Is interstellar travel impossible due to kinetic energy magnitude?
In summary: This is where I'm stuck. What is the cutoff velocity for when the rocket starts to expend more fuel than it is receiving?
BitWiz
This has been bugging me. Several respected propulsion scientists at the 2008 Joint Propulsion Conference claimed that interstellar travel within a human lifetime was impossible. The KE of a rocket traveling at a significant fraction of c would be enormous via KE=0.5 * m * v^2 and that presumably, this KE would have to come from fuel.
Examples of KE often use a car to demonstrate that doubling the velocity quadruples the stopping distance. I get that, but though velocity is a goal in space travel, I would think acceleration is a more important energy management element in frictionless, gravity-free space.
Then there's the difference in how cars and rockets work:
A Chevy and a rocket are at a stop light. The light turns green . . .
The Chevy's engine cylinders fire at equidistant points along the road; fuel usage is proportional to distance.
The rocket is not connected to the road; fuel usage is proportional to time.
If it's fair to plug proportions into the acceleration equation (d / t^2), then I get Fuel is proportional to t^2 for the Chevy, and sqrt(d) for the rocket, i.e:
If we double the acceleration time, the Chevy needs four times the fuel, the rocket just twice the fuel.
If we quadruple the acceleration distance, the Chevy needs four times the fuel, the rocket just twice the fuel.
So my question is, is it fair to use Earth-observer-based KE to determine the fuel requirements for a rocket?
Thanks!
Chris
Science news on Phys.org
This is correct as a low-velocity approximation. But it ignores the constant of proportionality.
A efficiency of a rocket motor is zero at rest -- it is wasting all of its energy on the exhaust stream. It is 100% efficient when the vehicle velocity reaches the exhaust velocity. At this velocity the exhaust stream is at rest with respect to the road. Pushing on the exhaust stream is exactly as efficient as pushing on the road.
So that's the crossover point where it might start to make sense to use a rocket.
But there is a complication. In order to reach a vehicle velocity equal to the exhaust velocity you need to throw a significant fraction of the vehicles starting mass out the back as exhaust. If you run the motor continuously, the fraction you need to throw out the back is 1-1/e (where e is Euler's number, 2.718...). That's about 63% of your starting mass.
In order to get to twice exhaust velocity you need to throw the same fraction out again. Now you've thrown a total of 86% of your starting mass out the back.
If you want to get up to five times exhaust velocity you need to throw out all but 1/e5 of your starting mass. That's over 99% of your starting mass.
This motivates the Tsiolkovsky rocket equation (http://en.wikipedia.org/wiki/Tsiolkovsky_rocket_equation)
For any useful interstellar velocity using chemical propellants, you need an insane ratio of starting vehicle mass to payload mass.
Thanks for the reply, jbriggs.
I ignored "k" to simplify the issue. I presume that, since we're comparing one device that uses fuel at a linear rate over time vs one on a power curve, that there is probably no k constant of "fuel efficiency" between the Chevy and the rocket where the rocket won't eventually overtake the Chevy. Is that a fair assumption?
This is again where I'm confused. Let's say that I'm using an electric ion engine in space -- no gravity, no atmosphere, no friction. My linear mass accelerator is one meter long -- I will accelerate my propellant as single mass objects in single events for exactly one meter. The object is then ejected into space. There is no need for a nozzle.
Further, at whatever velocity I might perceive with respect to any another object, as far as my rocket is concerned, I am at rest between propulsive events. Floating inside my rocket, as far as I and my rocket engine can tell, I'm not moving.
I then turn on my rocket engine, and I pump a gigajoule into accelerating a single proton in my linear accelerator. Yes, this engine has great specific impulse. ;-) Is there really a difference in how much acceleration I can measure as a passenger on the rocket between one propulsion event and the next? Can't I use propellant at an arbitrary rate as long as I can pump energy into its acceleration?
;-) Agreed.
Chris
Don't forget that energy has mass. The energy equivalent of a proton at rest is about 1.5*10^{-10} joules. Sure, you can (in principle) accelerate a proton to a gigajoule, but your energy source is going to be quite a bit more massive.
You mean mass equivalent? Or are you saying that an energetic photon has mass?
It's my understanding that propellant mass is largely arbitrary if you have a way to pump arbitrary amounts of energy into the propellant. Is this correct?
Thanks for your reply!
Chris
I mean mass equivalent. A photon does not have mass. My point is that there is no way to practically achieve a specific impulse higher than that of antimatter+matter, which converts 100% of mass to radiation.
Even using anti matter as a rocket propellant, the fuel mass required to travel to the nearest star would be about 5.6 times the payload mass and require at least 9 Earth years [albeit much less for the passengers]. Of course, you need the same mass of propellant for a return voyage. And this ignores some rather nasty side effects from the matter-antimatter reaction chamber. It's clearly impractical by any technology we currently possess. I have this nagging suspicion any other intelligent life in the universe is similarly victimized by the laws of physics.
By "nasty side effects" are you referring to long term radiation poisoning?
Would you not also need to consider the energy needed to slow down at each end of the return trip? That would mean a further doubling of the overall energy requirement.
I think there are a couple of misconceptions.
First, we do not need to accelerate for the entire trip. We work to get up to a reasonable gamma, trading time for energy, and coast for most of the trip. That saves a lot of fuel, plus the fuel to accelerate that fuel. If we accelerate at about 1 g for a year of proper (passenger) time, I think we could make a γ=4. A 10 ly trip could be done in about five proper years.
Second, we ONLY care about proper time. Earthers are not in our thoughts or frame of reference. ;-)
Deceleration. You can refuel at the destination.
IMO, antimatter will never be a practical propulsion fuel for the same reasons nitroglycerine isn't a good automobile fuel. The only practical fuel is water. Fuse the hydrogen (and its byproducts) and use the oxygen as the propellant. It has the additional benefits of being stable, non-toxic, relatively abundant for refueling at the destination, and a good source of water and oxygen for passengers.
Agreed. And we'll never have a practical fusion source for space travel if we continue to rely on tritium, terawatt lasers, and 100-tonne capacitors to drive them, such as we are exploring at the National Ignition Facility. We need to develop methods of gamma ray capture for "clean" energy rather than energetic neutron capture which tears up everything (IMO).
Of course! ;-)
yeah. It could be a long time before we have fusion power stations here on earth. So it would likely be an even longer time before we could get a fusion power station which is nice enough to use as part of a spaceship. So I'm guessing the scientists talking at that conference were essentially discounting fusion technology, as being something too speculative.
We can have fusion power stations in <40 years, if it isn't killed off by politics.
Hi, Bruce,
No, they were saying that the KE of a ship traveling at even 10% c is so large that no amount of fuel of virtually any sort could supply enough energy to produce the KE to get a passenger, the fuel, and his container to Proxima in a human lifetime.
The issue seems to involve settled physics at such a fundamental level that I'm having trouble coaxing an alternative.
The problem -- if there is one -- may stem from an Earth-centrism, our perceptual difficulty in excluding ourselves from the frame. Earth has no business in this -- it is not necessary for acceleration -- and without Earth, velocity and KE are undefined. Only proper, *relative* velocity exists, integrated from proper acceleration measured over proper time on the ship. So is there such a thing as proper KE, even though we are the only object in the frame?
Externally, we can get just about any velocity (and KE) value we want by selecting the appropriate reference object. I DO care about my velocity with respect to my destination, but I do not care about the distance (irrespective of relativistic effects) required to decelerate, and distance is a fundamental unit dimension of, and argument for, the validity of KE in this issue.
Something is out of kilter (perhaps besides the author), but I don't want to just guess. Can you help?
Thanks!
Chris
The problem of interstellar travel, besides the long distance requiring long times, is the problem of how much propellant and the energy source. A designer needs to look at the Isp (specific impulse) and specific power (kW/kg).
One has to take the propellant and energy source with one, or utilize the solar wind or prevailing cosmic radiation. The solar wind and cosmic radiation are however tenuous.
In chemical or nuclear thermal rocket systems, with relatively low Isp, one fires a rocket (impulse) for some short period of time to get up to a limited velocity.
In the case of nuclear electric or antimatter systems, the thrust (low) is employed more or less continuously to achieve high velocity. At some velocity, one would coast, as is the case with short impulse propulsion. Near the destination, one has to turn around and decelerate.
The problem with Alcubierre drive is still the energy source. What energy density is required to warp space, and what would be the local pressure? Could any physical object survive intact?
BitWiz said:
Hi, Bruce,
I don't think that's what they were saying. More likely is that they were saying it was not possible with technology in the near-future. (thus excluding things like fusion generators which could fit nicely on a spaceship).
We should be able to work out an example. Using the (relativistic) Tsiolkovsky rocket equation (as jbriggs mentioned), if we have an exhaust velocity of c (which I guess would be the case if we were using matter & antimatter propulsion, or using some other propellant that we can somehow propel out the back of the spaceship at near light speed). Then to get our spaceship to a velocity of 10% speed of light, then we only need an amount of fuel of mass roughly 10% of the mass of the payload. (the fact that both fractions are the same is a coincidence, by the way). So anyway, this would be a very ideal rocket. But the point is that it is definitely possible, if we had the right kind of technology.
Well, I think it is true that the KE of the spaceship would be so large, that current technology cannot provide enough energy. I think that is what they meant. But I'm guessing too. I wasn't at this conference. Although it does sound like an interesting one :)
p.s. no, there is no such thing as proper KE. But the KE of the rocket, according to the Earth is an important quantity, because the rocket initially has the same velocity as the earth, this means the KE of the rocket according to the Earth was initially zero. That is why the KE of the rocket, according to Earth is an important quantity.
p.p.s. also, we must assume the Earth represents an inertial reference frame, which it doesn't really, because it is in orbit around the sun. So really, we should talk about the KE of the rocket according to the sun. (Which is more or less an inertial reference frame, since our rocket will not be going across the galaxy, it is only going to the nearest star)
I suspect the way we will travel to the stars (and I firmly believe we will) is to drop the "in a human lifetime" constraint. Large, self-sufficient colony ships with 1000's of inhabitants that travel at ~1% of the speed of light and require 100's of years to travel between stars appear quite feasible.
Why would anyone fund a project like this?
1. It would be totally altruistic - in favour of the travellers and at the expense of 'the rest of us'.
2. Governments have difficulty thinking much further ahead than the time of the next election. A project like this would take decades or even hundreds of years.
I didn't say it was going to happen any time soon. A project like this is probably centuries to millennia in the future. As we progress as a species, especially as we move off of the Earth and out into the solar system, we can expect economic growth to continue, so that the resources required could be within reach of a large group of people. Why did people fund the Mayflower? Why is there a group planning on colonizing Mars? What is the alternative? Huddle here on the Earth until the sun swells up and incinerates us all?
The complaints were based on a combination of tech and energy -- but "never" is a long time to discount tech advances. There are summary references to the 2008 AIAA conference that can be extracted with Google. One source for the gritty details is here (http://arc.aiaa.org/doi/abs/10.2514/6.2008-5121), but not for the faint of heart. A good article appeared in Wired on 8/19/08, but is no longer accessible online (though Google still finds it -- go figure).
If our propellant has mass, I think we can (theoretically) pump energy into it up to the limits of our supply and tech, even if it's a single proton, and still get an "equal but opposite" reaction. The proton would gain mass as we push it closer to c, and I'm not sure that relativistic Tsiolkovsky takes this into account.
I made a point of stating that the propulsion system accelerated propellant over a distance of a single meter to simplify the KE of the propellant. "Distance" is a variable relativistically, and I would think a propellant cranked up to a high gamma will see a correspondingly shortened path through the accelerating field. You mentioned later that there is no "proper KE," but I wonder if our accelerated proton would agree with its KE measurement by a shipboard observer, not to mention an Earth-based observer.
As you can imagine, it created quite a stir in the SciFi community. Suddenly, every outer space opera had the scientific validity of "second star on right, and straight on till morning," regardless of the sincerity of the author.
I suspect KE is important for concepts such as storing potential energy in Earth's gravitational field, but once we're beyond the overwhelming magnitude of a nearby field, aren't we storing and harvesting potential energy in the gravitational fields of every mass object in the Universe? When we're several parsecs from Sol, why do we care about our KE with respect to Sol? ;-)
Thanks very much for your reply, Bruce!
Chris
I know people have a romantic notion about space travel and the parallel is often quoted with early exploration on Earth. However, the big difference is that exploration has always been done incrementally and there is no essential difference between sailing across an ocean (particularly if you island hop) and sailing along the coast. The Pilgrim Fathers were going nowhere that hadn't been visited before. Also, they funded themselves and were ripped off by the people they bought their ships from.
You make the assumption that we will "progress as a species". Civilisations tend to have a cycle of development - this is what History tells us. I think it is naive to imagine it will be different for our current culture. We are on a knife edge all the time. The simplest microbe could bring the present 'civilisation' down on its knees, as could a visit from an asteroid or just some loony group of extremists. If you are talking big numbers for developing advanced technologies then you also have to talk big numbers for the arrival of catastrophe.
As far as the Earth is concerned, this is of no consequence. Just a few viable surviving organisms is all that's needed for a civilisation to appear again. I do not regard that as a failure - it's just something we can expect to happen to humankind, eventually.
Btw, the group is not seriously planning to colonise Mars. The best they can hope for is to survive for a while and then come back in one piece. (What kind of an eejit can say he'd like to die on Mars?) I think it's a shame they can't direct their finances to some humanitarian project that would be better value and is more likely to succeed. The project isn't Science - it's a self-indulgent exercise by people who can afford it.
It does take that into account. That's why it's called the relativistic Tsiolkovsky equation :) If you think about it intuitively, the rest mass of the fuel you carry on board only needs to be very small, to give a huge amount of momentum to the spaceship, as long as you expel the propellant at close to the speed of light. Of course, the problem is that our technology is most likely not able to do such a thing. But this comes back to the statement that our technology is not nearly advanced enough to allow for interstellar space travel. This is different than the statement that it is not possible even in principle.
I'm not sure what you mean here. For sure, there is no absolute KE. The kinetic energy for an object with non-zero rest mass is simply ##m_0(\gamma -1)## So this is certainly dependent on the frame of reference which we use to describe the KE of the object, since gamma is for sure dependent on the frame of reference.
Chris
yeah, thanks for making this thread :) Uh, the KE with respect to sun is important because the sun is effectively the inertial reference frame that the spaceship initially has zero velocity according to. (I'm completely ignoring any gravitational fields, by the way). So, I'm assuming that we can get the rocket out of the gravitational field of the sun, then from there we have a rocket whose velocity is approximately zero according to the reference frame of the sun, and from there we can use the Tsiolkovsky rocket equation to work out how much fuel we need to make the journey. Also, I'm assuming there is zero effect from the gravitational fields of other objects, which should be approximately true. Unless we slingshot the spaceship past Jupiter, or do something similar, then this will mean we need to carry even less fuel than in the calculation I did before.
I suspect the people on this project do seriously intend to colonize Mars. Perhaps not on the first try, but eventually. We all die eventually; why do you think dying on Earth is better than dying on Mars? I think that if I died on Mars feeling that I had helped mankind spread off of the Earth out into the solar system, I would consider it a life well lived.
I can understand the romance of such an idea - at first sight. But there is not the remotest similarity between traveling to another planet and the 'wild frontier' on Earth. People tend to confuse the two.
How many generations of Curiosity could one premature human trip pay for? Sending people is little more than a vanity project. Now - if there were a military interest involved, that would change everything.
I think we will have to disagree about this. The practicalities of it all are highly interesting though.
I like romantic ideas. But maybe money could be better used to fight poverty. But again, economics is not a zero sum game, so I think maybe it is not so simple. Also, space research can help technology.
edit: In either case, interstellar travel for humans is not practically possible in the near future. Or at least, that seems to be the case to me. I don't really know much about this stuff.
Particularly military technology. That was the driving reason for the Moon landings.
Do you mean the reason for the moon landings was to create technology to be used by the military? Or that the moon landings were a military objective? I had thought the main reason was a "mine is bigger than yours" competition between the US and USSR, without really being military. I mean, nuclear weapons were (and are) the main threat. And the moon landings didn't change that, right?
edit: whoops, I mean soviet union.
In the late fifties / early sixties, the idea of 'the other side' having a military Moon base was, I am convinced, what drove the US (and Soviets) to spend all that money and effort on the Space project. The US spent (could afford to spend) more and got there. In those days, a Moon base was perceived as a perfect platform to mount a Nuclear attack. With the computers of the day, you needed people 'up there' to do clever stuff. The perception of the possible advantage of a military Moon base was certainly flawed in many ways but it certainly helped with the funding. (That and JFK's charismatic speeches.)
Things may have changed, once the Soviets were seen not to be serious contenders and Momentum carried the Moon program further into the Science realm. So, perhaps less of a military consideration later on.
The only possible military incentive for a Mars Base (/colonisation) would be the 'end of the world' scenario in which the Earth was rendered unliveable and a favoured few could escape and live for a few generations on Mars.
I'm afraid we're jawing away, off-topic, again. :redface:
Prestige is a proxy for military power, and is a lot less costly in treasure and lives.
Agreed, I often get annoyed at this comparison. The thing is about space is that there isn't any destination remotely analogous to on on Earth. Here there's a free biosphere to keep us supplied with everything we need from food to a microbiome. The first European settlers to the Americas might have had a hard crossing on the ocean but when they got there they had plenty of natural resources to untilise.
Furthermore people underestimate how many people are needed to sustain a high tech economy. When you live in wooden houses and most of what you need can be built by a blacksmith or carpenter all you need is a few hundred, perhaps less, people to maintain a healthy society. Filling all the specialised roles of a modern economy would take far more, potentially hundreds of thousands of people. If we were ever to build a self sufficient colony somewhere not on Earth not only would we have to make massive advances in ecosystem design and maintainence as well as mass manned space travel but we'd need to find a way to transport thousands upon thousands of people as well as supply them with a small industrial city's worth of infrastructure. The rugged Wild West it is not, Hong Kong in space maybe.
  • #31
I agree with most of what you said here. "Hong Kong in space" is a good way to think of it. However, just because it will be difficult doesn't mean that it will forever be impossible. As I said earlier, assuming economic growth continues (and there's no reason to assume that it will not), then the resources to build a colony on Mars or out in space will be relatively accessible in another century or so. Note that a colony in space (not necessarily on a planet) need not be self-sufficient from the very beginning. It would be perfectly acceptable to be dependent on resources from Earth for a period of time, even a long period of time, while the infrastructure in space grew.
  • #32
Hi, Bruce,
This is a very neat conversation.
I don't think we care about propellant mass, per se. What we care about is the amount of force we can apply to whatever propellant mass we have, even if it's a single proton. Theoretically (I think), we can pump unlimited KE into a proton, and as it approaches the speed of light, its effective mass will increase to allow us to keep pumping it in. This is where specific impulse (and Tsiolkovsky) go off the rails, imo, because the effective propellant mass is variable, and we're not using the propellant as a reactant.[/QUOTE]
I think it was a statement in principal. I believe it takes about a petajoule to accelerate a kg to 10% c at 50% efficiency using Earth-frame KE as the standard. That's doable if several percent of the original kg is antimatter, but fusion is out. There are two problems: 1) antimatter is never going to be feasible, imo, not least due to the lack of antimatter filling stations in the galaxy; and 2), 10% c does not cut it. Much, much too slow.
I think "distance" is an overemphasized dimension in our units of measure regarding space travel. Doesn't distance vary depending on the closing or opening velocity between an observer and any object?
As for using one-meter to accelerate propellant, that just simplifies the KE discussion by assigning "1" to the numerator of propellant velocity.
I think I get that. What I don't get is why in gravity free space my KE goes up in a power curve while my fuel use is linear. I guess that goes back to my original question. Why does my rocket need three times the energy to double its speed?
  • #33
Unlimited KE is not free. It has to come from somewhere. If it comes from carried fuel then it has mass and Tsiolkovsky applies. If it comes from the outside then it carries momentum and you might as well use the momentum directly.
Irrelevant if we're talking about the requirement to maintain a particular proper acceleration for a given period of time using on-board fuel and reaction mass.
Velocity is relative. What does it even mean to double speed? Where did you decide that it takes three times the energy to do so. Three times what energy?
  • #34
Hi, jbriggs, thanks for the reply.
If we can, I'd like to separate the source of the energy from the propulsion mechanism to help me understand this.
With classic Tsioilkovsky, delta-v is based in part on the difference in mass before and after the burn. In the example where I accelerated a single proton as the propellant, these masses are effectively the same such that
ln Mbefore/Mafter
is close to zero, which requires the specific impulse (Isp) to be huge. That's fine, but Isp, is based on exhaust velocity, and in relativistic Tsiolkovsky, I think Isp = effective velocity = actual exhaust velocity in a vacuum.
Since effective velocity is capped < c, we can never get to this Isp unless we allow the mass of the propellant to grow. I don't see this term in relativistic Tsiolkovsky. I presume I'm missing something very important, I just don't know what it is.
Agreed. That's why I'm having trouble with rocket KE measured from Earth. A rocket is an independent object in its own frame as soon as its acceleration overcomes gravity, imo, and its KE is undefined. It's KE would be exhibited in a collision with Earth, but then it would no longer be independent.
The "three times" has to do with a mass having four times the KE at 2 m/s than at 1 m/s. If I've already accelerated from at-rest to 1 m/s, then I will have to add triple the amount of energy expended so far to get to 2 m/s. At least according to KE.
Thanks for your help! ;-)
Chris
  • #35
Frames of reference are not physical. They are notional. You can use whatever frame of reference you like. But if you want it to be inertial, you need to be consistent. Having picked one you need to keep using it. Or transform out of it.
You do not enter or leave a frame of reference because your "acceleration overcomes gravity".
The original problem here involved interstellar travel. It would be "cheating" to adopt a frame of reference in which a spacecraft starts at rest while two stars whip past at speeds barely below the speed of light (and with a coordinate separation that is very small) and then claim to have solved the problem of interstellar travel. Adopting a frame of reference in which the Earth is at rest is a reasonable starting point.
But that has nothing to do with rocket propulsion.
For propulsion of a car on the highway using the Earth as its reaction mass, if it takes x energy to get from 0 m/s to 1 m/s then it takes 4x energy to get from 0 ms to 2 ms.
For propulsion of a rocket ship at non-relativistic speeds, if it takes mass ratio 1/x to get from 0 m/s to 1 m/s then it takes mass ratio 1/x2 to get from 0 m/s to 2 m/s
The difference in the two scenarios involves the energy being pumped into the exhaust stream. If your "exhaust stream" is the planet Earth and you are accelerating a Chevy to 1 m/s, you can ignore the energy being imparted to the Earth -- it's negligible.
If your exhaust stream is produced by a solid-fueled rocket motor and you are accelerating the same Chevy, the energy being imparted to the exhaust stream is quite significant.
There is no point invoking relativistic complications until this much is understood.
Likes 1 person
  • Science Fiction and Fantasy Media
  • Other Physics Topics
12K
