Register to reply
Ground Testing
by Royherd27
Tags: ground, grounding, neta, ohms, resistance, test, testing
Share this thread:
Royherd27
#1
Oct16-13, 03:14 PM
P: 11
Can the point to point test, (to determine the resistance between the main grounding system and all the major electrical frames, system neutral, etc) be made with an ordinary multimeter or does it need a special ground test tool?
The NETA value of 0.5 ohm is widely accepted?
Phys.Org News Partner Engineering news on Phys.org
DIY glove-based tutor indicates muscle-memory potential
Tricorder XPRIZE: 10 teams advance in global competition to develop consumer-focused diagnostic device
Study shows local seismic isolation and damping methods provide optimal protection for essential computing equipment
meBigGuy
#2
Oct16-13, 11:31 PM
P: 1,084
The advantage of an approved tester is that it is consistent with your country's requirements, and doesn't depend on you interpreting the rules and the readings and correctly applying the correct stimulus.
Babadag
#3
Oct18-13, 12:39 PM
P: 54
See[for instance]:
http://www.lightningman.com.au/Earthing.pdf
Babadag
#4
Oct19-13, 02:32 AM
P: 54
Ground Testing
See also [for instance]:
http://www.chromausa.com/pdf/app-not...2004122013.pdf
or:
http://www.hipot.com/pdf/Ground-Bond...ty-Testing.pdf
the_emi_guy
#5
Oct19-13, 02:27 PM
P: 589
Quote Quote by Royherd27 View Post
The basic problem with ordinary multimeter is that its leads will add resistance in series. You will need long leads if you are probing between major electrical frames, the lead resistance will probably be orders of magnitude more than the bonding resistance you are trying to measure.
You need a 4 wire "Kelvin" resistance meter (previous posters provided links). Here is how they work:
2 leads supply a constant controlled current source through the ground structure under test (lead resistance not an issue here since it is a current source). The other two leads measure voltage across the current source. The voltage measurement leads draw very low leakage current so lead resistance here is not an issue.
Register to reply
Related Discussions
Box on ground, incline (with friction), ground: find Kinetic Energy Introductory Physics Homework 10
Testing Ground in a Building Classical Physics 4
AC ground,DC ground & virtual ground. Electrical Engineering 1
Finding the subnormal using Descartes normal method Calculus & Beyond Homework 2
