| New Reply |
Simple and quick question on rotational motions |
Share Thread | Thread Tools |
| Dec24-12, 09:46 AM | #1 |
Hi guys, if a particle that is rotating around a axis at a constant angular acceleration, and at the highest point, it broke loose and flies off tangently and horizontally into the air, does it have a tangential acceleration of r*angular acceleration alpha? Please help!! This is found in University physics textbook qns 9.63 and the answer never includes the tangential acceleration although I think it should!
| Dec24-12, 09:59 AM | #2 |
After the particle breaks loose, what forces are acting on it?
| Dec25-12, 02:05 AM | #3 |
| Dec25-12, 02:20 AM | #4 |
| Dec25-12, 05:26 AM | #5 |
| Dec25-12, 05:45 AM | #6 |
Sorry, words are failing me lately. I would say that while the wheel is experiencing angular acceleration, the particle is experiencing tangential acceleration, with a resulting change in tangential velocity (could be speeding up or slowing down based on the direction of angular acceleration), as long as it is attached.
| Dec25-12, 06:26 AM | #7 |
Recognitions:
The tangential acceleration is along the tangent of the path, and its magnitude is at=dv/dt, derivative of the speed with respect to time. The radial acceleration is normal to the tangent and points toward the centre of the curvature of the path; the magnitude is v2/R where R is the radius of curvature. When the particle loses contact, it experiences a different force as before: gravity instead of the resultant force which forced it move along the circle with constant angular acceleration. The acceleration is proportional to the force: the force changes so does the acceleration. At the same time the velocity stays the same as just before loosing the contact, it is horizontal. As the force is vertical and the particle moves horizontally at the first instant after breaking loose, there is no tangential force acting on it so the tangential acceleration is zero. Later on, the particle moves like a projectile along a parabola. With respect to that parabola, gravity has both tangential and radial components, so there will be both radial and tangential components of the acceleration. ehild |
| New Reply |
| Thread Tools | |
Similar Threads for: Simple and quick question on rotational motions
| Thread | Forum | Replies | ||
| Quick rotational spectroscopy question(only need ideas/suggestions) | Biology, Chemistry & Other Homework | 0 | ||
| Quick rotational motion question | General Physics | 4 | ||
| Quick Question about Rotational Energy | Introductory Physics Homework | 1 | ||
| Simple, simple question concerning errors needing quick answer | Calculus & Beyond Homework | 0 | ||
| rotational motions | Introductory Physics Homework | 0 | ||
