Question on inductance with magnetic material core.
In summary, there is a difference in inductance of an inductor with magnetic material whether it is magnetized or not. The stronger the magnetization, the higher the \mu and the inductance. This is due to the non-linear relationship between flux and mu, known as the "B-H loop". To learn more about this subject, recommended reading materials include e/m fields texts such as Kraus & Carver, Griffiths, and Hayt, as well as consulting with manufacturers of transformer and inductor core materials such as Philips magnetics, Arnold Engr., and Magnetics Inc.
yungman
5,718
241
Is there a difference in inductance of an inductance with magnetic material whether it is magnetized or not. Meaning is there an increase of inductance if the core has been magnetized ( become magnet) vs the same material but not magnetized?
Does magnetization increase the [itex]\mu[/itex] of the material?
Yes.
cabraham said:
Yes.
So the stronger the magnetization, the higher the [itex] \mu[/itex]? How much difference.
Is it true that if I have an inductor with a iron core. I can increase the inductance by putting a magnet near it to induce magnetism onto the core? And the stronger the induction, the higher the inductance.
Can someone point me to reading materials in this subject?
Thanks
Alan
Near the origin is "hard magnetization". As the winding current increases, the flux increases non-linearly since mu increases. Then mu is roughly constant as amp-turns increase & flux increases linearly. This region is "easy magnetization". Then as the saturation flux density value is approached, mu decreases. THe curve, known as the "B-H loop" is non-linear.
For reading materials, any good e/m fields text is recommended. Kraus & Carver, Griffiths, Hayt, are 3 that come to mind, but there are others as well. Also, makers of xfmr & inductor core material like Philips magnetics, Arnold Engr., Magnetics Inc., are good resources. They know magnetic materials better than anybody. That should get you started.
Claude
Yes, there is a difference in inductance between an inductor with a magnetized core and one with a non-magnetized core. When a magnetic material is magnetized, it becomes more susceptible to the effects of magnetic fields, which can increase its permeability (\mu). This increase in permeability leads to a higher inductance in the inductor. Therefore, there is an increase in inductance when the core is magnetized compared to when it is not. This is because the magnetic field created by the current flowing through the inductor is able to penetrate the magnetized core more easily, resulting in a stronger and more concentrated magnetic field. So, while the material itself does not change, the magnetization of the core does affect its ability to store energy in the form of a magnetic field, thus impacting the inductance of the inductor.
1. What is inductance?
Inductance is the ability of a circuit or component to store energy in the form of a magnetic field when an electric current flows through it.
2. How is inductance affected by a magnetic material core?
A magnetic material core can increase the inductance of a circuit by providing a path for the magnetic field to flow through, thereby increasing the strength of the magnetic field.
3. What is the purpose of using a magnetic material core in inductors?
The main purpose of using a magnetic material core in inductors is to increase the inductance of the circuit, which can be beneficial in applications such as power supplies, filters, and transformers.
4. How does the permeability of a magnetic material affect inductance?
The permeability of a magnetic material is a measure of how easily a magnetic field can pass through it. A higher permeability means that the material can support a stronger magnetic field, which in turn can increase the inductance of the circuit.
5. What are some common types of magnetic material cores used in inductors?
Some common types of magnetic material cores used in inductors include iron, ferrite, and powdered iron. These materials have different levels of permeability and can be chosen based on the specific needs of the circuit.
  • Electromagnetism
  • Electromagnetism
