Tricky Trig Integration: How to Tackle Powers and Parts?
In summary, the problem deals with integration by parts. You might want to consider trying to type it out in latex since attachments can take some time to be approved.
graycolor
34
I need help I don't even know where to begin. The problem is attached, does this problem deal with integration by parts or should break sec down and some how get cot.
You seem to have forgotten the attachment?
Either way, you might want to consider trying to type it out in latex since attachments can take some time to be approved.
Sorry, its attached now.
So you can't see what I attached right now.
Okay here it is: Integral of (sin(14x))^3/cot(14x) respects to x from 0 to pi/42
Don't forget your trig identities!
A few you might find particularly useful here:
[tex]\cot x = \frac{\cos x}{\sin x}[/tex]
[tex]\sin^2 x = \frac{1 - \cos 2x}{2}[/tex]
[tex]\cos x \cos y = \frac{1}{2} \left[ \cos(x-y) + \cos(x+y) \right][/tex]
[tex]\cos(-x) = \cos x[/tex]
I think those are all you will need. Use them too rewrite the formula beneath the integral, you will see that it becomes much easier, as is very often the case!
After rewriting I get sec(14x)^3/3*tan(14x)dx letting my u equal sec(14x) and du=sec(14x)tan(14x) I get the integral of U^2du and the final answer comes to U^3/3... am I correct. Then plugging in sec back in, I get the final answer of sec(14x)^3/3...the funny thing is when I take the derivative I get 14sec(14x)^2*sec(14x)*tan(14x) and not the original equation that should be sec(14x)^2*sec(14x)tan(14x) I must be missing something.
EDIT
Oh dang, I misread your equation to be * cot... instead of / cot...
Let me have a look again. Hold on.
I am confused here, is the integrand
[tex]\frac{sin^{3}(14x)}{cot(14x)}[/tex]
Yeah I think it is, but I misread it to be [tex]\sin^{3}(14x) \cot(14x)[/tex]
sorry guys I meant sec(14x)^3/cot(14x)...I figured it out myself for those interested here it is... after rewriting we bring up cot and make it a tan so its now sec(14x)^3*tan(14x) letting u=sec(14x) are du is 14sec(14x)tan(14x) missing things around our equation now looks like 1/14*U^2du after integration its U^3/42 our final answer is sec(14x)^3/42 then just do the fundamental theorem. Sorry for typing the wrong problem.
There use to be a mark as solved feature can't seem to find it.
1. What is the purpose of integrating trig powers?
The purpose of integrating trig powers is to find the antiderivative of a function that contains trigonometric terms. This allows us to solve problems involving motion, sound, and other physical phenomena.
2. What are the basic rules for integrating trig powers?
The basic rules for integrating trig powers include the power rule, substitution, and trigonometric identities. These rules are used to simplify the function and make it easier to integrate.
3. How do I integrate trig powers with exponents?
To integrate trig powers with exponents, you can use the power rule and apply it to each term in the function. You may also need to use trigonometric identities to simplify the function before integrating.
4. Can I use trigonometric substitution to integrate trig powers?
Yes, you can use trigonometric substitution to integrate trig powers. This involves substituting the trigonometric functions for the variable in the function and using trigonometric identities to simplify the function.
5. Are there any common mistakes to avoid when integrating trig powers?
One common mistake to avoid when integrating trig powers is forgetting to use the chain rule when there is a composition of functions. It is also important to carefully apply the trigonometric identities and double check your work for any errors.
