- #36
Nirav Chavda
- 22
Doc Al said:How do you start moving with zero acceleration?
brother .. you've got an excellent point there but I'm still uncontent. i'll try get to the main core just wait..
Nirav Chavda said:the simple answer to this was that the body will accelerate down due to some smallest inevitable disturbance(at quantum level) and this would change the Static F. to kinetic F. which is lesser. and so new net force acting downwards will be produced resulting in downward motion.
The repose angle is the maximum angle at which a material can be piled without collapsing due to gravity.
The repose angle is the angle at which the material is in equilibrium with gravity. This means that the weight of the material is evenly distributed and there is no force acting to make it float.
The repose angle is determined by the physical properties of the material, such as its density, shape, and surface roughness. It can also be affected by external factors like moisture and vibration.
Yes, the repose angle can change depending on the conditions of the material. For example, wet or loose materials may have a lower repose angle compared to dry or compacted materials.
The repose angle is important in industries such as mining, construction, and agriculture as it helps determine the stability and flow properties of materials. It can also help prevent accidents and optimize processes.
