Open problem of classical representation of neutral antimatter bodies?
In summary, according to relativity, a neutral matter body would be exactly like a regular matter body.
Collider
Can anybody please tell me how to represent a neutral antimatter body such as a planet or a star in the classical formulation of special and general relativities?
Thanks.
Welcome to PF;
What do you mean by "represent a ... body"?
eg. can you show me how you would represent a regular matter body in SR and GR?
iirc: SR is about relative motion, and GR is about gravity - in a nutshell.
Relativity does not care about matter <-> antimatter. It would be exactly like a neutral body made out of matter.
Likes Larry Pendarvis
Simon Bridge said:
Welcome to PF;
Newton's equation, Galileo's Relativity, and Einstein's relativities deal with a body constituted by matter with a given mass m.
The only classical conjugation into anti-matter that I know of is the sign of the charge but I am interested in Newton's equation of motion or Einstein gravitation of a neutral anti-matter body that has no charge.
Does this make the entire 20th century of science inapplicable for a classical representation of neutral anti-matter?
I raise the question because I have seen on various websites the treatment of a matter-anti-matter gravitational repulsion. I have trouble accepting them unless I see a classical representation of the gravitational field of a neutral antimatter astrophysical body.
Charge is just one of the quantum numbers which are inverted for antimatter, there are more. But it does not matter: relativity cares about the energy density only, and that is the same both for matter and antimatter.
See my previous post: It would be exactly like a neutral body made out of matter.
It is expected that antimatter and matter attract each other, and anything else would be a huge surprise. It would require serious modifications to relativity, and allow a violation of energy conservation and similar things.
It's the way to bet isn't it?
OP is probably thinking about stuff like:
http://en.wikipedia.org/wiki/Gravitational_interaction_of_antimatter
http://www.phy.duke.edu/~phillips/gravity/frameIndex.html
National Geographic ran a pop-sci article in Feb 2012 titled: Is Dark Energy Really "Repulsive Gravity"? citing and quoting Massimo Villata, "an astrophysicist at the Observatory of Turin in Italy".
Investigating that last one turns up stuff like:
Villata M. (2012) "Dark energy" in the Local Void... a "letter to the editor" in Astrophysics and Space Science, which is cited by
by Hajdukovic D. S. (2013) Can observations inside the Solar System reveal the gravitational properties of the quantum vacuum?, Astrophysics and Space Science, February 2013, Volume 343, Issue 2, pp 505-509
... who propose a test.
afaik, there is no special reason to suspect antimatter has anti-gravity except perhaps that the prefix "anti" appears in both the names.
The OP isn't thinking of stuff like that, and as the OP won't be back, there's not much point in continuing trying to answer his questions.
1. What is the classical representation of neutral antimatter bodies?
The classical representation of neutral antimatter bodies refers to the theoretical framework used to describe the physical properties and behavior of particles with equal mass but opposite charge to their corresponding matter particles.
2. Why is the classical representation of neutral antimatter bodies considered an open problem?
This is considered an open problem because despite decades of research, there is still no complete and satisfactory understanding of how neutral antimatter bodies behave and interact with matter.
3. How does the classical representation of neutral antimatter bodies differ from that of matter?
The main difference is that antimatter particles have the opposite charge to their corresponding matter particles, which results in different interactions and behaviors. For example, antimatter particles will repel matter particles, whereas matter particles will attract each other.
4. What is the significance of solving the open problem of classical representation of neutral antimatter bodies?
Solving this problem would provide a deeper understanding of the fundamental laws of physics and could potentially lead to groundbreaking advancements in technology, energy production, and space exploration.
5. What are some current theories and approaches being used to solve this open problem?
Some current theories and approaches include experiments at particle accelerators, theoretical calculations using quantum field theory, and studies of cosmic rays and their interactions with matter. Scientists are also exploring the possibility of using advanced technologies, such as laser and magnetic fields, to manipulate and study antimatter particles.
  • Other Physics Topics
  • Classical Physics
  • Beyond the Standard Models
