Relationship between linear and circular velocity
In summary: If the curve is too steep, the runner will expend more energy and the time will be longer.Thanks for clearing that up!
Robert Vaughan
My Math and Physics knowledge has eroded from over 30 years of non-use though I can still integrate e^x with the best of you!
My son wants to know how to determine the time it takes to travel/complete a circular arc in terms of the time it takes to travel the same distance going in a straight line ... assuming in both cases that the "linear velocity" is the same and is constant.
I may be expressing it incorrectly but I think he is trying to determine the additional time it would take a runner to travel the same distance on a circular track ... relative to the time it would take the same runner to travel that distance on a straight track ... both with identical surfaces.
Thanks!
Thanks!
If the distances are the same and the speeds are the same, then the time must also be the same. Distance= speed * time, regardless of if it is linear or not. Maybe that isn't what he was asking...?
Not sure I'm getting the point of the question. A runner will cover the same distance regardless of his path, as long as his speed is constant.
Sorry for the confusion ... my terms were obviously incorrect ... in both cases, the runner is running at his "maximum speed" so I suppose you could say the expended energy is the same ... his understanding is that when running on a circular path, centrifical force would come into play and his "forward momentum" would be reduced ... so that it would take longer to navigate the arc than it would to travel the same distance on a straight course.
Again, the terms may be incorrect but I hope the intent of the question is clearer.
I guess his maximum speed on a curve would be less than his maximum speed on a straight because the runner would still be accelerating on the curve. The force required to do this acceleration would be his mass times the angular acceleration which (correct me if I'm wrong!) is v2/2 (you might want to check that cos I don't really use this very often).
Actually i know that's wrong cos you need the radius in there somewhere!
its mv^2/r
it would take the same amount of time assuming the guy is running at his maximum speed in both cases, centripetal acceleration does not effect forward velocity.unless your question was more along the lines of how much longer will it take to run around a circle as compared to running across the circle.
The way I'm thinking about it you say the power is constant.
Power = work/time = force*speed = constant
because on the circle the runner needs more force to overcome the centrifugal force, his speed must drop. The additional force he will need is mv^2/r.
As the first answers to this post mention, it can be shown with simple kinematics that the times are equal. No need to think about anything else than kinematics.
As long as the curve isn't too steep, the runner is not expending a significant amount to create centripedal acceleration.
What is the relationship between linear and circular velocity?
The relationship between linear and circular velocity is that they are two different ways of measuring the same thing - speed. Linear velocity is the speed of an object in a straight line, while circular velocity is the speed of an object moving in a circular path. The two are related by the radius of the circle - the longer the radius, the faster the object must travel to maintain the same circular velocity.
What is the formula for finding linear velocity from circular velocity?
The formula for finding linear velocity from circular velocity is v = rω, where v is the linear velocity, r is the radius of the circle, and ω (omega) is the angular velocity (measured in radians per second). This formula shows that the linear velocity is directly proportional to the angular velocity and the radius of the circle.
Can linear velocity and circular velocity be equal?
Yes, linear velocity and circular velocity can be equal. This occurs when an object moves in a circular path with a constant speed. In this case, the linear velocity will be equal to the circular velocity at any point on the circle.
How does linear velocity change as the radius of the circle changes?
As the radius of the circle increases, the linear velocity will also increase. This is because the circumference of the circle (which the object must travel in one revolution) increases as the radius increases. Therefore, the object must travel a greater distance in the same amount of time, resulting in a higher linear velocity.
Can the relationship between linear and circular velocity be applied to other shapes besides circles?
Yes, the relationship between linear and circular velocity can be applied to other shapes besides circles. This is because any shape with a curved path can be broken down into infinitesimal circular paths, and the linear velocity at any point on the path can be found using the formula v = rω. However, this relationship only applies to objects moving at a constant speed along a curved path.
  • Mechanics
17K
