Thermodynamics isue not homework but debate
In summary: A year later, the same balloon might leak half, or even all of its gas overnight. Some balloons are coated with an impermeable coating, but that may also wear off over time. A balloon may also burst instead of leaking.In summary, the conversation revolves around the question of what causes a balloon to explode when exposed to the sun. The two sides argue whether it is due to an increase in pressure or an increase in volume. The expert believes that the failure mechanism is fundamental to the breaking of atomic bonds, rather than the specific cause. The conversation also touches upon other factors that may contribute to the failure of a balloon, such as the type of gas used and the material and thickness of the balloon.
billowo
Thermodynamics isue... not homework but debate...
Hi, i have visited the forum for an explanation in cuantum theories (curious) and now i need other help.
In my school (in Chile, we speak spanish, forgive my english, please), my teacher gave a test, I am really good at physics but this time i got wrong an answer that i think that is wrigh, post your opinions and give VALID answers, not just a yes, maybe mathematical answers would be better.
the problem is this If you leave a baloon exposed to the sun, ¿what will happen?
(Really easy so far, right)
-My teacher says that it will explote (¡¡¡ NO WAY¡¡¡, really??') because of the presure increase.
-I say it will explote because of the volume increase.
This are my argumens
-When you say something (in cience) you have to make an hipothesis, to make a theory you have to reduce (or eliminate) any other variable or noise (Right).
So far so good...
so i started to think, the sun heats the balloon, that makes presure increase that makes volume increase that makes the balloon explote... so the presure is linked to the volume (in the baloon) .
-To eliminate all variables i simulated 3 experiments
1--Volume variable (all constants)
2--Presure variable (all constants)
3--Temperature variable (all constants)
In 1--Volume variable i give the next "hipothetical" scenario:
-In order to preserve presure and temperature constant i will decrease the "outside baloon" presure, so the presure differences will make the balloon expand without changing inside presure (At least in very little) nor temperature... (in theory) what I am doing is to expand the baloon, Will it explode at some point??...YES.
In 2--Presure variable i give the next "hipothetical" scenario:
-In order to preserve volume and temperature constant i will increase the "outside baloon" presure, and at the same time increase the "inside baloon" presure (either with magic or adding more gas) so the presure differences is 0 that will make the balloon to increase (inside) presure without changing volume nor temperature... (in theory) Will it explode at some point??...NO... because the presure inside and outside will eliminate each other (First law of Newton).
In 3--Temperature variable i give the next "hipothetical" scenario:
-Honestly, i tried to think this one, and i just couldn't figure it out...
SO what do you think??, my teacher is right or i am right, because if you thing about it, in all cases, volume is what makes a baloon explode, right??
PS: A tie is also allowed, that means say that neither the presure nor the volume is what cause the baloon to explote, that means saying that BOTH are linked so both answers are right.
Science news on Phys.org
Fundamentally, the balloon fails because it takes less energy to break the atomic bonds of its constituent material than it does to stretch them any farther.
I agree with you. The balloon would not fail if the pressure were increased at constant volume and temperature (for example, by enclosing the balloon or by increasing external pressure too, as you pointed out). But it would fail if the volume were increased at constant pressure and temperature (for example, by manually stretching the material). It would also fail if the temperature were increased at constant pressure and volume (for example, by heating an open balloon). In the temperature case, the balloon would fail because the solid plastic would start to flow.
So in my opinion it seems more reasonable to say that a balloon fails by volume increase than by pressure increase. But these are coupled in the closed-balloon-in-the-sun scenario, so it seems like a minor issue. I think it is much more useful to describe the failure mechanism, the fundamental idea of atomic bonds breaking, than to argue about the cause.
A rubber balloon filled with AIR will leak, because air can pass through the rubber. Perhaps the leakage rate compensates for thermal expansion from heat from the sun (PV = nRT). Over time, the sun degrades the elasticity and quality of the rubber, possibly causing failure.
If the balloon is filled with gas lighter than air rises indefinitely: external pressure decreases towards a vacuum. An increasing difference between internal and external pressure adds stress to the balloon's rubber, possibly causing failure.
first time i am hearing that. IF it does leak, in what quantities does air leak through rubber?
Balloon wall thickness and material are not standardized, thus vary greatly. Mylar balloons usually have less air leakage than rubber, but are usually more expensive.
The greater the difference between inside and outside pressure, the greater the leakage rate. A freshly filled helium filled rubber balloon could leak one fourth of its gas overnight.
1. What is thermodynamics?
Thermodynamics is a branch of physics that deals with the study of heat and its relation to energy and work. It explains how energy is transferred and transformed in physical systems, and how this affects the properties of matter.
2. What are the laws of thermodynamics?
The first law of thermodynamics states that energy cannot be created or destroyed, only transferred or transformed. The second law states that the total entropy of a closed system will always increase over time. The third law states that the entropy of a pure crystalline substance at absolute zero temperature is zero.
3. How does thermodynamics apply to everyday life?
Thermodynamics is present in many aspects of our daily lives, from the functioning of our bodies to the operation of machines and appliances. It helps us understand how energy is used and transformed in various processes, such as cooking, electricity generation, and transportation.
4. What is the debate surrounding thermodynamics?
One of the main debates in thermodynamics is whether or not the universe will eventually reach a state of maximum entropy, known as the "heat death." Some scientists believe that this will eventually occur, while others argue that the universe may undergo a cyclic process of expansion and contraction.
5. How does thermodynamics relate to other fields of science?
Thermodynamics has a strong connection to other fields of science, including chemistry, biology, and engineering. It is used to understand and predict the behavior of systems and processes in these fields, and has also led to the development of other branches of study such as statistical mechanics and chemical thermodynamics.
  • Thermodynamics
  • Other Physics Topics
  • Thermodynamics
