Is Quantum Entanglement a Means of Evil Communication Across the Galaxy?
In summary, quantum entanglement is when two particles are linked in such a way that any change in one particle will also affect the other, regardless of the distance between them. However, this does not allow for the transmission of meaningful information as any observation or alteration of one particle will only result in a random outcome for the other particle. This concept is often misunderstood and confused with classical entanglement, which does not exhibit the same properties as quantum entanglement. Thus, entanglement cannot be used to communicate information in any way.
Causetic
Physicist say "Quantum Entanglement is when you place 2 electrons together.
They Vibrate in Unison.
When you take them across the galaxy if you "jiggle" one, The other also "jiggles"
Physicist say" however it does not transfer any meaningful information"This is a EVIL way of speaking.
Why can't you Jiggle Once For YES
Twice for NO
10101010?
That is to say you take one electron , go to the far side of the galaxy, spend trillions of years flying there
you have a question that both sides already agreed upon for when you reach your destination
say "is it raining?"
Once you arrive they "jiggle" yes
How is this not New and Meaningful FTL information
FTL you now know that on the other side of the galaxy it is raining.
If you "jiggle" the entanglement is broken. The next "jiggle" will not do anything.EVIL...?
They say that if you alter the state of one, the state of the other is also altered and can be observed.
but also claims that this is not meaningful information.
But that's a false statement, as long as you can alter and observe the alteration, that is meaningful information.
unless your saying that you cannot observe the alteration in any way.
even if the entanglement breaks after 1 alteration, 1 bit of data is still meaningful information.
Quantum entanglement does not work the way you are imagining it. You CANNOT tell whether the value you get upon measuring a particle is due to pure chance, or because someone altered the state. Shaking one electron does NOT cause the other one to move. What is meant is that when you measure the state of one particle the other particle must be in a different state. However neither one knows which state it is in until one of the particles is measured. At that point in time BOTH particles know which state to be in, no matter how far the distance is between them. No information can be transmitted using entanglement.
Welcome to PhysicsForums, Causetic!
When you interact with one member of the pair, let's say Alice, you cannot impart any specific action to it which will be transmitted to the other (who we will call Bob).
The rule is: an observation about Alice tells you something about Bob. But that does NOT tell Bob anything specific. The reason is that the observation of Alice always produces a random result (otherwise Alice and Bob are not entangled). It is true that Bob will see that random result, but so what? All Bob sees is the equivalent of a random series of 0's and 1's. I.e. no useful information.
Further, there is no experimental technique to even assure ourselves that it is Alice causing the collapse into a known state - it could be Bob. *Regardless of sequence*, there is no preference given to one's actions over the other. So who is to say that Alice collapses things; when Bob might see it the other way around.
Sounds like another case of quantum misinformation!
The easiest way to picture it in most cases is to imagine the entanglment as this;
Take two socks, a red and a blue one.
You take the socks and put them in boxes, you then randomize the boxes so you don't know what sock is in what box.
We could describe the state of each box as 'red + blue' there's an equal probability that we have a red sock or a blue sock in our box.
We then separate the boxes by whatever distance you want. We then measure the box, just say we find red in our box, then the state of our box can then be described by just 'red' but in doing this we have changed the description of the state of the other box, it's state has gone from 'red + blue' to just 'blue'
Can we convey information in this manner?
No, we cannot.
Thank you so much for your answers, I've been so frustrated with this issue ever since i was told my original statement.
digging into my brain.
i just wanted someone to dispute the bad description given to me but can't find anything on wiki /previous post specifically disputing it. (one that i can understand at least)
thanks all
:D
Your analogy serves to explain how two things can be entangled without sending signals, but be aware that this is the usual example used to distinguish classical entanglement (the socks) from quantum entanglement (which is quite a bit more subtle and doesn't happen with socks). Only the latter leads to Bell's theorem and "spooky action at a distance." To be clear, as it has been said, neither can be used to transmit information.
No, we cannot.
Einstein, Podolsky, and Rosen thought that quantum entanglement is not any more mysterious than you socks example, but then Bell presented a powerful argument that a "socks" explanation does not suffice to understand the phenomenon. You can read about Bell's proof http://quantumtantra.com/bell2.html.
Hmm... I would say that the link you provided misses half the point of Bell's Theorem. Without getting too deep into it, you can read for instance here that the proof you presented misses the possibility of violation of counterfactual definiteness, which happens to be a property of the Many-Worlds interpretation, because of the basic postulate of multiple parallel universes due to superpositions at the macroscopical scale.
The way I understand it, once the two photons are entangled, they are in a superposition of an infinity of polarisations, as good wavefunctions they are. And so, once you observe the photon, you become a part of the superposition, and all that.
Now, the probability of mismatch described by the example given seems to be quite like the Born Probabilities which describe the pseudo-probabilistic nature of the evolution of the wavefunction.
It seems, to me, that what happens is simply that the universe has entered a superposition of states, and so, according to the Born Probabilities, given that the two photons are entangled, and given that there is a 60º difference between the two SPOTs, it just so happens that in 75% of the universes the two bits will mismatch.
No, Herbert doesn't miss this. His purpose is to disprove the hypothesis that "reality is local" AKA local realism or locality + counterfactual definiteness.
The EPR example gives a good illustration of the impossibility of transmitting information. If you have two entangled electrons A and B then a measurement of the spin of A on a particular axis will lead to a measurement of the spin of B which will have a probability of an opposite spin equal to the square of the cosine of the angle between the two axis. So if A is measured along the x-axis and B is later measured on the same axis then B will always have an opposite spin. If A and B are light years apart then the fact that A was first measured on a particular axis will immediately effect the probabilities of the measurement of B's spin, however there is no way for B to know what the spin of A is, all B knows is whether the spin is up or down on the axis he measured, and while A knows that once he measures spin along a given axis, then the probabilities for B will be determined by that, he has no way to know what axis B will chose to measure and is of course limited to the speed of light in attempting to communicate to B which axis was chosen.
Where did you get that idea?
I mean, they thought the only reason quantum entanglement seemed "spooky" was that quantum mechanics was an incomplete theory. But they thought a future, more complete theory would explain away "spooky action at a distance". so that quantum entanglement would be no more mysterious than the socks example.
lol guys, the socks example is pretty much the best thing you can do without invoking maths, at least it's the best example I've seen so far that doesn't give people ideas of ftl stuff :shy:
imo any explanation that doesn't use the maths directly will be insufficient in some way
It's not strictly necessary to invoke difficult maths to get the spirit of what is "spooky" about quantum entanglement, only if one wishes to actually verify that spookiness for one's self. At issue in EPR was not what is true about socks, it was expressly what is true in quantum mechanics that is not true about socks. Einstein and company understood socks just fine, indeed they felt that all matter had to act like socks. The whole point of EPR is that quantum mechanics does not act like socks, and EPR used that to try and conclude that therefore quantum mechanics was incomplete. Bell found a way to verify experimentally that quantum mechanics was actually right-- the reality of the particles was not like the reality of the socks, and thus quantum mechanics could still be a complete description. Of course how we interpret that completeness is still left wide open, and Bell favored the most "sock-like" of the interpretations, which is Bohm's. But even Bohm's allows behaviors that socks can't do, so it is still the crux of the matter as to how quantum particles don't act like socks.
Well, yes, when it will be explained away it won't be mysterious. But then (and now) it was not explained away. Your statement kind of implies that they believed there was nothing to explain away.
Actually Einstein said something like what you imply:
"The attempt to conceive the quantum-theoretical description as the complete description of the individual systems leads to unnatural theoretical interpretations, which become immediately unnecessary if one accepts the interpretation that the description refers to ensembles of systems and not to individual systems."
But considering that he does not say where he sees the difference between individual system and ensemble it can not be viewed as a way to explain entanglement away. IMHO
OK, all I was trying to say is that Einstein et al. believed that ultimately quantum entanglement would be understood with a "socks" explanation, not anything "spooky".
The analogy with socks is misleading, because it presupposes ignorance from the side of the observer. In QM entanglement is not about ignorance over the states of the two particles like in statistical mechanics. It is intrinsically inherent in the particle system itself. If we want to force the analogy between socks randomization and particles in QM we could say that when the blue and red socks come together they will form a red+blue=green physical 'entity'. And that 'entity' will remain green as long as it spreads throughout the universe and someone doesn't look at it. Then, when the measurement occurs, the green colored entity will collapse instantly to the red and blue socks (possibly light years apart). But which sock will have which color is a process that happens by pure chance, you can't force it to your advantage for encoding messages. We might say that entanglement is about a 'state of being', and not as a set of possible microstates as in statistical mechanics.
So the entanglement is quite unstable [or should I say not verry stable]? If this is so, then does it mean that in the sub-atomic levels entanglements appearing [being build] and disapperaing [being destroyed] all the time?
Hi Aidyan, I posted in another thread about this but you've kinda cleared somethings up for me with your post.
So keeping with the sock analogy, you're saying that together they could produce green and it will remain green no matter the distance, until a measurement is made. My next question is how do you determine they are both green? I thought measuring it would instantly determine if it is red or blue, so how can you measure to tell it's green?
I appologise if this is hard to explain with such a stuipd analogy, my understanding of these things at this point is pretty basic.
In a way, yes.
This thing of "measuring will instantly determine" is a little bit too mystical.
What happens is not that the socks are 'green'. Neither of them is 'green'. They're just in a joint state of red+blue, what we should call a superposition, and we conveniently named this superposition 'green'. That basically means that each sock is red and blue at the same time (more or less what happens with Schrödinger's Cat), and furthermore, what's really impressive about this is that while the 'green system' doesn't interact with anything else (i.e. no outside particles happen to meet the system), the socks can interact with themselves (that's what happens with the electrons in a double-slit experiment), because they are in what's called a 'coherent' system.
Now let's be clearer here. Measuring does not alter the system itself in any way. If we define measuring in this particular case as a person opening the box and seeing the one sock, this is what happens. What happens is that what once was a coherent superposition of red+blue socks is now another superposition of 'red sock and human who saw red sock+blue sock and human who saw blue sock'. That is, you are superposed with yourself.
But of course, you yourself don't realize that. There is one 'you' who will only see a red sock, and there is another 'you' who will only see a blue sock. And because of that measurement, each of the 'you's will know what colour the other sock is.
And the analogy breaks down here, because in the sock case, if one sock is red, the other is definitely blue, and vice-versa. That is not so with entangled systems. It also depends on the "way" they are measured. I will take the example given earlier at the explanation of Bell's theorem.
In the example, they have a source that sends pairs of entangled photons (let's call them socks) to Alice and Bob, in different places. Alice and Bob each have a copy of a certain measuring apparatus, the SPOT, and depending on how the spot is positioned they can or cannot see each photon. Let's call 'blue' the state where one of them can see the photon, and 'red' the state where they cannot.
In this experiment, there is a multitude of entangled socks, one after the other. What is observed is that if Alice and Bob have the SPOT positioned in the same way, their results will seem completely random (half the times they will see red, half the times they will see blue, with no apparent order), but once they meet, they will see that the exact order of their results will match to a T.
Now, suppose Bob rotates his spot 90º. From that moment on, while the results will still appear random, once Bob and Alice compare their results, they will see that they are all inverted, that is, whenever Bob saw Red, Alice saw Blue, and vice-versa.
Next step, suppose Bob and Alice's SPOTs are aligned again, but Bob rotates his 30º clockwise. From then on, they will see that 25% of their results disagree. That is, one out of four times Bob saw red, Alice saw Blue, but the other three times they both saw the same thing.
Suppose now Alice rotates her SPOT another 30º, except counterclockwise, so that there is an angle difference between both SPOTs of 60º. One should expect that then half their measurements would differ, right? Except this doesn't happen, and 75% of the time there is a difference in measurement.
This happens because the probability of a match is given by the cosine squared of the angle difference between both SPOTs, and that has to do with the Born Probabilities.
Let's explain what really happens. At first, before any measurement is made, we have an entangled, superposed state of two photons, each going in a different direction. Once they are detected, however, the superposition of states gets a little bit more complicated.
We have 'Alice sees red and Bob sees blue + Alice sees red and Bob sees red + Alice sees blue and Bob sees blue + Alice sees blue and Bob sees red'. These are the four possible different systems that happen. Once measurement was made, Alice and Bob became part of the superposed system. But that's not all. Because of the Born probabilities, not all four states are equally likely (although since all of them physically happen, likely isn't a good word here; let's just say that there's not an equal number of Alices and Bobs that fit in each state).
Actually, if we define chance as the probability that Alice and Bob will find themselves in a given state, then there is a 3/8 chance of 'Alice red, Bob blue', a 3/8 chance of 'Alice blue, Bob red', a 1/8 chance of 'Alice red, Bob red' and a 1/8 chance of 'Alice blue, Bob blue'.
And if you then ignore Bob's result (i.e. if you don't ask Bob about his detection), then you have exactly 1/2 chance of 'Alice red' and 1/2 chance of 'Alice blue'. Once you know Alice's result, if you ask Bob, you know that there is a 3/4 chance of 'Bob disagrees with Alice' and a 1/4 chance of 'Bob agrees with Alice'.
That's... about it, I guess. I'm not sure I made myself perfectly clear, Quantum Entanglement isn't exactly easy to explain or understand :P
Again you are using too classical a concept of probability here. There is zero chance of Alice blue, Bob blue, if we later ask Alice and Bob to compare results. What you are describing is more like a "many worlds" kind of interpretation, which is not a necessary interpretation to take, is a bit bizarre to many, and above all, requires renormalizing the probabilities all the time because you end up with copies of Alice and Bob-- so you can't just use standard classical probability arguments.
In a way, yes.
So in the case with the two little diamonds that were entangled by scientists - if one of the diamonds is droped on the floor or trown - this will break the entanglement ? [I must be getting this wrong, but... ]
With the 'colored' sloppy terminology the 'green' state obviously meant a specific quantum state which is the superpositon of the two particles states. But it is not only that, because that state must also respect the principle of quantum indistinguishability (that's why the correct state vector is written |Psi_c>= (|blu>|red>+-|red>|blue>)/sqrt(2) and not just the wrong |Psi_w>=(|red>+|blue>)/sqrt(2)). At the bottom it all boils down to the principle of complementarity (of which Heisenberg's uncertainty is only an example). When two particles interact or scatter with each others in a tiny volume of space the uncertainty over their position and impulse (as spin and other non commuting observables) is such that the possibility to distinguish which path (spin state, etc.) the one or the other particle took is 'washed out', they become indistinguishable. Again, not because of our ignorance, they are not distinguishable even not in principle, there simply isn't anything like 'two particles' scattering but a 'single whole' (the 'green' thing) and that we describe with the wavefunction |Psi_c>. How do we know that? If you are tempted to calculate the scattering rate by describing the system with |Psi_w> (scattered particles distinguishable) you simply get the wrong answer. Experimental results will instead fit only if you describe the scattering process by |Psi_c> (scattered particles indistinguishable).
E.g. see: http://www.phy.cuhk.edu.hk/course/2011-2012/2/phys5520/download/1/Indistinguishability.pdf Fig.3 is our 'naive' view of the process. What really happenes is in Fig.2
Even without taking many-worlds into consideration, I'm pretty sure you can consider the classical concept of probability here when talking about the state of the universe before we ask Alice and Bob about their results. There is not zero chance of Alice blue, Bob blue even if we ask them to compare results, because if the SPOTs are tilted so that the relative angle between them is 60º, there's still a match 25% of the time between both of them. So whichever result Alice writes down, 25% of the time it will be exactly the same as Bob's, as stated in the article on Bell's Theorem.
Also, I've yet to find a good argument against Many-Worlds that doesn't involve human notions like "bizarre", because as the matter of the thread exemplifies, the Universe does not care how bizarre we think it is, its laws are absolute. But we're not going to discuss this here, because this is not the point of the thread :P
Hmm... to put it very simply, yes, it will. But let's complicate a bit:
Once the two diamonds are entangled, as long as they don't interact with anything else (or rather, as long as nothing they interact with has the ability to change their entangled configuration), the entanglement holds. Once you measure it, you will know the state of the other tiny diamond.
But if you drop it on the floor, or throw it, or anything that radical, I'm pretty sure the diamond interacts with enough particles that you actually change its configuration.
I am not 100% sure of the above, someone who knows more about how resistant diamonds are to being dropped on the floor can be better to explain this XD
:D
well I will ask one more question, just to make sure its all clear to me
So in the case with the diamonds again - I can take one of them with me and drive say 900 km away, no metter how fast or un-smooth I drive- the diamonds will stay entangled, but If I crash the car and the diamond got damaged- the entanglement is broken?
Because I watched video about the the possible use of quantum entanglement for comunication in future and one of the possible scenarios was - to entangle two brains and this way to make them experience what the idea of "telepathy" is [not in the mystical way]. Like when I think of something the neurons in my brain "fire" signals to each other, and the second brain [lets say of my friend] will start fireing too. But from what I understand from you this idea is more of a fairy-tale ?
gogo_t said:
:D
In the first case, it's not necessary that you crash the car. Any interaction that changes the system somehow breaks the entanglement. Now I'm not sure exactly what it is in a diamond that could be entangled, but let's suppose it's the spin of the particles in it. In this case, a mere magnetic field around would be able to break the entanglement because it would change direction of the spins of the particles of the small diamonds.
Entanglement doesn't hold against change, is the main idea. If you entangle two brains, for a split second they will be the same person (i.e. there won't be a 'you' and 'your friend' anymore, you will be exactly the same, personality- and memory-wise), and as soon as you saw anything, your brain would fire a neuron and the entanglement would break. And that is mostly because brains are too big and complicated and full of atoms to be entangled in the first place, so if you did manage to do that, you would have a very awkward situation in which neither of you would know who you really were, because both of you would be the same person (if that person is you or him or neither, I don't know).
I see now, thank you so much for answering all my dump questions : ] It is much more clear in my mind now
1. What is quantum entanglement and why is it considered evil?
Quantum entanglement is a phenomenon in which two particles become inextricably linked, so that changes in one particle affect the other instantaneously, regardless of the distance between them. It is considered "evil" because it challenges our understanding of classical physics and can lead to strange and seemingly impossible outcomes.
2. How does quantum entanglement work?
When two particles are entangled, they share a quantum state, meaning their properties are intertwined. This means that any changes to one particle will also affect the other, even if they are separated by large distances. The exact mechanism behind this phenomenon is still not fully understood.
3. Can quantum entanglement be used for communication?
No, quantum entanglement cannot be used for communication. While it may seem like changes in one particle could be used to send information to the other, this is not possible due to the randomness and unpredictability of quantum states.
4. What are the potential applications of quantum entanglement?
Quantum entanglement has potential applications in quantum computing, cryptography, and teleportation. It also allows for the study of fundamental physics and could lead to new discoveries in the field.
5. Is quantum entanglement dangerous?
No, quantum entanglement is not dangerous. While it may challenge our understanding of the universe, it does not pose any immediate threat. In fact, it has the potential to greatly advance technology and our understanding of the world around us.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
