Minimization and least squares/ridge regression
In summary, minimization and least squares/ridge regression are used to find the best fitting line or curve for a given set of data points by minimizing the sum of squared errors. The difference between least squares and ridge regression is that ridge regression also includes a penalty term to reduce the effects of multicollinearity. The optimal value for the penalty term is determined through cross-validation. The main assumptions of least squares/ridge regression are linearity, normality, and equal variance of errors. Ridge regression can also be used for feature selection by penalizing unimportant variables, but it may not perform well with a large number of predictors with small effects.
monkaez
f(x;a) = x_o + (a_1,a_2,a_3,...a_d)*x
min a (Xa - Y)^t o^(-1) (Xa - Y)
a = (a_0 a_1 a_2 a_3 a_4 . . . a_d)^t
Y = (y_1 y_2 y_ 3 ... y_k)
X = Dsign Matrix
to minimize write
(X(a+ (delta a) - Y )^t o^(-1) (X (a+ delta a) - Y)
= (Xa - Y)^t o^(-1) (Xa - Y) + (delta a)^t X^t o^(-1) (Xa - Y) + (Xa -Y)^t o^(-1) X (delta a) + O((delta a)^t * (delta a))
= (Xa - Y)^t o^(-1) (Xa - Y) + 2*(delta a)^t X^t o^(-1) (Xa - Y) + + O((delta a)^t * (delta a))
a = (X^t o^(-1) X)^(-1) X^t o^(-1) YThis is directly out of my professors notes and I have no clue how this proves that the resulting product is always the minimum this way?
The above solution a is just the solution for standard least squares problem if o = o^2 * I
a = (X^t X)^(-1)*X^t*Y
I guess my main issue is understanding how the minimization process works and how he drops the terms in the O notation. Any input is greatly appreciated. (I tried using latex but the code doesn't manifest for me and I need to read more about it.)
To understand why this solution is the minimum, we need to look at the properties of the least squares problem. The goal of the least squares problem is to find the values of the parameters (a) that minimize the sum of the squared errors between the predicted values (Xa) and the actual values (Y). In other words, we want to find the values of a that make the predicted values as close to the actual values as possible.
In the attempt at a solution, we see that the error term (Xa - Y) is multiplied by the inverse of the covariance matrix (o^(-1)) on both sides. This term is known as the weighted error, and it is used to give more weight to the errors that have smaller variances. This is important because it ensures that the parameters are not overly influenced by outliers or errors with large variances.
Next, we see that the error term is squared and summed, which is the same as taking the squared error between the predicted values and the actual values. This is the objective function that we want to minimize.
Now, let's look at the terms in the O notation. The O notation represents higher order terms that are negligible compared to the terms that are being kept. In other words, as the values of delta a get smaller, the O notation terms become less and less important and can be ignored. This is a common practice in mathematical proofs, as it simplifies the calculations and makes it easier to see the main steps.
Finally, we see that the solution for a is given by (X^t o^(-1) X)^(-1) X^t o^(-1) Y. This is known as the normal equation, and it is derived from setting the derivative of the objective function to 0. This solution is the minimum because it satisfies the necessary condition for a minimum, which is that the derivative of the objective function is equal to 0.
In summary, the solution for a is the minimum because it minimizes the sum of the squared errors, takes into account the variances of the errors, and satisfies the necessary condition for a minimum.
1. What is the purpose of minimization and least squares/ridge regression?
The purpose of minimization and least squares/ridge regression is to find the best fitting line or curve for a given set of data points. This is done by minimizing the sum of squared errors between the predicted values and the actual values.
2. What is the difference between least squares and ridge regression?
Least squares regression aims to minimize the sum of squared errors, while ridge regression also includes a penalty term to reduce the effects of multicollinearity in the data. This means that ridge regression often provides more stable and accurate predictions for highly correlated variables.
3. How is the optimal value for the penalty term determined in ridge regression?
The optimal value for the penalty term in ridge regression is usually determined through a process called cross-validation. This involves splitting the data into training and testing sets and trying different values for the penalty term until the best fit is achieved.
4. What are the assumptions of least squares/ridge regression?
The main assumptions of least squares/ridge regression are that the relationship between the independent and dependent variables is linear, the errors are normally distributed, and the errors have equal variance. These assumptions should be checked before using these techniques and if they are violated, alternative methods may be more appropriate.
5. Can ridge regression be used for feature selection?
Yes, ridge regression can be used for feature selection by penalizing the coefficients of variables that do not contribute much to the prediction. This can help to reduce overfitting and improve the overall performance of the model. However, it is important to note that ridge regression does not perform well when there are a large number of predictors with small effects.
