Finding the Area Inside Four Tangents for a Cubic Function | Step-by-Step Guide
  • Thread starter jahaddow
  • Tags
    Area
In summary, the conversation is about finding the area inside of four tangents that form a parallelogram using a cubic function and four tangent lines. The suggested methods are to solve the equations to find the points of intersection and lengths of the lines, or to split the area into two triangles and calculate it.
jahaddow
47
Ok, I have a cubic function, y=(x-6)(x-1)(x-9) or y = x3-16x2+69x-54
I then have four tangents to make a quadrilateral, the tangents are as follows.
y=7.75x+14.75
y=-6.25x+56.25
y=7.75x + -76.231
y=-6.25x + 31.602
I need to find the area inside the tangents, except I have no idea where to start, Thankyou for any help in advance.
y=7.75x+14.75
y=-6.25x+56.25
y=7.75x + -76.231
y=-6.25x + 31.602
Start by sketching the lines. What do you notice about these pairs of lines:
y=7.75x+14.75 & y=7.75x + -76.231
y=-6.25x+56.25 & y=-6.25x + 31.602
What sort of quadrilateral figure is formed?
A Parallelogram, But I don't see how I can get the area from the equations?
You can find where the lines intersect one another and thus find the coordinates of the corners. You can then find the lengths of the lines. Split the area into two triangles and find the areas.
So, How do I do that?
Solve each pair of equations to get the points of intersection. Find the lengths of the lines and then find the area of the shape.
Or you could split the area into two triangles and calculate it.
1. What is the formula for finding the area inside four tangents?
The formula for finding the area inside four tangents is A = 2r2, where r is the radius of the circle.
2. How do you determine the radius of the circle when given four tangents?
To determine the radius of the circle, you can use the formula r = √(a2 + b2 + c2 + d2) / 4, where a, b, c, and d are the lengths of the four tangents.
3. Can the area inside four tangents be negative?
No, the area inside four tangents cannot be negative. This is because area is a measure of the space occupied by a shape, and it cannot have a negative value.
4. What is the significance of the area inside four tangents in geometry?
The area inside four tangents is used in geometry to find the area of a circle when given four tangents. It is also used in various geometric constructions and proofs.
5. Is there a relationship between the area inside four tangents and the circumference of the circle?
Yes, there is a relationship between the area inside four tangents and the circumference of the circle. The circumference of a circle is equal to 2πr, which is also equal to the perimeter of the shape formed by the four tangents. This shape has the area of 2r2, which is the same as the area inside four tangents.
26K
