Recall that [itex]A\Rightarrow B[/itex] is equivalent to [itex]\lnot B\Rightarrow \lnot A[/itex]).
(I won't be near my computer for a few hours now).
Too bad the time limit for edits has been lowered, so that I can't remove the emphasis on the word "is", which makes no sense. My point was that the implication
E is closed [itex]\Rightarrow[/itex] E contains its cluster points,​
which is one of the two implications you're supposed to prove, is equivalent to
Ec is open [itex]\Rightarrow[/itex] E contains its cluster points,​
which is equivalent to
There's a cluster point of E in Ec [itex]\Rightarrow[/itex] Ec is not open.​
Have you proved this yet? Did you figure out how to do the other half of the problem?
Since everyone uses a slightly different definition of closed, can you post yours?
So if I prove that
then I proved one way of this proof since it is a iff
Have you proved this yet? Did you figure out how to do the other half of the problem?[/QUOTE]
No i still haven't I have to figure it out by tomorrow...I had to take a break and study for two more finals I had
@earlh the only definition I have is A is closed if A compliment is open
And what's your definition of an open set?
it's a theorem, not definition
It's a valid definition. It's a good one because it works in the context of topological spaces too. (In that context, it's the standard way to define "closed"). Other valid definitions of "E is closed", in the context of metric spaces, include "E contains all of its cluster points" and "for every x in E there's a sequence in E with limit x".
Cluster points are often called limit points or accumulation points instead.
ckr21 said:
So if I prove that
Right. And I recommend that you do that by proving
We can talk about how to prove the converse after you've done this.
[tex]A[/tex] is closed if [tex]A^{C}[/tex] is open is a perfectly reasonable definition, at least in topology, where the definition of open is the elements of the topology set. It's the standard definition, and it's used by Munkres which is the only text I have here.
1. What is a closed set?
A closed set is a subset of a metric space in which all of its limit points are contained within the set.
2. What does it mean to have a cluster point?
A cluster point, also known as a limit point, is a point in a set that can be approached by an infinite number of other points in the set. In other words, it is a point where a sequence of points in the set converges.
3. How do you prove that a set is closed?
To prove that a set is closed, you can show that it contains all of its limit points. This can be done by showing that for any sequence of points in the set that converges, the limit point of the sequence is also in the set.
4. What are interior points?
Interior points are points in a set that have a neighborhood entirely contained within the set. In other words, they are points that are not on the boundary of the set.
5. How are interior points and cluster points related in a closed set?
In a closed set, all cluster points are also interior points. This is because in a closed set, all of its limit points are contained within the set, and interior points are points with a neighborhood contained within the set. Therefore, all cluster points, which can be approached by an infinite number of points in the set, must also have a neighborhood contained within the set.
