How to edit fields in explorer
In summary: Yes. Its visible/editable in several other (windows) types as well... but not pdf. My guess is that they are just sore about microsoft word losing popularity.
AndyUrquijo
Hi everyone,
I own a pc with Windows 7 and I need help to organize my files, specially the folders with articles and books. What I want to do is to edit the ‘author’ field. This way I can search books by this parameter if they have common names such as "Quantum Mechanics Vol I"
I could do this with Windows XP before so I hope it’s still possible here. If you can’t do this with the explorer’s options, is there any property editor available on the web?
Computer science news on Phys.org
Do you actually want to edit the author field, or just select files based on the value in the author field?
You can display only the files authored by a particular person in Win 7. In Windows Explorer, at the upper right corner there is a control titled Arrange by. This control has a drop-down menu with Author, Date modified, and other menu options. Click Author to arrange the files by their author. You can choose one or more authors whose files should be displayed.
As far as actually editing the author for a file, I don't believe you can do that in Win Explorer, and I don't think you could do it in Win XP, either.
I want to edit the author field.
This was possible! Actually in win7 you can still do this easily with multimedia files. In the properties dialog there is an aditional set of editable properties such as interpeter, genre etc.
Well any editable property would be fine actually. I wouldn't mind having a file with extension '.D_Griffiths'. But this is not possible in windows :(
Borg said:
Have you tried this?
I have. It seems pdf files don't have any editable properties. Which is stupid... way to go windows!
I'm using XP and there is an editable author field for pdf files. I don't know if it's been stripped off in Windows 7 but, it doesn't make sense that they would take that away. Can you see the author field on doc files?
Yes. Its visible/editable in several other (windows) types as well... but not pdf. My guess is that they are just sore about microsoft word losing popularity. So they create compatibility issues with non-windows formats (they did it even to their own older formats).
1. How do I edit fields in explorer?
To edit fields in explorer, right-click on the field you want to edit and select "Properties" from the drop-down menu. From there, you can make any necessary changes to the field.
2. Can I edit multiple fields at once in explorer?
Yes, you can edit multiple fields at once in explorer by selecting all of the fields you want to edit and then right-clicking and selecting "Properties". This will allow you to make changes to all selected fields simultaneously.
3. How do I add new fields in explorer?
To add new fields in explorer, right-click on the folder or file you want to add the field to and select "Properties". Then, click on the "Custom" tab and click "Add". You can then enter the name and value for the new field.
4. How do I remove fields in explorer?
To remove fields in explorer, right-click on the field you want to remove and select "Properties". Then, click on the "Custom" tab and click "Remove". This will remove the field from the file or folder.
5. Can I customize the fields that are displayed in explorer?
Yes, you can customize the fields that are displayed in explorer by right-clicking on any field and selecting "Customize Columns". From there, you can select the fields you want to display and rearrange them in the order you prefer.
  • Computing and Technology
  • STEM Academic Advising
  • Beyond the Standard Models
