A high schooler looking for some complicated physics problems
In summary, the two candles leaning in opposite directions indicate that the merry go round is not a magnet.
Bassir
24
I'm in high school and am very frustrated by how easy "physics" is. I really enjoy the subject but feel it's watered down in my school, and apparently my state.
I would like to do some more complicated problems that only cover intro to physics, but are very complicated in that you need to actually think.
I'm bored with physics in my school. My calculus is not good enough yet to do complicated calculus, so I can't do that.
I want to challenge myself.
If [tex]x=2sin(9t)[/tex] expresses a mass on a spring in simple harmonic motion, what is its maximum velocity?
Not exactly difficult, but it requires some thought.
Are there any books with physics thought problems?
I need problems that challenge my logic, not my ability to plug and chug. Your problem is good.
I hear about SHCAUM's 3,000 Physics problems, but I don't want to waste money on something that isn't very challenging.
have you checked out Jearl Walker's "Flying Circus of Physics"?
Here is an interesting problem.
Consider a point A in space at x1, y1, and another lower point B at x2, y2 (not directly below the upper point). A bead slides on a stiff frictionless wire between the two points. Find the shape (curve) of the wire such that the transit time from a bead released at point A to point B is a minimum. Note: The shortest distance (direct line) is not the quickest. If you want specific numbers; use y1-y2 = 1 meter, and x2 - x1 = 1 meter.
Bob S
Try this
The bicycle is on a rough surface and is being gently supported so that it doesn't fall over sideways. It is a standard pedal bicycle.
You tie a string to the pedal as shown and pull horizontally.
In which direction does the cycle move?
Go to Amazon and search “Schaum’s Physics” and have your folks buy you a book. I have the “3000 Solved Problems..” and find it invaluable. They work from simple to hard in each category and solutions to all problems are given so you can learn if you get stumped. (Note – you need to cover the solutions as you work through the problems.)
The only thing I don’t like about the book is the problems assume you’ve mastered what’s come before. I like to skip around, so that’s kind of a pain, but you’ll probably be sticking to the first chapters so you should be ok.
Good luck!
-David
Try this. You have a wheel of radius (r) with a mark on the rim that is in contact with another mark on the road. The wheel is rolled forward by less than half a turn (theta degrees) so that the distance the base of the wheel moves along the road is x= 2*Pi*r*(theta/360). What is the vertical and horizontal distance that the mark on the rim of the wheel moves by?
Warning. Despite its simple appearance this is a very difficult problem.
Go to a bookstore and thumb through it. If you can knock out all 3,000 problems "plugging and chugging" you're ready to start your masters thesis in physics!
-David
Are they all 3000 problems a good difficulty or do I have to weed out the easy ones to get to the hard ones?
your in a room with 2 iron bars , one is a magnet and the other is not ,
how do u tell which one is the magnet , you can only use the two iron bars to tell which one is the magnet.
another one , i light 2 candles one candle on each end of the merry go round then i put a glass chimney around the candles to protect the flame from getting blown out when it goes around . but they are still open to the top
and i spin the merry go round , which way do they candle flames lean , or do they lean at all .
do they lean out , lean in , fall behind , angle back at a diagonal . lean forward .
The vertical distance is r-rcos(theta) and the horizontal distance is
2*pi*r(theta/360) - rsin(theta)
Bob S
Could you provide the answer to that? According to my calculation, the shortest distance is the quickest
Nah, I'm pretty sure the quickest is somewhere below the straight line. You want to gain speed first, so initially you go down with higher slope.
But I'm to lazy to [STRIKE]google it[/STRIKE] derive it. ;)
Consider concrete block lying on the surface, mass m, friction coefficient f. What is the minimum force required to pull it from the place. Assume Earth surface (that is, g).
I got it at 35.26° to the vertical
Bob S
Bob S didn't explicitly say this, but there's gravity present.
Google brachistochrone.
Good for Borek. This deceivingly simple classical mechanics problem is actually a very challenging one. It is not a "plug and chug" problem. The straight-line transit time (y=1-x) is t=sqrt(4/g), but y=(1-x)2.5 is shorter. But is it the shortest? What about
y=1-sin(pi*x/2)?
Isaac Newton was challenged to solve this minimum-transit-time problem ~1697, and rumor has it that in one day he found a unique solution (inverted cycloid) which he proved was the shortest transit-time solution, using calculus of variations. Newton "invented" calculus of variations.
Fermat's Law of minimum transit time in optics is eerily similar to this one. Is there a connection?
Bob S
After seeing how vin is struggling I decided to push him in a right direction.
I know what you mean. I suggest you go find a couple sets of college freshman physics books and dig in. Usually they have quite a few thoughtful problems at the end of each chapter. They also start out assuming that you know nothing of calculus and are learning it concurrently. Get a head start on college. I did. You are planning on studying science in college, right?
Here are the examination problems of last year's IPhO. They require some physics beyond high school. Dig in. :)
http://ipho2009.smf.mx/home
You can take a look at the GRE physics, and just skip the physics you haven't learned yet. Do all the mechanics questions...imo they are quite difficult (at least I usually fail at doing them XD).
I have a book by Mir publishers ,Moscow in english in djvu format.
"Problems in general physics" by I.E.Irodov . PM me . I can send it by email.
The book has really challenging problems as well as easy ones.
If you want to challenge your brain, try to find ingenious ways of violating the 2nd law of thermodynamics. Design devices then prove to yourself why they don't work. Then design another one, this time better and trickier so that you have to think harder before you see why it won't work.
After doing this you'll learn a lot about the 2nd law, unlike most kids who just memorize it.
I do this a lot myself although involuntarily.
An airplane is standing on a conveyor/ treadmill which always exactly matches the airplane's speed, but in the opposite direction. Can the plane take off?
Hope I don't get banned for this...
LOL
or tell him about the downwind vehicles.
1. What are some examples of complicated physics problems for high school students?
Some examples of complicated physics problems for high school students may include: projectile motion, rotational dynamics, thermodynamics, electromagnetic induction, and quantum mechanics.
2. How can I find resources to help me solve complicated physics problems?
There are many online resources available such as textbooks, practice problems, and video tutorials that can help you solve complicated physics problems. You can also seek help from your physics teacher or join a study group with fellow students.
3. What is the best approach to solving complicated physics problems?
The best approach to solving complicated physics problems is to break them down into smaller, more manageable parts. Start by identifying the key concepts and equations involved, and then apply them step-by-step to solve the problem. It is also important to draw diagrams and write out all given information to help visualize the problem.
4. Are there any tips for understanding and solving complicated physics problems?
Some tips for understanding and solving complicated physics problems include practicing regularly, reviewing fundamental concepts, and seeking help when needed. It can also be helpful to work through problems with a partner or in a group to discuss different approaches and solutions.
5. How can I challenge myself with more complicated physics problems?
You can challenge yourself with more complicated physics problems by seeking out additional resources, such as advanced textbooks or online courses. You can also try solving problems from past physics competitions or create your own problems by applying physics concepts to real-life situations.
  • STEM Academic Advising
  • Other Physics Topics
  • New Member Introductions
