Dimensional Analysis of Constant Acceleration at 1 g
In summary, Newton's universal formula for calculating Gravity: Fg = G Mm / r²which states that two objects attract each other with a force equal to the product of their masses divided by the square of their separation, times a constant of proportionality (G), where G = 6.6742(10) x 10^-11 makes it possible to calculate the mean acceleration due to gravity (g)for any planetIn summary, Newton's universal formula for calculating Gravity states that two objects attract each other with a force equal to the product of their masses divided by the square of their separation, times a constant of proportionality, which is 6.6742(10) x 10
Gregor
39
for any planet
in the case of Earth
g = G*Me / Re²
earth's radius (Re] = 6 378 137 m
this radius squared = 40 680 631 590 769
earth's mass (Me) = 5 977 347 368 296 994 158 859 250.7577676 kg
G = 0,0000000000667421 m³ kg^-1 s-²
applying these values to the above formula
/ 40 680 631 590 769
= 146 933 494 750.68959472357028022792
*0.0000000000667421
= 9.80665
therefore 1 g = 9.80665 m/s²from this point a dimensional analysis can be made
on the premise that
d = integral of v dt over time interval
since gravity is constant acceleration
v = g*t
d = g*t²/2
as illustrated in following table
exact values from rest to 0.2 seconds - in 0.01 s intervals
Velocity m/s...Time (s)...Distance (m)
0 ........0 ...... 0
0.0980665 .... 0.01 ... 0.0004903325
0.196133 ...... 0.02 ... 0.00196133
0.2941995 .... 0.03 ... 0.0044129925
0.392266 ...... 0.04 ... 0.00784532
0.4903325 .... 0.05 ... 0.0122583125
0.588399 ...... 0.06 ... 0.01765197
0.6864655 .... 0.07 ... 0.0240262925
0.784532 ...... 0.08 ... 0.03138128
0.8825985 .... 0.09 ... 0.0397169325
0.980665 ..... 0.10 ... 0.04903325
1.0787315 .... 0.11 ... 0.0593302325
1.176798 ...... 0.12 ... 0.07060788
1.2748645 .... 0.13 ... 0.0828661925
1.372931 ...... 0.14 ... 0.09610517
1.4709975 .... 0.15 ... 0.1103248125
1.569064 ...... 0.16 ... 0.12552512
1.6671305 .... 0.17 ... 0.1417060925
1.765197...... 0.18 ... 0.15886773
1.8632635 .... 0.19 ... 0.1770100325
1.96133 ...... 0.20 ... 0.196133
exact values from rest to 2 seconds - in 0.1 s intervals
0 .......0 ..... 0
0.980665 ..... 0.1 ..... 0.04903325
1.96133 ...... 0.2 ..... 0.196133
2.941995 ..... 0.3 ..... 0.44129925
3.92266 ...... 0.4 ..... 0.784532
4.903325 ..... 0.5 ..... 1.22583125
5.88399 ...... 0.6 ..... 1.765197
6.864655 ..... 0.7 ..... 2.40262925
7.84532 ...... 0.8 ..... 3.138128
8.825985 ..... 0.9 ..... 3.97169325
9.80665 ...... 1 ..... 4.903325
10.787315 ... 1.1 ..... 5.93302325
11.76798 ..... 1.2 ..... 7.060788
12.748645 ... 1.3 ..... 8.28661925
13.72931 ..... 1.4 ..... 9.610517
14.709975 ... 1.5 ..... 11.03248125
15.69064 ..... 1.6 ..... 12.552512
16.671305 ... 1.7 ..... 14.17060925
17.65197 ..... 1.8 ..... 15.886773
18.632635 ... 1.9 ..... 17.70100325
19.6133 ...... 2 ..... 19.6133at 1 g
an object will (from rest) fall 1 m in 0.452 s ---- reaching a velocity of 4.4326058 m/s
an object will (from rest) reach a velocity of 1 m/s in 0.10197162129779282425700927431896 s
and will (during this interval) travel a distance of 0.050985810648896412128504637158521 m
anyone have any criticisms of my calculations now? :rolleyes:
And the purpose of these calculations is...?
ok, what was the point of moving this topic to Homework & Coursework Questions ?
this is neither Homework nor Coursework
it's a Classical Physics topic
a demonstration of my ability to perform Dimensional Analysis :cool:
correct me if I'm wrong (I only just started a topic of motion in a horizontal circle yesterday) but wouldn't the centre directed accelleration due to an objects position on the Earth be added to the normal gravitational force?...thus making results correct to 32 s.f. perhaps a bit premature? (i might be wrong and if I am I do apologise)...and even falling from rest for only 1m...I have a vague expectation that drag would also skew those results.
Why don't you go buy a book on physics, you still seem to think [tex] ms^2 = \frac{m}{s^2} [/tex].
Yes, you are quite correct. There are a number of reasons why it is inappropriate to quote to 32 sf. Primarly because the accuracy of some data is only given to 5 sf. Also, this theory assumes that the Earth is spherical, which it isn't. Also, the apparent force of gravity is altered by the Earth's rotation and significantly more by the movent of other massive bodies (moon and sun etc); in fact, these massive bodies can cause fluctuations of upto [itex]2\mu \;\; m\cdot s^{-1}[/itex] per day.
Sorry to put a bummer on your work Gregor, but apart from quoting your answers to a inappropriate number of sig figs you have obviously put a fair amount of work in. :smile:
It's probably the fact that I need coffee, but I can't see where he has said that :confused:
What does all that number crunching have to do with dimensional analysis?
Its from another thread. Put your seat belt on, because I am sure its BOUND to come up again now that he has proved he can do dimensional analysis
you still seem to think[PLAIN]https://www.physicsforums.com/latex_images/93/938964-0.png[/QUOTE]
it was you who posted the expression https://www.physicsforums.com/latex_images/93/938964-0.png
which is meaningless
you need serious helpthe dimensional analysis is represented in the table i calculated
if you take the time to read the table
you will find that it's absolutely correct
the point has been made, so from here on i will just sit back and watch you make a fool of yourself
I guess you still do not understand the meaning of dimensional analysis.
Dimensional analysis is MUCH simpler and is used to verify calculations without the use of ANY numbers.
Here is dimensional analysis for your first equation
[tex] g = \frac {G M_e} {R_e^2} [/tex]
[tex] g = \frac {m^3} {kg s^2} * \frac {kg} {m^2} [/tex]
now do basic algebra on the units to get:
[tex] g = \frac m {s^2}[/tex]
this is the correct units for acceleration, now that you know the basic relationships are correct you can proceed with your calculation using valid numbers for your quantities. Here is where you have thoroughly demonstrated a total lack of understanding of the concept of significant digits.
Open up one of your many physics books and look up what "dimensional analysis" means.
What's your point? You just plugged numbers into an equation. Uh... why?
"earth's mass (Me) = 5 977 347 368 296 994 158 859 250.7577676 kg" :rofl:
You've made no point.
Please don't start another of these silly threads.
I cannot see any purpose to what you have done gregor. It looks like you've gone the long way round to nowhere. As Doc Al said, dimensional analysis isn't plugging numbers into equations, it looking at the dimensions of the equations.
i know what dimensional analysis is
the table was an illustration giving numerical proof
and what the hell do you find so funny about Earth's mass?
are all mentor's in this forum narrowminded?
If you're actually measuring the Earth's mass down to the microgram, I'm afraid that you're ignorant.
The Earth is constantly losing some mass (e.g. hydrogen) from the top of the atmosphere, while constantly gaining other mass (e.g. dust from meteors, etc.). The Earth's mass varies on the order of several tons a day. So it's absolutely laughable to try to quote the Earth's mass to a precision of micrograms.
And it's very apparent, Gregor, that you actually do not know what dimensional analysis is. As has been said, once you start plugging in numerical values, you're by definition no longer doing dimensional analysis.
Please grow up and recognize the limits of your own understanding.
- Warren
the precise value of Earth's mass (for those nearsighted thwackheads out there in physics lalaland) may be derived by Newton's Gravitational Formula
Fg = G Mm / r²
since the value of Re is precisely known to be 6 378 137 m
which squared = 40 680 631 590 769
and the value of G is a precise value : 0,0000000000667421
as well as g : 9.80665 m/s²
therefore Me is precisely defined by default as 5 977 347 368 296 994 158 859 250.7577676 kg
More insults deleted
Integral
Gregor said:
the fact that you couldn't think this out on your own
proves that you couldn't calculate your way out of a public toilet :rolleyes:
:rofl: Where to begin? Where to begin?
The value of G is only known to about six significant figures (you posted it, count them yourself!). This means your calculation of the mass of the Earth is also only accurate to about six significant figures. This means your assertion of the mass of the Earth in terms of micrograms is entirely meaningless. It's effectively nothing more than "measurement noise."
The most precise value for Me that you could quote, using your own numbers, is 5.97734 x 1024 kg. :rofl:
Are you just a troll, or what?
- Warren
the end result must equal the known, measured value for g
this is the only way we can measure Earth's mass
Edit:Enough with the insults
Integral
tell that to your Admin...
Chroot - Are you just a troll, or what?
and these are grown up people?
You've had this explained to you numerous times Gregor. If you still wish to discuss the topic, take it to another website.
- Warren
1. What is dimensional analysis?
Dimensional analysis is a mathematical technique used to analyze and understand the relationships between different physical quantities. It involves examining the dimensions and units of the quantities involved in a problem to gain insight into their behavior.
2. What is constant acceleration at 1 g?
Constant acceleration at 1 g refers to the acceleration experienced by an object due to the force of gravity on Earth, which is approximately 9.8 meters per second squared (m/s^2). This means that an object in free fall will accelerate at a rate of 9.8 m/s^2 towards the ground.
3. How is dimensional analysis used to study constant acceleration at 1 g?
Dimensional analysis can be used to study constant acceleration at 1 g by examining the dimensions and units involved in the problem. By using the correct units and dimensions, scientists can make accurate predictions and calculations related to this type of acceleration.
4. What are some real-life applications of dimensional analysis of constant acceleration at 1 g?
Dimensional analysis of constant acceleration at 1 g has many real-life applications, including predicting the trajectory of projectiles, understanding the motion of objects in free fall, and designing roller coasters and other amusement park rides.
5. How does the value of 1 g affect the motion of objects?
The value of 1 g greatly affects the motion of objects on Earth, as it is the acceleration due to gravity that pulls objects towards the ground. This force is responsible for the motion of objects in free fall, as well as the weight of objects on Earth's surface.
10K
  • Mechanics
9K
