How are Differential Equations usually found in real world applications?
In summary, differential equations (DE's) are mathematical equations that describe the relationship between multiple simpler functions. They can come in various forms, including partial differential equations, integral equations, and difference equations. Solutions to DE's are typically expressed in terms of some function, and solving them can involve various methods, some of which are more complicated than others. DE's are commonly used in physics, including in problems related to oscillation, beam bending, heat transfer, fluid mechanics, and more. Often, basic relationships are discovered first, and then derivatives are used to create DE's that can describe real-world phenomena. There are also books available that focus on deriving DE's rather than just solving them, which is known as modeling DE's.
DrummingAtom
659
I just started learning about DE's and am impressed by how much information they contain. Are they usually just a relationship between several simpler functions?
For instance, a basic kinematic problem like v = at + vo seems quite hard to come up with experimentally but v = d/t would be easy. Thanks for any help.
Technically any derivative is a differential equation, just a trivial one.
For instance
d(f(x))/dx=f'(x)
since first derivatives can be treated as fractions,
d(f(x))=f'(x)dx
then integrating we get f(x)=int(f'(x)dx)
But obviously DE's can come in all shapes and forms and there are even such things as partial differential equations, integral equations, and difference equations which are very closely related to differential equations. But yes and no, any solution of a differential equation is in terms of some function. This is because your given an equation that is in terms of a function's derivatives and your asked to find the function which satisfies that equation. As I showed before sometimes it is simple algebra tricks and then integration. But for most higher order differential equations there are various methods and some of them are very complicated, while some are brute force methods such as series solutions, while still some methods are very elegant. In physics the first higher order equations that you will come across are usually oscillation. As for your last question the first equation v=at+v(0) is actually the solution of one of those trivial differential equations that I showed you before where v(0) is the initial velocity, then for constant acceleration a(t)=d(v(t))/dt=a implies that d(v(t))=adt and integrating we obtain that v(t)=at+C where C is the constant of integration and evaluating at 0 we have v(0)=0+C=C which implies that v(t)=at+v(0). You are very right though, they are an extremely elegant method to solving physical problems.
In a beam bending with a uniform load w, the displacement can be related to
EI d4v/dx4 +w = 0
and applying certain finite methods one can find the displacement (angular and linear) at some point in the beam.
heat transfer, fluid mechanics, physics, biology, chemistry, all types of applications ranging to describe heat diffusion to cell displacement on a substrate
... they are fun, powerful mathematics
I should have retitled this thread to "How are Differential Equations usually *discovered* in real world applications?"
Are basic relationships usually found first then the derivatives of those then applied to a differential equations? Or are the differential equations usually found first?
Thinking from an experimental standpoint it would seem that the basic relationships are found first then the complex part later. The reason I ask is because the examples in my book seem to suggest the D.E's are found easily. Then instead of coming up with the D.E.'s as exercises we just use them and solve them. By the way, are there any books that focus on deriving differential equations instead of just solving them? Would this be called modeling D.E.'s?
1. How are differential equations used in real world applications?
Differential equations are used to model and solve many real world problems in fields such as physics, chemistry, engineering, economics, and biology. They can be used to describe and predict the behavior of systems that change over time, such as population growth, chemical reactions, and electrical circuits.
2. What are some examples of real world problems that can be solved using differential equations?
Some examples of real world problems that can be solved using differential equations include the motion of objects under the influence of gravity, the spread of diseases in a population, and the flow of fluids through pipes or channels.
3. How are differential equations typically solved in real world applications?
Differential equations can be solved analytically by using mathematical techniques such as separation of variables, substitution, and integration. However, for more complex or nonlinear systems, numerical methods such as Euler's method or Runge-Kutta methods are often used. These methods involve breaking the problem down into smaller, more manageable steps and using a computer to approximate the solution.
4. What are the benefits of using differential equations in real world applications?
Differential equations allow us to make predictions and understand the behavior of complex systems over time. They also provide a framework for studying and analyzing real world problems in a quantitative manner. By using differential equations, we can gain insights into the underlying mechanisms that govern natural phenomena and make informed decisions based on these insights.
5. What are the challenges of using differential equations in real world applications?
One of the main challenges of using differential equations in real world applications is the complexity of the systems being studied. Many real world problems involve multiple variables and nonlinear relationships, which can make it difficult to find an exact analytical solution. Additionally, the accuracy and reliability of numerical methods can be affected by factors such as round-off errors and stability issues. It is important to carefully consider the assumptions and limitations of using differential equations in real world applications.
  • Differential Equations
  • Science and Math Textbooks
  • STEM Academic Advising
