- #36
Averagesupernova
- 1,217
Thank you sophie. I will take a little more time later too look at the links you have provided. I skimmed through them very quickly.
sophiecentaur said:Here are a few links on the subject of matching. Read what they are actually saying about the significance of transmitter / load matching and efficiency. They all agree with what I have been saying.
http://www.jaycar.co.uk/images_uploaded/impmatch.pdf
http://users.tpg.com.au/users/ldbutler/OutputLoadZ.htm
http://urgentcomm.com/test-amp-measurement-mag/maximum-power-transfer
Averagesupernova said:Thank you sophie. I will take a little more time later too look at the links you have provided. I skimmed through them very quickly.
sophiecentaur said:@the_emi_guy
Would you comment on that issue please and not on the nuts and bolts of matching networks?
the_emi_guy said:Here is what I am trying to get my arms around:
Assuming that the impedance that the amp want to see hanging on its output for optimum, high efficiency, performance is higher than its impedance as seen from outside looking in (these were assumed to be the same in my previous analysis).
For example an RF amp with 1ohm output impedance specified to drive 1Kohm load (not maximum power transfer but really efficient).
We need a matching network to make 50 ohm cable look like 1K load. Is it not possible to design this network to simultaneously provide 50 ohm backmatch?
Maybe not, that is what I am hung up on.
If you look at the Impedance, looking into a transmitting antenna, you will come across a resistive component (if not, then it is not radiating any power). That resistive component is referred to as Radiation Resistance. The Characteristic impedance of a 50Ω line is the ratio of Reactances, as is the impedance of free space, effectively. But, in both cases, the Energy transfer is due to where the energy goes and not to the characteristic impedance.Likewise, in free space, the ratio of the E to M field strengths represents an impedance of approximately 120*Pi ohms. That does not in any way represent a dissipation of power.
A 1 kW RF transmitter driving a matched line does not generate >= 1 kW internally.
Class C and D amplifiers can operate at efficiencies better than 80% into matched lines.
The transmitter output stage has an impedance transformer called a tank circuit. To cancel the inductive component of the wound transformer it has a parallel capacitor, adjustable for different frequencies.
The load line or V:I ratio of the amplifier's active element is transformed to the impedance of the transmission line by the tank.
A reflected signal returning from the output t'line is reverse transformed by the tank from a V:I ratio of 50 ohm in the t'line to the V:I ratio of the amplifier's active element, and so is not reflected.
Baluncore said:As this subject is fraught by the many devils in the details, any general statement in a non-mathematical language must be expected to fail under some interpretation.
In post #46 you asked only one question.Averagesupernova said:I just wish my questions would be answered.
My reply was;Averagesupernova said:I have a question for you baluncore. If zero output impedance is not applying to RF transmitters, then why are we not dissipating the same amount of power in the class C amplifier that drives the antenna system that we are radiating in the antenna?
Baluncore said:The load line of an active device can also be modulated by oscillating between two points on the line rather than operating on the linear middle part of the line. That is a difference between the class A,B and class C,D amplifiers. The tank circuit will be different for different class amplifiers. That is because the effective output impedance of class A and B will appear resistive while the output impedance of classes C and D will be a very low resistance in series with a reactive network that functions as a flywheel.
Class A is inefficient because it operates in the linear mode. It forms a simple model of an externally matched amplifier in which a significant proportion of the energy is wasted in the output of the active device. Class D is efficient because the switching is between a point with high voltage with very low current and a point of high current with very low voltage, neither of which dissipates high power in the output of the active device. The output impedance is effectively the ratio of the pulsed current average to the pulsed average voltage. The lack of in-phase voltage and current is consistent with the use of a reactive element to limit the output power.
I do not ignore it. I simply do not misapply it to concepts such as matching characteristic impedance.sophicentaur said:You can never ignore the maximum power theorem. It applies everywhere - with or without the detail.
It depends on the situation you are referring to. A fixed voltage power source, with unlimited current capability should never be matched to any load in any direction. I am talking about “matching both ways” along a signal path that has a limited RF energy available. The example I used was between two stages of an RF amplifier.sophicentaur said:I have very little argument with you except when you claim that matching both ways is possible to achieve with high efficiency. That just has to be wrong on basic, almost philosophical, grounds.
That statement includes nothing about the source impedance relative to the load impedance, which is what the whole of the MPT is about - so we can ignore it. Obviously, a lossless transformer is 100% efficient but it can't impose efficiency onto anything else.Baluncore said:I see no reason why “efficient matching both ways” must be philosophically impossible. Where two ports are coupled by a lossless transformer that has an appropriate ratio, and any reactive mismatch is neutralised with a conjugate reactance, then there can be no real loss, hence there must be high efficiency.
I'm sorry that you are blind to the distinction.Sophicentaur said:This nonsensical distinction between the two 'sorts of' Impedance doesn't help in any way. If you were really across this stuff you would see there is no such distinction.
Baluncore said:I'm sorry that you are blind to the distinction.
Matching what ? for high efficiency. Matching at one frequency or broadband ? One way or reciprocal matching ?sophiecentaur said:A reference to the meaning / relevance / possibility of matching for high efficiency and perfect termination , that you claim.
It has been quite clear to me that there has been a misunderstanding for some time. That is why I have been trying to isolate a simple situation where we can either clarify the misunderstanding or resolve the difference. You call it “disingenuous”, I call it reductionist.sophiecentaur said:I think you are being disingenuous here. I thought we were well aware of the difference of opinion.
I do claim points 1 and 3. I don't understand precisely what you mean by your point 2.sophiecentaur said:The root of the disagreement is that you seem to claim that a transmitter can be operated
1.) at high efficiency
2.) see the load as the same as the transmitter internal resistance
3.) present a perfect termination when looking back from the load.
The root of the disagreement is that you seem to claim that a transmitter can be operated 1.) at high efficiency 2.) see the load as the same as the transmitter internal resistance 3.) present a perfect termination when looking back from the load.
The three are not mutually compatible. A reciprocal match can only be achieved with 50% efficiency (as the MPT tells us)
The MPT can be derived in three lines andI don't think is in doubt.
sophiecentaur said:We could make this simpler if you replace matching network, feeder and antenna with a resistance R(L). You can replace the transmitter by an emf and a resistance R(T). We can assume you have eliminated all reactances. For maximum power transfer, R(L) = R(T). That will involve 50% Power loss. Take it from there.
I disagree.Averagesupernova said:No matter how you do it, if you have a reciprocal match you will lose the same power in the transmitter that you are dissipating in the load.
Baluncore said:Now I see what you mean.
By eliminating all reactance you can deny the existence of all switch mode power conversion.
That eliminates all the efficient class C and D amplifiers, along with all resonant converters.
I am left to use class A and B amplifiers which are inefficient because of the MPTT.
The reference I offer you is; Hamlet Act 1, scene 5. Shakespeare, W.
“There are more things in heaven and earth, Horatio, Than are dreamt of in your philosophy”.
Switching power supplies along with class C and D amplifiers, provide a way to avoid the MPTT by using a switched reactance.
Baluncore said:I disagree.
By taking the analytic path that you have, you are setting out to encounter the MPTT when it could be avoided.
Averagesupernova said:Baluncore, it doesn't matter if you have or have not eliminated a certain class of amplifier. If the Zout of an amplifier is 10 ohms, then you will have lost power in that 10 ohms as my math shows. Now, let's see your math.
