- #71
Andrew Mason
- 7,776
- 474
Yes, provided no work is done on the environment ie. there is only heat flow to/from the environment, it does not matter how the heat originates in the system when determining the entropy change of the surroundings.atyy said:Yes, I think that was the OP's question - why can one use dQ/T to calculate entropy change even though this process is irreversible? Would you agree that the basic idea is that in a quasi-static process in which the irreversibility is due to dissipative work, the surroundings that accept the heat from the dissipative work cannot distinguish whether the heat is due to "reversible heating" or to "irreversible work",
I am not sure what you are saying here. If there is only heatflow into/out of the surroundings (the system does no work on the surroundings) AND if the surroundings have sufficiently high heat capacity so that there is no change in temperature of the surroundings, then [itex]\Delta S_{surr}= \Delta Q_{actual}/T[/itex]. It does not matter whether the actual process is quasi-static or not.so dQ/T can still be used in the exceptional case of a quasi-static irreversible process (ie. this trick should not work for a non-quasi-static irreversible process, in which case one has to know the initial and final states of the environment to find a corresponding reversible process)?
AM
