Solve Brightness of Bulbs | 100W & 50W, 120V Battery
  • Thread starter ana111790
  • Tags
    Brightness
In summary, the conversation discusses the differences in resistance and current between two bulbs connected in parallel and in series, and how these differences affect the brightness of the bulbs. In parallel, the bulb with higher resistance will shine brighter, while in series, the bulb with lower resistance will shine brighter. The factor by which they shine brighter is equal to the resistance ratio between the two bulbs.
ana111790
42
There are two bulbs, one of 100W and one of 50W and a 120V battery.
First, connect them in parallel, find the resistance and current of each and determine which will shine brighter and by what factor. Next connect them in series, again find the resistance and current of each and determine which will shine brighter and by what factor.
Parallel circuits have the voltage drop is the same on each loop.
A circuit in series has equal current.
V=IR
P=IV
In parallel:
I found the current across each resistor, I=P/V so that current across 100W bulb is .833 A and current across 50W bulb is .417. I then found the resistance of each by R=V/I so resistance of 100W bulb is 144 Ohms and across 50W is 288 Ohms. Because the resistance of 50W bulb is larger it glows brighter, by a factor of 2.
In series:
I set (Voltage across 100W + Voltage across 50W)= 120 V.
Substituting for V=P/I, with I being the same I got: 100/I + 50/I = 120, so I=150/120=1.25 A. I then proceeded to find resistance, R=V/I, so Resistance across the 100W bulb is 100/1.25^2 = 64 Ohms and resistance across 50W bulb is 50/1.25^2 = 32 Ohms. Because it has a larger resistance 100W bulb will shine brighter by a factor of 2.
Can anyone verify this is correct? I want to make sure my concepts are right. Thanks!
Resistance of a bulb does not change (it depends a bit of the temperature but this is relevant only at very high temperature differences.) If a bulb is designed for a special voltage and power (the nominal values are written on the bulb) the resistance is R=U2/P. If the voltage across the bulb is different from the nominal value the power will be different. When the power is lower than nominal the bulb shines dimmer. If the power is higher than nominal, the bulb will be destroyed because of overheating.
ehild
In series:
In parallel the two get whatever they need to work from the battery, that mean one has 100W the other 50W. The battery delivers more energy in parallel. So the 100 W will be brighter, and by a factor of 2 (as no other variables are given that is right)
In series they share the same Intensity of current that means that the 50 W bulb has more Power than the 100W, by a factor of 2 as it has double the resistance.
I am having trouble seeing this conceptually, can someone tell me which steps in the process (mathematically solving it) I am doing wrong?
In parallel: (voltages are the same, currents are not)
a) Find the resistance on each bulb
R=V2/P
Resistance of 100W bulb= 120V2/100W = 144 Ohms
Resistance of 50W bulb= 120V2/50W = 288 Ohms
b) Find the current on each bulb
I=P/V
Current on 100W bulb = 100W/120V = .833A
Current on 50W bulb = 50W/120V = .417A
c) Which bulb glows brighter? By what factor?
The 50W bulb because it has a higher resistance, by a factor of 2.
In series: (voltages are not the same, currents are)
a) Find the current of each bulb
I set the sum of the voltages (V1=voltage across 100W bulb, V2=voltage across 50W bulb) equal to 120:
V1+V2= 120 (substituting for V=P/I:)
P1/I + P2/I = 120 (common denominator:)
100/I + 50/I = 120
150/I = 120
I=120/150 = 1.25 A (The same across each bulb)
b) Find the resistance across each bulb
R=P/I2
Resistance on 100W bulb=100W/(1.25A)2 = 64 Ohms
Resistance on 50W bulb=50W/(1.25A)2 = 32 Ohms
The 100W bulb because it has a higher resistance, by a factor of 2.
Thanks
Can someone check the above work please? I pretty much cannot do the rest of my homework since they are problems similar to this one... :(
What do you understand by glowing brighter?
I mean what physical concept?
1. What is the difference between a 100W and 50W bulb?
The main difference between a 100W and 50W bulb is the wattage or power output. A 100W bulb will emit twice as much light as a 50W bulb and therefore, will consume more energy. However, the brightness of a bulb also depends on other factors such as the type of bulb, its design, and the surrounding environment.
2. How does the voltage of a battery affect the brightness of a bulb?
The voltage of a battery is directly proportional to the brightness of a bulb. This means that a higher voltage battery will produce a brighter light than a lower voltage battery. In the case of a 100W and 50W bulb, a 120V battery will make the 100W bulb appear brighter than the 50W bulb.
3. Can a 120V battery power both a 100W and 50W bulb at the same time?
Yes, a 120V battery can power both a 100W and 50W bulb simultaneously. However, the total power consumption will be 150W, which may drain the battery faster. It is important to check the wattage compatibility of the bulbs with the battery before using them together.
4. How long will a 120V battery last when powering a 100W and 50W bulb?
The lifespan of a battery depends on various factors such as its capacity, age, and usage. Generally, a 120V battery should last for a few hours when powering a 100W and 50W bulb together. However, using a higher capacity battery or switching to more energy-efficient bulbs can increase the battery's lifespan.
5. Can the brightness of a bulb be measured in something other than watts?
Yes, the brightness of a bulb can also be measured in lumens, which is a unit of measurement for the amount of visible light emitted. Watts only measure the power consumption of a bulb, while lumens indicate its brightness. For example, a 100W bulb may produce 1600 lumens, while a 50W bulb may produce 800 lumens.
