bgggsob
- 2
a body of mass m1 and speed v1 collides with a body of fmass m2 at rest. the bodies ad here; the collision is perfectly inelastic. what fraction of the initial kinetic energy remains?
a body of mass m, moving with velocity v1, strikes an ideintical body at rest, off center. friction and rolling effects are negligible. if collision is perfectly elastic, final velocities of the two bodies will be perpendicular. if the collision is not perfectly elastic, is the angle between the final velocities always less than 90 degrees, always greater than 90 degrees, or greater in some collisions, less in others?
the trajectory of a projectile (with aerodynamic drag negelcted) is only apporximately a parabola, because the acceleration due to gravity is only approximately constant, and that only for projectiles which don't travel two high or too far. a more accurate approximation is to treat the Earth as a spherically symmetic mass. given that, and still disregardinig drag, describe as precisely as possible the actual shape of a projectiles path---even projectiles which travel long distances over the earth
a satellite is in circular orbit around its parent body. the ratio of the satellits kinetic energy to its potential energy, K/Ug is a constant independent of the masses of the satellite and parent, and of the radius and velocity of the orbit. find the value of this constant (potenial energy is taken to be zero at infinite separation)
