Question about Critical Temperature and Interface between Liquid and vapour
In summary, at critical temperature the interface between liquid and its vapour disappears, which is observed at the boiling point for a liquid.
Abir Sarkar
While Studying 'surface tension' I came across a statement that 'At critical Temperature the interface between liquid and its vapour disappears' without any explanation or logic. Can Anyone please tell me why such phenomenon is observed at critical temperature ?
Thanks in Advance.
not sure what you mean by that, emphasis on the word interface
As far as I know an interface is a tool and concept that refers to a point/layer of interaction between components/ Different substances. :)
Read: http://en.wikipedia.org/wiki/Critical_point_(thermodynamics)
In case when some liquid is in a closed vessel and the volume above the surface is filled with the saturated vapour of the liquid, the physical properties (for example density) of the liquid are clearly different from that of vapour. Heating the system, the density of the liquid decreases, that of the vapour increases, together with the increasing pressure. There is less and less difference between liquid and vapour and the difference vanishes at the critical temperature: you get a single phase.
ehild
Mr.Ehild,
First of all thanks a lot for your reply. The Reference you have given in your reply helps a lot to understand the term "Critical Temperature". Ultimately I just reached to a conclusion that "at Critical temperature [ in general ] The distinction between liquid and vapor disappears as the boiling point is always less than that of critical temperature of that particular liquid" . But now the question arises that is there any possibilities to have any liquid with greater boiling point than that of critical temperature ?
Look at the phase diagram: does liquid phase exist above the critical temperature? A gas does not boils.
When a bubble appears inside a liquid, its volume is filled with saturated vapour. The pressure of the saturated vapour depends on temperature. If it is less than the ambient pressure, the bubble collapses. At that temperature where the saturated vapour has the same pressure as the ambient, the bubbles do not collapse, but increase and raise up to the surface of the liquid and leave it. The boiling point of a liquid is defined as the temperature where the pressure of the saturated vapour is the same as the ambient pressure.
There is no liquid and vapour above the critical temperature. The substance does not have defined volume. How would you define boiling point for a gas?
ehild
oops .. now I just got it :)
Thanks again for your time & consideration and for such great explanation too :)
You are welcome.
ehild
1. What is critical temperature?
The critical temperature is the highest temperature at which a substance can exist in a liquid state. Above this temperature, the substance will transition into a gas or vapor state regardless of the amount of pressure applied.
2. What is the significance of critical temperature?
Critical temperature is important because it marks the point at which a substance can no longer be liquefied, no matter how much pressure is applied. It also helps to determine the conditions under which a substance will transition from a liquid to a gas or vice versa.
3. How does critical temperature affect the interface between liquid and vapor?
At the critical temperature, the interface between liquid and vapor disappears, and the substance becomes a single phase. This is because the properties of the liquid and vapor phases become identical at this temperature, making it impossible for the two phases to coexist.
4. What happens at the interface between liquid and vapor below the critical temperature?
Below the critical temperature, the interface between liquid and vapor is present, and the two phases can coexist. The amount of vapor present at the interface depends on the temperature, pressure, and properties of the substance.
5. How does critical temperature vary among different substances?
The critical temperature varies among different substances and is dependent on their molecular structure. Generally, substances with stronger intermolecular forces will have a higher critical temperature, while those with weaker forces will have a lower critical temperature.
  • Mechanical Engineering
  • Mechanics
  • Astronomy and Astrophysics
