Is a uniform gravitational field a gravitational field?
In summary: The length a,b, etc. are all constants.In summary, the term "gravitational field" is rather ambiguous, and when one wants to be precise, one is advised to avoid this term in favor of something better defined.
  • #106
pervect said:
Plugging this into Maple, I get
[tex]
-{\frac {m \left( 2\,r-3\,m \right) }{{r}^{3} \left( r-2\,m \right) }}
[/tex]
assuming I haven't messed anything up. This blows up at r=2m.
This looks right.
Of course, we still haven't really settled whether or not calculating the rate of change of proper acceleration with respect to distance is the correct definition of tidal force...
Consider a hovering pillar. Thinking in a Newtonian way, gravity tries to compress the pillar. For example, the cross-sectional slab in my attached diagram has it acting onthe wieght W of all the stuff above the slac, and also a normal force applied to the slab by the stuff below.
Still thinking in a Newtonian way, if the accleration due to gravity changes over the length of the pillar, the wieght of all the stuff in the portion of the pillar above the slab is found by "adding up" (integrating) the weights (dW = a(d) dm) of a "bunch" of infinitesimal slabs above the illustrated slabs. Here, if appropriate dimensions and units are used, the infinitesimal mass can taken to be your dd.
This leads to an infinite squashing force as the pillar approaches the event horizon.
I think both you and JesseM have talked about stuff like this in other threads.
  • #107
If one has a uniform bar in a Newtonian field, the stress in the bar will be non-linear (I believe it's quadratic). GR will have a different distribution of stress for a uniform bar than the Newtonian case, but I think it winds up the same for a short enough bar.
But having a uniform bar is not the way to get a simple measure of tidal force.
The way to get a linear relationship and thus a simple read on the tidal force is to have a "lightweight" bar of negligible mass supporting a test mass, i.e.
(O)---------(m)
where O is the observer, the ----- is the lightweight bar with a "small" mass, and m is the test mass. This arrangement makes the force in the bar essentially constant.
But the above arrangement will work only if the observer is not accelerating.
For an accelerating observer, one way to fix this, and the way I'm proposing, is this:
(A1)-------------(A2)
A1 is an accelerometer mounted on one end of the bar (some test mass and a spring, for example), and A2 is an accelerometer mounted on the other end of the bar.
What I'm calling the "tidal force" is [tex]\lim_{L \rightarrow 0}(A2-A1)/L [/tex] where L is the length of the bar.
  • #108
Quadatic in the length of the bar? I don't suppose you know a reference?
I think the effect in my previous post is real, and that this is why scenarios for human space travel have a ~ 1 g. Notice that I didn't actually call the effect a tidal force. :biggrin:
Lately I have been working on wormholes (I get a big :frown: from Chris.), and the original Morris-Thorne paper calculates tidal forces for accelerated observers the same as they are calculated for freely falling observers. The paper says "The fact that the observer is accelerated (does not fall freely) has no influence on the relative acceleration that she feels."
Visser's book refers to box 37.1 of MTW for this argument, but I won't be able to look at MTW until tomorrow or Monday.
  • #109
Gah. I should have said that pressure should be proportional to depth, displacement (assuming Hooke's law) should be quadratic.
Yes, in casual conversation I'd just call that effect gravity, not tidal force. I'd interpret what you said as "when you stand up, the soles of your feet have to support all your weight".
IIRC the equations for pressure vs depth in GR can be derived from
[tex]\nabla_a T^{ab} = 0[/tex]
and the appropriate metric of interest.
I think I posted about this once, but I don't recall what my final conclusion was.
Box 37.1 (pg 1007) looks VERY interesting. It's not quite as clearcut as Visser's summary makes it sound, there are some acceleration effects mentioned of the order of (1+ax) and (1+2ax) applied at various places in the formula. I think I need to study this section a lot more carefully.
Checking the index, pg 860 $32.6 has a brief comment on tidal force as well, but it looks like the real meet is in box 37.1.
  • #110
JesseM said:
If the G-forces are different for different points on a rod undergoing Born rigid acceleration, and if a "uniform gravitational field" is just what must be postulated by a coordinate system undergoing Born rigid acceleration in order to view itself as being at rest, then there should be no problem with freely-falling observers--if the accelerating system sees an observer A as freely-falling, then A will see herself as being at rest in flat spacetime with no gravitational field while the coordinate system accelerates past her, so of course she will feel no G-forces.
You've missed the crux of the issue. Considering a single point A is no good - it will feel no force regardless of whether it's free falling in a "uniform" field or a "normal" non-uniform one. A uniform field is defined as one in which the equivalence principle holds exactly over an extended frame, so that an extended body feels no tidal force, or separated particles remain at constant distance, when in free fall.
If one adds a separated colinear observer B to your A then of course they'll stay at fixed separation when stationary in your scenario, but if one actually substitutes a gravitational field the only way that A and B can stay at constant distance is if the field is constant with height.
If you try and argue that the particle higher in the field needs to fall with greater acceleration to stay at the same distance you need a field "the wrong way round" - i.e. greater gravitational pull higher up and smaller gravitational pull lower down, which would be opposite to and in no way resemble the supposed "uniform acceleration".
Thus by elimination a "uniform gravitational field" is proven to be one where the g-force is the same at all heights, and by the same token "uniform acceleration" must involve the same g-force at all points along the frame.
  • #111
pervect said:
Now consider an observer free-falling through the event horizon of a black hole. The tidal force for such an observer is finite and independent of his velocity. (I can provide a reference if needed).
I doubt this. Can you provide a reference please? What about for a freely falling observer who is just above the horizon and escaping to r=infinity (i.e. in free fall and moving away from the black hole)? Is the tidal force for such an observer independent of her velocity?
  • #112
MTW's textbook, "Gravitation", carries out the calculation of the tidal forces on an infalling observer in pg 821-822. I'll quote some of the relevant sections:
The tidal forces felt by the explorer as he passes a given radius r are measured by the components of the Riemann curvature tensor with respect to his orthonormal frame there. To calculate these curvature components, proceed in two steps. (1) Calculate the components, not in the travellers frame, but rather in the "static" orthonormal frame.
and step (2) is to convert these to the traveler's frame.
The payoff of this calculation, according to equation (31.6), none of the components of the Riemann (ed note:components of Riemann == tidal forces) in the explorers orthonormal frame become infinite at the gravitational radius. The tidal forces the traveler feels as he approaches r=2M are finite; they do not tear him apart.
The independence of the tidal forces on velocity is also discussed in these pages - the traveller's frame and the static orthonormal frame are related by a Lorentz boost if the object is outside the event horizon, and by a boost-like transformation (but with a velocity parameter greater than 'c') if the falling object is inside the event horizon.
In either case (with the ordinary boost or with the hyper-boost) the components of the Riemann (i.e. the tidal forces) are totally unaffected by the boost, and are equal to the components of the Riemann in the static orthonormal frame. In geometric units, the stretching tidal force is of magnitude 2M/r^3, where M is the mass of the body, and r is the radius.
To give the exact quote:
The amazing result (a consequence of special algebraic properties of the Schwarzschild geometry, and somewhat analogous to what happens - or rather, does not happen - to the components of the electromagnetic field, E and B when they are both parallel to a boost) is this: all the components of Riemann are left completely unaffected by the boost.
This would also work for an outgoing traveler, though the textbook doesn't discuss this case explicitly.
[add]
One thing I should probably clarify. The results above apply only for a boost directly towards or directly away from the black hole. Though it is not directly discussed in MTW, one can see an effect on the Riemann / tidal forces due to a boost if the boost is in a non-radial direction. The point of the above remarks is that for a radial boost, there is no effect on the Riemann /tidal forces.
  • #113
Thanks so much for that great info pervect!
But if MTW are right, then how is GR valid? Let a freely falling rod be escaping to r=infinity radially as it travels through a group of particles falling toward one another to eventually form a black hole, when a horizon forms along the rod so that the rod spans the horizon with the part of the rod that is above the horizon still escaping to r=infinity radially. If the rod can be small enough (or the black hole large enough) that the tidal force on the rod can be too weak to break the rod, and GR features no other force that can break it, then how does it break as GR predicts it must so that it does not pass outward through the horizon? To be a self-consistent theory it seems that GR must feature a force other than the tidal force to break the rod, but I don’t see one mentioned in my texts. The tidal force isn’t an attractive force, so it can’t pull the rod inward across the horizon. Do you know what breaks the rod in this case?
  • #114
There are a couple of problems with your argument, I think.
The first problem is that one normally expects, in a well-behaved coordinate system, that two points with almost identical values of the 'r' coordinate will be "close together".
Schwarzschild coordinates are not well-behaved at the horizon, however. In fact, g_rr goes to infinity. This means that two points with nearly the same r coordinate can be "far apart".
Therefore it is not clear that a particle at the horizon, falling in, will ever be "close" to a particle that is escaping. Sure, they may have nearly the same r coordinate, but this does not mean that they are "close", because the metric goes to infinity.
The second problem relates to the fact that your problem statement is different than the one worked out in the textbook.
For any particle in the exterior region of the forming black hole, we can use the Schwarzschild metric, and the calculations from the textbook will apply. In this case there will be no difference between the forming black hole, and a static black hole, and the tidal forces will be finite. Therefore we can eliminate the forming black hole from the problem, and replace it with a static black hole, for any particle in the exterior of the forming black hole. We can do this both in the calculation, and in the problem statement.
However, we can't use the Schwarzschild metric for any particle in the interior of your forming black hole. If we assume that your forming black hole is a presureless collapse, we'd have to use the interior metric for such a presureless collapse. I seem to recall that this is just the FRW metric in the interior, smoothly joined to a Schwarzschild metric in the interior. This needs a new calculation of the Riemann components.
  • #115
The simplest case to analyze appears to be when the black hole is formed by dust falling in from infinity - i.e. a FRW cosmology with a_max=infinity, i.e. a FRW cosmology with the critical density.
In this case, for an observer moving with the dust, all tidal forces are compressive. So the radial component of the tidal force for someone comoving with the cloud will change sign depending on whether one is outside or inside the cloud.
This surprised me, but it is similar to the Newtonian case. Radial tidal forces are of the stretching type outside a massive body, because gravitational acceleration (in the Newtonian sense) drops off with increasing radius. Newtonian radial forces are of the opposite type (i.e. compressive) inside a massive body, because gravitational acceleration increases with increasing radius, i.e. the acceleration is zero at the center and for a body of uniform density follows a linear "Hooke's law".
As far as the effects of a boost on the tidal force goes: For the FRW cosmology, the boost doesn't seem to affect the components of tidal force in the direction of the boost, but it does affect (increase) the tidal forces in the transverse directions.
So this suggests that the first explanation I offered is the correct one, the issue is that two objects with nearly identical 'r' coordinates may not actually be close near the horizon, because the metric coefficient multiplying dr^2 becomes infinite.
  • #116
For any part of the rod to fall inward through the horizon, the rod must first break. But that’s the question, whether or not the rod breaks. If you’re talking about one of the cloud of particles that forms the black hole, I don’t see why it would need to be close to a particle of the rod that is escaping.
GR must predict that the tidal force on the rod is infinite, so the rod will always break regardless of its tensile strength, which can be arbitrarily high in principle. Otherwise the rod could pass outward through the horizon, violating GR’s prediction that nothing can do that.
... However, we can't use the Schwarzschild metric for any particle in the interior of your forming black hole. If we assume that your forming black hole is a presureless collapse, we'd have to use the interior metric for such a presureless collapse. I seem to recall that this is just the FRW metric in the interior, smoothly joined to a Schwarzschild metric in the interior. This needs a new calculation of the Riemann components.
I translate what you’re saying to this: Although the tidal force is independent of velocity, GR may predict that the tidal force on the rod is infinite, because part of the rod is below the horizon. Do I have that right?
The rod isn’t comoving with the cloud of particles that formed the black hole. It was escaping to r=infinity from the cloud when the horizon formed along the rod.
It seems that GR would be self-inconsistent even if it predicted that the tidal force on the rod is infinite. GR postulates that SR holds locally. But SR cannot hold locally where the tidal force is infinite locally.
How does GR avoid self-inconsistency? I don’t see how it can.
  • #117
Wouldn't your argument also imply that if an accelerating observer in flat spacetime was dragging along a rod undergoing born rigid acceleration (so its length remains constant in the Rindler coordinate system where the accelerating observer is at rest), then by making the rod's tensile strength high enough the back end of the rod could pass through the Rindler horizon? But in fact this is impossible--as explained here, the rod must always break if it extends past the Rindler horizon. And the breaking has nothing to do with tidal forces, since this takes place in flat spacetime, it has to do with the fact that in order to pass the through the horizon in Rindler coordinates, the back end of the rod would have to move FTL as measured in an inertial coordinate system. It seems quite possible that the breaking of a relatively short rod moving outward that is cut in half by the formation of an event horizon would also have nothing to do with tidal forces (since after all tidal forces always disappear in the limit as you zoom in on a smaller and smaller local region of spacetime, and you're free to make the rod as short as you like, all that matters is that it gets cut in half by the event horizon). I believe observers at different ends of a rod undergoing Born rigid motion in flat spacetime do experience different G-forces (different proper acceleration), so perhaps the breaking of the rod could be explained in terms of some sort of "fictitious" tidal-like force that's a consequence of adopting a non-inertial coordinate system. But as I understand it a real tidal force always implies spacetime curvature.
  • #118
Consider in particular a radar method of measuring distance. Assume, for the sake of argument, that one could put something that reflects radar waves at the event horizon of a black hole.
While there can be many different methods of measuring "distance in the large", for objects nearby all methods give the exact same distance. (This is because "nearby", we can ignore curvature effects).
Since we are interested in particular in nearby measures of distance, the radar method is a good one, and it has the advantage that it is easy to understand and visualize.
It seems obvious even without using math that an object that is not falling into a black hole will always see the horizon as being "distant", because while a radar signal can be emitted, one will never receive a return.
[add]It probably wouldn't be a bad idea to do a more formal analysis, though - something along the idea of computing the distance to the horizon in the radial direction using Rieman normal coordinates.
Contrawise, an object falling into a black hole can see the event horizon as being "close" via the radar method - the radar return signal will reach the infalling object at the same time as the object crosses the event horizon.
Thus if an object is only 2ns of proper time away from crossing the event horizon, we can say that the event horizon is approximately 1 foot away in the local frame-field of the observer.
Thus the distance to the event horizon depends on the velocity of the observer, but this is nothing new. The distance from Earth to Alpha Centuari also depends on the velocity of the observer. The radar experiment makes it pretty clear that an object that does not cross the event horizon is never "close" to the horizon.
  • #119
Assuming for the sake of argument it implied that, how does it answer the key question: how can GR be self-consistent? More on this below.
The rod I’m talking about is freely falling. By the definition of “freely falling object”, no forces except gravity are acting on the rod. Then if the rod breaks, it must be the tidal force that broke it, because the only force of gravity in GR is the tidal force. Yes, GR says that the tidal force always disappears in the limit locally, but GR also predicts that the tidal force must be what breaks the rod if it breaks, by disallowing any other possibility.
I don’t see how. According to GR, the tidal force is the only force on the rod. A fictitious force cannot break the rod; only a real force can do that.
The rod must break, or else GR is self-inconsistent (because then the rod would pass outward through the horizon in contradiction to GR’s prediction). Only an infinite tidal force is guaranteed to break the rod, since the tidal force is the only force on the rod (according to GR) and the rod’s tensile strength can be arbitrarily high in principle. So if the rod breaks, GR is self-inconsistent (because then SR would not hold locally as GR postulates). If GR is self-consistent then something must be wrong with my argument. I’d like to know in no uncertain terms what is wrong with it.
  • #120
pervect said:
... Thus the distance to the event horizon depends on the velocity of the observer, but this is nothing new. The distance from Earth to Alpha Centuari also depends on the velocity of the observer. The radar experiment makes it pretty clear that an object that does not cross the event horizon is never "close" to the horizon.
I don’t disagree with anything in your post. But how does it show the problem with my argument? The rod spans the horizon; the horizon is somewhere along the rod. When you’re grazing Alpha Centauri, its distance from you does not depend on your velocity; it’s zero. And you’re at Alpha Centauri. Right?
  • #121
But unless the rod is made up of noninteracting dust particles, every part of it won't really be moving in a locally inertial way (freely-falling), since different sections can push and pull on one another.
No, I think you're wrong on this. As long as the different parts of the rod interact with each other they won't all be freely-falling, so you don't have to assume it's tidal forces that break the rod. We know that in the case of a rod being dragged along by an accelerating observer, the rod also must break if it extends past the observer's Rindler horizon, and yet this is a flat spacetime situation with no tidal forces.
  • #122
How is this different from saying that there’s no such thing as a freely falling object? Doesn’t this apply to even a dust particle? Even a dust particle is made up of interacting particles.
You’re suggesting that any object floating in space rips apart due to forces other than tidal forces. (I won’t say “freely falling object” because you’re suggesting that there’s no such thing.) Unless GR predicts that the International Space Station will always break apart for the same reason, it doesn’t show the problem with my argument. For you to be right, GR would have to predict that even a hydrogen atom floating anywhere in space always breaks apart, and even its subatomic particles would have to break apart too. But GR doesn’t predict that.
  • #123
I'm talking about the sort of idealized "dust" used in general relativity, like the kind in this paper, not realistic physical dust.
No I'm not--large objects that occupy regions where there is significant spacetime curvature can of course be ripped apart by tidal forces. My argument is specific to the case you're discussing, since there is nothing in your thought-experiment that requires the rod be particularly large, I don't see why we can't assume an arbitrarily short rod that just happens to be right at the location the event horizon forms when it does. Of course there's a complication in the sense that the event horizon of a star collapsing into a BH is actually supposed to start at the center, then grow until it reaches its final radius, but I don't see why we shouldn't assume the event horizon sweeps past the back end of the rod and then reaches its final radius right at the middle...even if the rod's size is neglible the time for the event horizon to sweep past the back end and reach the middle might not be, I'm not sure, and likewise the time for the stress to increase and the rod to break apart might not be negligible. And since tidal forces only go to zero in short intervals of time as well as small regions of space I could be wrong that the ripping apart has nothing to do with tidal forces. I don't see that we can assume the rod rips apart because of tidal forces though, not without actually doing a mathematical analysis of a specific situation as opposed to handwaving verbal arguments.
What "same reason" would that be? The ISS isn't on the event horizon of a black hole, and the event horizon has other properties that are likely to be relevant besides tidial forces, like the way light cones are tipped over and the fact that the horizon seems to be moving at c as measured by a free-falling observer passing through it.
  • #124
Actually, thinking about this some more the rod probably does have to break due to tidal forces, since in flat spacetime with no tidal forces it's always possible for an object to remain perfectly rigid with every single point in the object moving inertially, so I can't think of a reason why a small rod couldn't be moving like that for a brief moment if we zoom in on a small region of spacetime around the event horizon. And in this region the event horizon is moving outward at the speed of light in a locally inertial coordinate system, so no part of the rod can move from inside of the event horizon to outside it in this region--the only way any part of the rod could ever avoid being swallowed by the horizon would seem to be if we were considering a non-local region of spacetime which couldn't be treated as identical to flat spacetime with the horizon moving at c. So for the rod to break and part of it to escape the horizon, it seems like we do have to consider a rod of non-negligible length, although I still think some sort of mathematical analysis is needed to be sure.
Still, even if it is tidal forces that break the rod, I'm not convinced about your argument about the tidal forces needing to be infinite. You say that the tensile strength of a material can be infinite, but doesn't tensile strength have to do with resistense to breaking at a single point in that material when Newtonian force is applied to that point, whereas tidal "force" is not localized like Newtonian force, since it always goes to zero in a local region? Also, the page on Rindler horizons I linked to earlier mentions that there is an upper limit to the stiffness of a material in relativity imposed by the speed of light--I can't find definitions of stiffness vs. tensile strength, do you have them, and if so could you explain exactly why you think it would be impossible to break apart an object of finite stiffness with finite tidal forces if it's tensile strength were arbitrarily high?
  • #125
Agreed.
I said the tensile strength can be arbitrarily high, not infinite. It seems like you’re suggesting that the ability of the tidal force to break an object is unaffected by its tensile strength. But everything I’ve read says the opposite.
I’m not sure I can prove that. But it doesn’t seem necessary to prove that. To avoid contention on the issue of an infinite tidal force I can modify the argument. The tidal force on the rod must be strong enough to break it. The rod can be arbitrarily small. Any object could substitute for the rod, so the tidal force must be strong enough to break any arbitrarily small object. GR says that SR holds locally; i.e. in an arbitrarily small region. But it cannot hold locally when any arbitrarily small object breaks due to tidal forces on it.
BTW, this isn’t a handwaving argument. Logic can show an inconsistency with a theory. Math is just one form of logic. If logic shows with certainty that GR predicts that the rod must break and also predicts that the tidal force on the rod can be too weak to break it, then GR is self-inconsistent and no math is necessary. We can depend on the math that has been done in spades to show GR’s prediction for a horizon, and we can depend on GR’s postulate that says that SR holds locally. The math would have to support the logic, or else the math that has been done in spades is wrong.
  • #126
I didn't say unaffected, because again, I don't really know the relationship between stiffness and tensile strength. But without knowing the precise definitions, it's not at all obvious that making the tensile strength arbitrarily high will always be sufficient to prevent breaking given some large but finite tidal force, given that there is an upper limit to stiffness.
Well, forget infinite. Can you prove that for an arbitary large but finite tidal force, the rod can be prevented from breaking by making the tensile strength high enough, even though we can't make the stiffness any greater than some maximum upper limit?
No it can't, because like I said, "tidal force" is not analogous to a Newtonian force which can be defined in an arbitrarily small region--the tidal force always goes to zero in the limit as the size of the region goes to zero (except in the case that the region contains a singularity).
But logic is only as good as the assumptions you make. If your assumptions are false, like the assumption that you can always prevent breaking by finite tidal forces if you make the tensile strength high enough, in spite of the upper bound to stiffness, (which is a physical statement that you can't prove by 'logic' alone), then your conclusions will be false too.
  • #127
I think it's about time to lock this thread. We are not here to debate the validity of mainstream science - which is essentially what Zanket is interested in doing with his claims about "GR being inconsistent".
Zanket will have to have this sort of discussion on some other board (if he can find anyone interested in carrying it out).
I've given the thread some latitude because in his misguided attempt to find inconsistencies in GR, Zanket has asked some interesting questions. But I think the questions have basically been answered (even if Zanket isn't listening to the answers).
It's unfortunate that Zanket continues to confuse the ill-behavior of Schwarzschild coordinates at the horizon with deep problems in GR. Schwarzschild coordinates are in fact singular at the horizon - the simple solution to this issue is to use some other coordinate system.
