When does equality occur in the inequality (a^2+b^2)cos(α-β)<=2ab?
In summary, Harry tried to solve the problem of proving that in any triangle ABC with a sharp angle at the peak C, apply inequality (a^2+b^2)cos(α-β)<=2ab but couldn't find the angle α-β. He then suggested making one, and when he did so, he found that equality occurred.
  • #71
soo I see that it apply but I don't know mathematically explain :(
  • #72
ok, then explain it in ordinary English first …
what makes you think that it applies? :smile:
  • #73
I see from definition, better said I believe that apply :(
  • #74
or c²≤ a²+b²
c²/c² ≤ (a²+b²)/c²
sin²α + sin²β ≥ 1
  • #75
But it doesn't apply! when I have (a²+b²)cos(α-β) ≤ 2ab when a=b and α=β then occurs equality.
But when I have sin²α + sin²β ≥ 1 ,α=β equality doesn't occur ! where is mistake ?
  • #76
i don't understand … what is c ? :confused:
EDIT: oh, i didn't see your last post
why are you going back?
you have to prove (sin²α + sin²β) ≥ 1 using only α + β > 90°
  • #77
I don't know how :(
  • #78
oh, I have feeling that I never finish this prove :(
sin²α + sin²β = 1 when α+β=90 so inequality doesn't apply I think
  • #79
yes, but the question specifies an acute angle (BCA), so α+β > 90°
ok, as you say, sin²α + sin²β = 1 when α+β = 90°,
so how can you show that sin²α + sin²β > 1 when α+β > 90 ? :smile:
  • #80
certainly β or α >45° so sin²α or sin²β > 0,5 so sin²α+sin²β >1 but how explain it mathematically
  • #81
no that argument doesn't work unless both β and α are > 45°, does it?
we're still looking for a proof of sin²α + sin²β > 1 when α+β > 90°,
using sin²α + sin²β = 1 when α+β = 90° :smile:
  • #82
apply sin²α + sin²β = 1 when α+β = 90° and from that α+β > 90 so sin²α + sin²β >1
so when I prove sin²α + sin²β >1, I proved that (a²+b²)cos(α-β) ≤ 2abcos(α-β)?
  • #83
Could someone help me? I am desperate:(
  • #84
(been out all day :wink:)
yes, if you prove that sin²α + sin²β > 1,
then the previous arguments show that (a²+b²)cos(α-β) ≤ 2ab …
but first you have to prove that sin²α + sin²β > 1
  • #85
how?
into sin²(α-β)b²/sin²β ≤ (a²+b²)sin²(α-β)
and so b²/sin²β ≤ (a²+b²)
thats isn't true because when α=β we divide 0
  • #86
yes, we can't divide both sides by sin²(α-β) when sin²(α-β) = 0
we have to deal with the case of α-β = h = 0 separately
(this is one of the things i was referring to when i mentioned tidying up earlier :wink:)
  • #87
How can I prove sin²α + sin²β > 1 when α+β > 90°?
  • #88
as you said before, sin²α + sin²β = 1 when α+β=90 …
using that, it's actually very easy to prove it …
just draw a few triangles, some with = 90°, and some with > 90°, and you'll see what i mean :smile:
(btw, i'll be out soon, for the rest of the evening)
  • #89
Yes I know what do you mean, but when I use picture so it isn't correct mathematical proof so I don't know ...
  • #90
try drawing a three-dimensional graph …
put α and β along the usual x and y directions, and sin²α + sin²β along the z direction …
that will be a surface …
do it for a "box" with 0 < α < 180° +and 0 < β < 180° …
what does it look like?
draw the line z = 1 on it :smile:
  • #91
time to tidy-up …
hi harry654! :smile:
ok, when we get stuck, it's good idea to go back and check whether we missed anything on the way
and so, looking back to page 3 (!), I've noticed that we got to …
harry654 said:
I have (a²+b²)cos(α-β) ≤ (a²+b²-h²)/cos(α-β)
and from it I get
(a²+b²)cos²(α-β) ≤ a²+b²-h²
but how can I tidy up later?
and going from the first inequality to the second, we multiplied by cos(α-β), which can be negative,
and of course if it is negative, then multiplying by it turns the ≤ into a ≥
so (tidying-up time! :wink:) actually we need to prove that, if α + β > 90°, then:
sin²α + sin²β > 1 if cos(α-β) > 0, ie if |α-β| < 90°, and
sin²α + sin²β < 1 if cos(α-β) < 0, ie if |α-β| > 90°;
(alternatively, we could simply point out that we needn't bother with the cos(α-β) < 0 case, since the originally given inequality, (a² + b²)cos(α-β) ≤ 2ab, is obviously true in that case, since the LHS is negative and the RHS is positive! :smile:)​
  • #92
Yes THANK YOU tiny-tim! I understand this and I thank you for your patience and assistance.
  • #93
Anyway I have question. Does it apply when sin(α-β) isn't 0 so cos(α-β) is positive or no?
  • #94
sorry, i don't understand :redface:
  • #95
Assume that apply sin(α-β) is not 0 then question is : Is cos(α-β) positive?
  • #96
sin(α-β) wil be zero only if α = β …
if α ≠ β then cos(α-β) can be either positive or negative
for example if α = 150° and β = 20° then cos(α-β) = cos130° is negative :wink:
why are you asking? :confused:
  • #97
because I thought that I can say cos(α-β) is positive because sin(α-β) is not 0 but I found out that I can not :D OK thank you again:)
  • #98
Hi tiny-tim!
If α=135 and β=30 then sin²α + sin²β < 1 and apply α+β>90 so what isn't correct?
  • #99
harry654 said:
Hi tiny-tim!
nothing, that's fine because cos(α-β) = cos105° < 0, so it agrees with …
