How Much Force to Equal Earth's Atmospheric Pressure?
In summary: If you can answer this question, you have the basic understanding of the problem. If you cannot answer this question, you may need to review the problem again, or ask the person who created it for help.In summary, you need to know the area of a person's foot in order to calculate their Earth Atmosphere pressure. You need to know P, and you need to know F.
mr.toronto
#1. What would have to be the area of a person's foot in order to impact a one Earth Atmosphere pressure? What do you need to ask?
Earth Atmoshpere pressure= ?
P=Force(Newtons)/Area(m2)
Okay, so you know that (solving your equation for area) that A = F/P.
You know P.
A is what you are trying to find out.
You DON'T know F.
So what do you have to ask (the person)?
well how many Newtons is one Earth Atmosphere pressure
I know ten Newtons = 1kg arghhhhhhhhh
First of all, pressure isn't measured in Newtons. Pressure is force PER UNIT AREA. Force is measured in Newtons, therefore pressure is measured in Newtons per square metre (also known as pascals).
As for your question...come on! Seriously?!? You don't know what the typical atmospheric pressure is? Don't you ever watch the weather channel? Heh...I'm kind of joking around with you a bit, but even if you DON'T know it off the top of your head, it's something easily looked up. Here are two examples of how you could have saved me some time:
http://www.google.com/search?client=safari&rls=en&q=1+atmosphere+in+pascals&ie=UTF-8&oe=UTF-8
http://en.wikipedia.org/wiki/Atmospheric_pressure
I'm afraid that this is nonsense. It doesn't make any more sense than saying that
3 metres = 2 seconds.
Just as length and time are two different physical quantities (meaning you can't equate them in any meaningful way), so too are force and mass.
A mass of 1 kg WEIGHS 10 Newtons (and that's only true on Earth). That statement means that Earth will exert a gravitational FORCE of 10 Newtons on a MASS of 1 kilogram.
thanks cepheid I kinda get it now
Alright...so what do you have to ask the person (in the problem) in order to solve it?
the area of their foot
Nope, not quite. The area of their foot is what you are trying to calculate (this is a hypothetical person whose foot exerts a pressure equal to atmospheric pressure). So, what information do you need to calculate that area? Well, you need P, and you need F. You know P (it has been given). You DON'T know F. So, what do you need to find out?
you need to know A = F/P
no wait F=A/P
Right, so to calculate A, you need BOTH F and P. But right now, you have only P. When the question says, "What do you need to ask?", it is asking you what additional information you need to solve this problem. Since you need both F and P, but you have only P, the additional information that you need is F. You can't solve the problem until you have F.
Now, what is F? How could you find it out (again, hypothetically)?
Note: this is a simple problem. They just have deliberately NOT given you all of the information you need to solve it. By asking you what additional information is required, they are just checking to see if you understand what the problem is asking.
1. What is Earth's atmospheric pressure?
Earth's atmospheric pressure is the force per unit area exerted by the weight of the air above a given point on Earth's surface. It is typically measured in units of pressure called atmospheres (atm).
2. How is atmospheric pressure measured?
Atmospheric pressure is commonly measured using a barometer, which measures the height of a column of mercury or aneroid barometer, which measures the deflection of a metal disk. The average atmospheric pressure at sea level is about 1 atm or 1013.25 millibars (mb).
3. What factors affect atmospheric pressure?
Atmospheric pressure is affected by the density and temperature of the air. As temperature increases, air molecules move faster and take up more space, leading to lower pressure. Similarly, as altitude increases, the air becomes less dense and the pressure decreases.
4. How does atmospheric pressure impact weather?
Atmospheric pressure is closely linked to weather patterns. High pressure systems generally bring clear skies and fair weather, while low pressure systems are associated with stormy weather and precipitation. Changes in atmospheric pressure can also cause changes in wind patterns and air movement.
5. What are the units used to measure atmospheric pressure?
The most commonly used units to measure atmospheric pressure are atmospheres (atm), millibars (mb), and pascals (Pa). Other units such as pounds per square inch (psi) and inches of mercury (inHg) are also used, but less frequently.
