About uniform continuity and derivative
In summary, uniform continuity and derivative are two essential concepts in calculus. Uniform continuity refers to the property of a function where small changes in the input result in small changes in the output, regardless of the location of the input. This means that the function has a consistent rate of change throughout its domain. On the other hand, the derivative of a function is a measure of its instantaneous rate of change at a specific point. It is represented by the slope of the tangent line to the graph of the function at that point. Together, these concepts help us understand the behavior and characteristics of functions, making them crucial in calculus and other areas of mathematics.
A Dhingra
211
hello
(pardon me if this is a lame question, but i got to still ask)
If a function is uniformly continuous (on a given interval) then is it required for the derivative of the function to be continuous?
I was thinking as per the definition of Uniform continuity, f(x) should be as close to f(y) as possible, for x around y, meaning change in f should not be sudden at some point within the interval; it should rise or fall in a uniform manner, suggesting the slope of the function at different points should change gradually and be real always (i.e. never infinite), that implies the derivative should be continuous in the open interval. So if we have a function whose derivative is continuous then can we say it is uniformly continuous on the closed interval?
(I must mention i won't be able to understand very rigorous proofs, so if possible explain this either by counter example, if any, or geometrically. )
thank you..
Consider f: [-1,1]->R, f(x)=x^2 sin(1/x) for x!=0, f(0)=0
A uniformly continuous function may not have a derivative at some points. If your mean to assume the derivative exists everywhere, you should state this.
So in the interval [-1,1] function f(x) is continuous.
And its uniform continuity can be easily seen on [-1, 1]
The derivative of the function is =(1/x)( 2x^2 sin(1/x)- x cos(1/x))
at x=0, it is -cos(1/x) = not defined could be any value between [-1,1]
So??
stephen, the above example states what you said...
Okay if i talk about the converse, i.e. if a function has derivative over the interval then the function is uniformly continuous, is this right??
The derivative of the function I posted is well-defined at x=0 (it is 0). The approach you tried does not work at x=0.
To say "the interval" is not specific. Do you mean an open interval? a closed interval?
To follow up on Stephen, differentiability implies continuity; continuity in a compact subset implies...
Should be closed interval...
"To follow up on Stephen, differentiability implies continuity; continuity in a compact subset implies... "
Does this imply uniform continuity? if the differentiation of function f(x) is g(x), is also continuous ...
Yes, a function that is differentiable everywhere on a closed interval is uniformly continuous on that interval.
What are you asking? If f(x) is differentiable at x and g(x) = f'(x) then g(x) itself need not be continuous at x.
Take, for example, f(x)=|x|; it is not differentiable at 0 . Find its integral ( it is continuous, so the indefinite integral exists ) , and use the FTCalculus:
f(x) = -x^2/2 , if x<0
f(0) =0
f(x) =x^2/2
Now, f is continuous, and, in a compact interval, it is uniformly continuous, and f'(x)=|x|.
To folllow up on mfb's point, the derivative at 0 should be:
Lim_h->0 f(h)/h .
(Sorry, mfb, don't mean to speakfor you, just thought you may be away for a while)
any continuous function on a compact set - such as a closed interval - is uniformly continuous. But such a function need not be differentiable anywhere.
If the function is continuously differentiable the its derivative is uniformly continuous on a compact set.
Actually, take a function with countably-many points of discontinuity, e.g., the Dirichlet function. Then its Riemann integral exists, since functions only need tobe a.e. continuous in order to be Riemann integrable. Now,consider the integral of the Dirichlet function over a compact set . It is uniformly continuous, and its derivative ( by the FTCalc) has countably-infinite many points of discontinuity.
EDIT: Please see my corrections below, in #16.
Isn't the integral of the Dirichlet function simply the constant zero function?
Anyway, there can never exist a function whose derivative is the Dirichlet function. The reason is that derivatives always need to satisfy the intermediate value property. This is Darboux's theorem: http://en.wikipedia.org/wiki/Darboux's_theorem_(analysis) . However, the Dirichlet function does not satisfy the intermediate value property.
take a sample path from a continuous Brownian motion on a closed interval. It is uniformly continuous
and is nowhere differentiable.
My bad; I meant the Thomae function; the Dirichlet function is nowhere-continuous , so it cannot be Riemann integrable. Of course, you want to exclude cases like a function being a.e. 0 , like the Cantor function; the condition is absolute continuity,which allows you to recover the function from integration
EDIT: I keep mixing functions in my head; please see my post after this one.
Yes, I was talking about the Thomae function as well (for some reason, I always called that the Dirichlet function, but now I see that it is something different). The same remarks hold.
EDIT: Well, yes, it is a.e. 0 ; just take copies/iterates of |x| in a closed interval. So it is covered (modulo my mistake) in my previous post,where I excluded functions that are a.e. 0, but mistakenly mentioned Thomae. So I think the Darboux Thm is overkill here; I think it is obvious issue that being a.e. 0 means the integral is 0, so that you cannot recover the original function, and absolute continuity.
Does every one agree to this?
If yes...I think i got the answer.
(don't mind but i don't want to get into reimann integral and those functions again, i had them last semester )
That can be proven, we don't need votes ;).
Note that "If the function is continuously differentiable" is a requirement you did not have in the first post.
It is the basic same corollary : if f is continuously-differentiable , then f' is continuous (tautologically, i.e., by definition), and continuity in compact is uniform continuity, then f' is uniformly continuous.
alright thanks.
I think a function that is continuous except on the Cantor set is Riemann integrable.
What is uniform continuity?
Uniform continuity is a mathematical concept that describes the behavior of a function over a specific domain. A function is considered uniformly continuous if, for any two points in the domain, the difference in the output values is always less than a certain value, regardless of how close the input values are to each other.
What is the difference between uniform continuity and regular continuity?
The main difference between uniform continuity and regular continuity is that uniform continuity requires the difference between output values to be consistently small for all input values, while regular continuity only requires the difference to be small for points that are close to each other.
Why is uniform continuity important?
Uniform continuity is important because it guarantees that a function will behave predictably over its entire domain. This is especially useful in applications where small changes in input values should result in small changes in output values.
How is uniform continuity related to differentiability?
Uniform continuity and differentiability are closely related concepts. If a function is uniformly continuous, it is also differentiable. However, the converse is not always true - a differentiable function is not necessarily uniformly continuous.
How can uniform continuity be tested?
There are a few different ways to test for uniform continuity, including using the definition of uniform continuity, the Cauchy criterion, or the Heine-Cantor theorem. Additionally, some functions are known to be uniformly continuous by their nature, such as polynomials and trigonometric functions.
  • Calculus
  • Calculus
