Thermodynamics: Is Stirling engine reversible or irreversible?
In summary, the Stirling engine cycle involves two isothermal and two isochoric processes, and it operates with just two heat reservoirs. The isochoric processes are irreversible due to the exchange of heat with a reservoir at a different temperature than the gas. However, in the case of an engine connected to an infinite number of infinite heat reservoirs, heat flow would occur isothermally. The Stirling cycle is reversible, but in practice, it is not possible to provide an infinite number of heat reservoirs. Instead, a regenerator is used which acts as a set of infinite heat reservoirs between the two temperatures of the cycle. This allows for reversible heat flow during the isochoric processes, but it still requires an
tsuwal
105
Stirling engine: the cycle is composed by two isothermals and 2 isometrica and there are just two heat reservoirs.
By the isometrics I would say that that it is irreversible since you exchanging heat with a reservoir at a different temperature than your gas.
However my notes say the contrary.. I guess it refers to the case where there are a infinity of heat reservoirs
Science news on Phys.org
Are we talking about a real Stirling engine cycle as you have described which is connected to two heat reservoirs or the cycle in an engine that is thermally connected to an infinite number of infinite heat reservoirs?
In the first case, you are correct. It is irreversible because heat does not flow isothermally. In the second case, heat flow would occur isothermally but I'll buy a steak dinner to anyone who can explain to me how you actually would build such an engine.
AM
Your 1st and last sentences as also your guess are correct.
There are infinity of heat reservoirs (HRs) with which the system interacts during a cycle. But, of them only two HRs suffer a change of heat - the two whose Ts correspond to the temperatures of the isothermals. The other HRs suffer equal amounts of gain and loss of heat during each cycle and therefore don't suffer any change. The set of the HRs that do interact with the system but don't suffer a change are known by the name 'regenerator'.
Stirling cycle is a reversible cycle and there is no irreversible heat transfer at any temperature during a cycle or during any portion of the cycle.
During the isochoric parts of the Stirling cycle, the gas passes through the regenerator. After isothermal expansion the gas passes through the regenerator and gas heat flow is negative (from the gas to the regenerator). After isothermal compression, the gas passes again through the regenerator and gas heat flow is positive (to the gas from the regenerator). What no one seems to ever explain is: how can the regenerator temperature always be equal to the gas temperature during these isochoric processes?.
This is important because if the regenerator is not at the same temperature as the gas, the process is not reversible. In the Carnot cycle this is not a problem because as the temperature of the gas changes (adiabatic compression or expansion) there is no heat flow. So all you need are two reservoirs.
But to make the Stirling cycle reversible you need some way to make the temperatures of the regenerator always the same as the gas temperature as the gas increases or decreases its temperature. You would need an infinite number of regenerators all at different temperatures between Th and Tc.
AM
Perfectly right, except that you mixed up theory and practice.
Your statement about the reversible adiabatics in Carnot cycle is quite right. In reversible isochoric processes, the system suffers heat interactions which give rise to continuous change of temperature of the system. In order that the process be reversible, we need to provide HRs which are at the temperatures as the system is. This, however, is possible only conceptually. Even the isothermal processes in Carnot cycle are conceptual only - for that matter, any and every reversible process is conceptual only - not possible in practice!
Failing to provide an infinity of HRs with a range of continuous temperatures, the best we do in practice is to use a regenerator. All processes we carry out in practice are necessarily irreversible - use of regenertor is no exception.
'You would need an infinite number of regenerators all at different temperatures between Th and Tc.'
No, we don't need infinite number of regenerators, we just need one - because, an ideal regenerator acts as a set of infinity number of HRs between two temeratures: Th and Tc.
P. Radhakrishnamurty
I don't see a problem to realize a heat bath of varying temperature, e.g. a large amount of gas being compressed adiabatically.
As long as you don't see a problem to realize a heat bath (better use heat reservoir) of varying temperature, you may go ahead and use it in the isochoric steps of Stirling cycle, which will then work as a reversible heat engine!
There is nothing wrong with it except that you require another source of work. It seems rather strange to base an engine on a cycle that requires an external engine operating on a Carnot cycle in order to operate reversibly. In that case, is it not really just a more elaborate Carnot cycle?
AM
For sure this then resembles suspiciously a Carnot cycle.
But at least it does not nearly sound as strange as that of coupling to an infinity of heat baths with infinitesimally small temperature difference.
Here is a short description of the regenerator used in the 1845 original engine in the foundry in Dundee. Note the significance of the installation in a foundry.
During the ischores in the cycle the energy rejected is the same as the energy required thus if a device could be found to store the energy during the rejection process and yield it up again during the acceptance process, once the engine had started and warmed up, the cycle would be self perpetuating and no further heat energy would be required through the system boundary.
The device used to carrry out this process was called a regenerator and in the case of the foundry engine consisted of a matrix of sheet iron plates maintained at a high temperature by the furnace at one end and at a low temperature by a water cooler at the other. Thus the necessary temperature gradient was maintained through the matrix, which was of such a bulk that the necessary heat transfers through the processes did not substantially modify the temperatures.
Since, with a regenerator installed, external heat energy is not required to carry out the constant volume processes then the thermal efficiency relies only on the two isothermal processes and is the same as a Carnot engine.
You are right.
In fact, perhaps as you would be aware, the efficiency of Stirling cycle is the same as that of Carnot cycle operating with same values of Th and Tc. After all, they bring about the same changes in the surroundings during each cycle of operation (assuming the same capacity), making them indistinguishable from the point of view of the surroundings, and, that is what matters for efficiency calculation.
Thanks for the information.
I too read a similar description about a regenerator, Though, I don't recall the source now.
I think the efficiency depends on how you "count" the energies. If you are using a regenerator, you should take into account the heat given by the motor in the right isochoric, that heat cancels the heat given in the left isochoric and the efficiency turns out the same as Carnot's and therefore the engine is reversible. However, if you don't take into account that heat (don't use a regenerator) the efficiency is given by:
R(T2-T1)*ln(r)/(cv*(T2-T1)+R*T1*ln(r))
r=volume ratio
cv=heat capacity at constant volume
T2=temp of the hot resevoir
T1=temp of the cold resevoir
You are right. But what is the point you want to make?
It may be of interest to you to note that, there are some, who argue that the efficiency of Stirling cycle is less than the efficiency of Carnot cycle. They don't bother where the rejected heat goes! the area enclosed by the PV diagram of the cycle gives the work and the sum of the Qs (heat supplied at constant volume plus the heat supplied during the isothermal expansion) is taken as the heat input to the system.
This issue has lot of consequences on the second law!
If heat flow from the gas or from the regenerator to the cold reservoir is not isothermal or if heat flow from the hot reservoir to the gas or to the regenerator is not isothermal, then the engine cannot be reversible. I have yet to see an explanation that this is the case even in theory.
There is necessarily a thermal gradient through the regenerator. One end is thermally connected to the hot reservoir and the other end is thermally connected to the cold reservoir. So heat flows through the regenerator from the hot reservoir to the cold reservoir without doing any work. A heat gradient like that is always non-reversible: i.e. it takes more than an infinitesimal change in conditions to reverse the gradient.
AM
Q
In reviewing some of the literature on the Stirling engine, it appears that the term "reversible" when applied to the Stirling cycle did not mean reversible in the sense of ΔS = 0 but reversible in the sense that its direction can be reversed so that by adding work it operates as a refrigerator. This appears to be how Lord Kelvin used the term.
The cycle requires heat flow either into and out of the gas during all four parts of the cycle. Work is done only on two parts of the cycle, 1 and 3 (with 1 being the isothermal expansion). The efficiency is:
[tex]\eta = out/in = (W_{1-2} - W_{3-4})/Q_h[/tex]
Now the numerator is:
[tex] nRT_h\ln\frac{V_2}{V_1} - nRT_c\ln\frac{V_3}{V_4}[/tex]
Since V4 = V1 and V2 = V3 (isochoric parts) this is just:
[tex] nR\ln\frac{V_2}{V_1}(T_h - T_c)[/tex]
Since heat flows into the (ideal) gas during 4 and 1, Qh is:
[tex]Q_h = Q_4 + Q_1 = \Delta U_{4-1} + W_{1-2} = nC_v(T_h-T_c) + nRT_h\ln\frac{V_2}{V_1}[/tex]
So the efficiency is:
[tex]\eta = W/Q_h = \frac{nR\ln\frac{V_2}{V_1}(T_h - T_c)}{nC_v(T_h-T_c) + nRT_h\ln\frac{V_2}{V_1}}[/tex]
This reduces to:
[tex]\eta = W/Q_h = \frac{(T_h - T_c)}{\frac{C_v(T_h-T_c)}{R\ln\frac{V_2}{V_1}} + T_h}[/tex]
And this is the problem. For a reversible cycle we know that Qc/Tc = -Qh/Th, so efficiency is just:
[tex]\eta = W/Q_h = \frac{(T_h - T_c)}{T_h}[/tex]
Two reversible engines have to have the same efficiency. So if the Stirling cycle is "reversible" in the modern thermodynamic sense, that Q4 has to disappear. As I said, if you can show me how it disappears, I'll buy you a steak dinner.
AM
how do you know that if it is resersible, Qc/Tc = -Qh/Th?
If it is reversible, ΔS = 0:
[tex]\Delta S_{sys} + \Delta S_{surr} = 0 + \int_c^h dS_{surr} = \int_{T_c}^{T_h} dQ/T = Q_h/T_h + Q_c/T_c = 0[/tex]
Qh is negative since it is a flow out of the reservoir. Qc is positive. And there is no change in the system entropy since there is no change in state in a complete cycle.
AM
AM
I can see the validity of the point you make.
The ideal regenerator must now be understood like this: It is equivalent to a series of HRs with a continuous range of temperatures (in our case Th to Tc). Just as the HRs have no thermal or heat communication from one to the other, heat transfer through the regenerator from one end to the other end is prohibited, by definition. There exists a temperature difference between the two ends of the regenerator ΔT, but spacially there is no connectivity between two points for heat to flow. Heat flows only from the regenerator to the system and vice versa, but no heat transfer tangential to the plane of (or within) the regenerator. This is the reason the regenerator needs no additional support by way of an external source of energy to maintain the temperature difference between its ends. This is the concept of regenerator.
Regenerator is a conceptual device and not a practical device. To the extent the practical regenerator is different from the ideal (or conceptual one) we can take the practical Stirling engine to fall short of efficiency from the corresponding Carnot engine. Similarly, the real Stirling engine will be irreversible to the extent the regenerator falls short of ideality.
This reduces to:
AM
Your argument is perfectly valid. No one can find fault with it.
The problem, however is with the interpretation of the terms Q and W for efficiency calculations.
W poses no problem. It is Q in the denominator of efficiency equation that is problematic. One way to see it is as you saw it. But there is a different way of seeing at it! And that is to see the HRs that suffered loss of heat. In the case of Stirling engine it is just one HR that is at temperature Th that suffers heat loss Qh. It is this Qh that must find place in the denominator of efficiency and nothing else. That gives us Stirling efficiency equal to Carnot efficiency.
I may add an interesting experience of mine here.
Some years ago (1998-1999) AJP called for papers for its special theme issue on Thermal and statistical physics. Harvey Gould and Jan Tobochnik were the Editors of the issue. I submitted a paper which discussed the issue about the Q in the denominator of efficiency of Ideal heat engine cycles. It was more with specific reference to the right angled triangle PV cycle of R H Dickerson and J Mottmann that appeared in AJP 62,(1994) 737, where they dealt with calculation of efficiency.
My paper was found suitable by the editors and they asked me to send it by email. I sent it that way. Unfortunately Prof. Tobochnik found it contained virus and asked me to remove the virus and submit. I was new to use computers and didn't know how to remove it. While I was seeking help from others to get the virus removed the last day for acceptance passed.
Prof. J Tobochnik was not prepared to remove the virus at his end and was not prepared to include my paper in the special issue after the dead line of dates passed. He suggested I might submit it to AJP. I submitted it to AJP. AJP promptly rejected the same saying that it was a original paper and not suitable for publication in AJP.
By this time I lost interest in pursuing it further and that paper remained unpublished.
Prof. H S Leff who reviewed my paper found it interesting and offered me lots of help but in vain.
I had a look at the design of a Stirling motor. Apparently the regenerator is a block with fine pores and a temperature gradient. If the gas is pumped sufficiently slowly through it, its temperature will always be in local equilibrium with that of the block at the current position. Hence irreversibility is due to heat conduction in the material of the block (which can be reduced chosing a material with a low heat conductance, like some ceramic) and the heat conduction of the gas along the pores (which can be reduced by reducing the size of the pores). So theoretically the irreversibility of a Stirling motor can be made small.
Perfectly right. In the limit no heat conduction within the block ideality is reached and reversibility of the cycle is ensured. If possible you may send me some more information about the design of Stirling motor and the regenerator.
P Radhakrishnamurty
Both
Lewitt (Thermodynamics Applied to Heat Engines)
and
Robinson & Dickson (Applied Thermodynamics)
Contain quite a few pages describing/analysing Stirling and Ericsson engines, including drawings of the original engine and regenerator.
Lewitt also has a worked example from past London University exams.
PM me if you need more information.
I agree that the regenerator helps make it more efficient. As I said, you would need a large number of reservoirs with arbitrarily large heat capacity in order to make the Stirling cycle approach the efficiency of the Carnot cycle.
With a Carnot cycle, once you get the hot and cold reservoirs established, the engine (in theory) does not require any tweaking. In theory, the Stirling cycle requires a slight increase of the regenerator temperatures when the flow reverses in order to reverse the heat flow direction back into the gas.
AM
What no one seems to have mentioned is that the regenerator itself is a hopelessly wasteful device. All that heat passing through and warming a pail of water, which is then discarded!
Hence my comment in post #10 about the availability of a furnace.
1. Is a Stirling engine a reversible or irreversible process?
A Stirling engine can be both reversible and irreversible, depending on the specific conditions under which it operates. In theory, a perfectly balanced and frictionless Stirling engine can be considered reversible, as it can operate in both directions without any energy loss. However, in practice, due to imperfections and inefficiencies, most Stirling engines are considered irreversible processes.
2. What factors affect the reversibility of a Stirling engine?
The main factors that affect the reversibility of a Stirling engine are temperature differences, gas properties, and mechanical losses. The greater the temperature difference between the hot and cold sides of the engine, the more irreversible the process becomes. The type of gas used also plays a role, as some gases have higher internal friction and thus lead to more irreversible processes. Lastly, mechanical losses such as friction and heat transfer also contribute to the overall irreversibility of the engine.
3. Can a Stirling engine be made more reversible?
Yes, it is possible to make a Stirling engine more reversible by minimizing temperature differences, using gases with lower internal friction, and reducing mechanical losses. This can be achieved through careful design and engineering, as well as using high-quality materials and precise manufacturing techniques.
4. How does the Carnot efficiency apply to Stirling engines?
The Carnot efficiency is a theoretical limit on the efficiency of any heat engine, which is based on the temperature difference between the hot and cold sides of the engine. In theory, a Stirling engine can achieve the Carnot efficiency if it operates at the same temperature as the hot and cold reservoirs. However, in practice, this is not possible due to the aforementioned factors that affect the reversibility of the engine.
5. Can the irreversibility of a Stirling engine be reduced to zero?
No, it is not possible to reduce the irreversibility of a Stirling engine to zero. This is because even in a perfectly designed and balanced engine, there will still be some mechanical losses and imperfections that lead to irreversibility. However, with careful optimization, the irreversibility can be minimized to a very small degree, resulting in a highly efficient Stirling engine.
12K
