Linear operators & mappings between vector spaces
In summary: The convention you're asking about ensures that ##[T]_{ij}=T_{ij}##.The left hand side T(v_j) has a j in it. If you summed over j on the right hand side you wouldn't have any j remaining on the right hand side. So the equation would make a claim that T(v_j) is a sum involving subscripts that are constant except for the index i . How would we interpret that?In summary, the traditional way to write a linear transformation is to think of a matrix as being left multiplied by a vector. The convention ensures that the sum of the components
"Don't panic!"
601
Hi,
I'm having a bit of difficulty with the following definition of a linear mapping between two vector spaces:
Suppose we have two [itex]n[/itex]-dimensional vector spaces [itex]V[/itex] and [itex]W[/itex] and a set of linearly independent vectors [itex]\mathcal{S} = \lbrace \mathbf{v}_{i}\rbrace_{i=1, \ldots , n}[/itex] which forms a basis for [itex]V[/itex]. We define the linear operator [itex]T[/itex] which maps the basis vectors [itex]\mathbf{v}_{j}[/itex] to their representations in [itex] W[/itex], i.e. [itex]T:V \rightarrow W[/itex], as [tex] T\left(\mathbf{v}_{j}\right)= \sum_{i=1}^{n} T_{ij}\mathbf{w}_{i} [/tex] where [itex]\mathcal{B}= \lbrace\mathbf{w}_{i} \rbrace_{i=1, \ldots , n}[/itex] is a basis for [itex]W[/itex].
What I'm struggling with is, why is the transformation expressed as [itex]\sum_{i=1}^{n} T_{ij}\mathbf{w}_{i}[/itex] and not [itex]\sum_{j=1}^{n} T_{ij}\mathbf{w}_{j}[/itex] ? Is it purely definition, or is there some deeper meaning behind it? (and if so, is there any way of deriving this expression?).
Sorry to ask a probably very trivial question, but it's been bugging me, and I can't seem to find a satisfactory answer from trawling the internet.
The left hand side [itex] T(v_j) [/itex] has a [itex] j [/itex] in it. If you summed over [itex] j [/itex] on the right hand side you wouldn't have any [itex] j [/itex] remaining on the right hand side. So the equation would make a claim that [itex] T(v_j) [/itex] is a sum involving subscripts that are constant except for the index [itex] i [/itex]. How would we interpret that?
Mathematics is traditionally written in a sloppy way from the viewpoint of logic. An equation with a with unknowns like [itex] i [/itex] and [itex] j [/itex] is used with the preceeding quantifiers "for each [itex] i [/itex] and for each [itex] j [/itex]" omitted. So the statement [itex] T(v_j) = T_{i\ 1} w_1 + T_{i\ 2} w_2 + ... T_{i\ n} w_n [/itex] would be interpreted to be a condition that was true for each pair of indices [itex] i , j [/itex]. However this wouldn't make sense as definition unless terms like [itex] T_{i\ 1} w_1 [/itex] had the same value for all indices [itex] i [/itex]. We don't want that restriction in the definition of a linear transformation.
You could also ask why we don't define the transformation by [itex] T(v_j) = \sum_{i=1}^n T_{j\ i} w_i [/itex].
It's just a matter of tradition. Linear transformations are associated with matrices. The traditional way to think of this is to think of a column vector v being transformed by being left multipled by a matrix T. If you wanted to think of a transformation as a row vector v being right multiplied by a matrix T, you'd change the order of T's indexes [itex] i,j [/itex] in the definition.
That first definition ensures that ##(Tv_j)_i## (the ith component of ##Tv_j## in the ##\mathcal B## basis) is ##T_{ij}##.
Recall that when we're given a linear operator T, we define the matrix [T] corresponding to it by ##[T]_{ij}=(Tv_j)_i##. (See the FAQ post I linked to in your other thread). The reason that we use this convention rather than ##[T]_{ij}=(Tv_i)_j## is that it's nice to have the matrix equation that corresponds to y=Tx be [y]=[T][x], rather than ##[y]^T=[x]^T[T]##.
Stephen Tashi said:
The left hand side [itex] T(v_j) [/itex] has a [itex] j [/itex] in it. If you summed over [itex] j [/itex] on the right hand side you wouldn't have any [itex] j [/itex] remaining on the right hand side. So the equation would make a claim that [itex] T(v_j) [/itex] is a sum involving subscripts that are constant except for the index [itex] i [/itex]. How would we interpret that?You could also ask why we don't define the transformation by [itex] T(v_j) = \sum_{i=1}^n T_{j\ i} w_i [/itex].
Thanks. Sorry, when I wrote it with the sum over the other index, I had meant in the form that you've put above.
I guess I was just trying to make sense of it really, as usually, if one expresses a vector in terms of a column matrix, with respect to a given ordered basis, for example
[tex] \left[ \mathbf{v}\right]_{ \mathcal{B}} = \left( \begin{matrix} a_{1} \\ \vdots \\ a_{n} \end{matrix} \right) [/tex]
where [itex]\mathcal{B} [/itex] is an [itex]n[/itex]-dimensional basis for [itex]V[/itex] and [itex]\mathbf{v} \in V [/itex]. The components [itex] a_{i} [/itex] of the column matrix are the components of the vector [itex] \mathbf{v}[/itex] with respect to the basis vectors [itex] \mathbf{v}_{i} [/itex]. ( [itex] \left[\, \cdot \,\right]_{\mathcal{ B}} [/itex] defines an isomorphism between [itex] V[/itex] and [itex] \mathbb{R}^{n}[/itex] ).
Then, for some linear operator [itex]\mathcal{A}[/itex], we have that, with respect to the basis [itex]\mathcal{B}[/itex]: [tex] \left[\mathcal{ A} \left( \mathbf{v} \right) \right]_{\mathcal{ B}} = \left( \sum_{j=1}^{n} A_{ij} a_{j} \right) [/tex]
where the [itex] a_{j} [/itex] are the components of [itex] \mathbf{v} [/itex] with respect to the basis vectors [itex] \mathbf{v}_{i} \in \mathcal{B} [/itex] (the right-hand side of the equation denotes a column matrix whose components are [itex]\sum_{j=1}^{n} A_{ij} a_{j} [/itex] ).
In my mind, I rationalised it by using that one can the basis vectors as the standard basis in the basis that they define, i.e. [tex] \left[ \mathbf{v}_{i}\right]_{ \mathcal{B}} = \left( \begin{matrix} 0 \\ \vdots \\ 1 \\ \vdots \\ 0 \end{matrix} \right) [/tex]
where [itex] \mathbf{v}_{i} \in \mathcal{B} [/itex]. And in that sense, for the [itex] j^{th}[/itex] basis vector [itex] \mathbf{v}_{j} \in \mathcal{B} [/itex], the vector "picks off" the elements of the [itex] j^{th} [/itex] column of the matrix representation of [itex] \mathcal{A} [/itex] in the basis [itex] \mathcal{B} [/itex], such that [tex] \left[ \mathcal{A} \left( \mathbf{v}_{j} \right) \right]_{\mathcal{B} } = \left( \begin{matrix} A_{1j} \\ \vdots \\ A_{nj} \end{matrix} \right) = A_{1j} \left( \begin{matrix} 1 \\ 0 \\ \vdots \\ 0 \end{matrix} \right) + \cdots + A_{nj} \left( \begin{matrix} 0 \\ \vdots \\ 0 \\ 1 \end{matrix} \right) = A_{1j} \left[ \mathbf{v}_{1}\right]_{ \mathcal{B}} + \cdots + A_{nj} \left[ \mathbf{v}_{n}\right]_{ \mathcal{B}} = \left[ A_{1j} \mathbf{v}_{1} + \cdots + A_{nj} \mathbf{v}_{n} \right]_{ \mathcal{ B}} = \left[ \sum_{i=1}^{n} A_{ij} \mathbf{v}_{i} \right]_{\mathcal{B}} [/tex]
from which one could imply that [tex] \mathcal{A} \left( \mathbf{v}_{j} \right) = \sum_{i=1}^{n} A_{ij} \mathbf{v}_{i} [/tex] however, I'm not convinced that I've got this write and it didn't seem to be the most general way of doing it?!
Cheers Fredrik. My question actually arose after reading your FAQ, I was just a bit unsure. So, is the way that an operator acts on the basis vectors defined that way so that one recovers the matrix equation [itex] \left[ \mathbf{y}\right] = \left[\mathcal{T} \right] \left[\mathbf{x} \right] [/itex]. instead of [itex] \left[ \mathbf{y}\right]^{T} = \left[\mathbf{x} \right]^{T} \left[\mathcal{T} \right] [/itex]?
Also, is it correct to deduce it the way I did in the above post?
Your calculation looks OK, but there are some inaccuracies. I see nothing in the calculation that indicates a misunderstanding, but the formula above is weird, because it says that a matrix is equal to a number. The right-hand side is the ith component of the left-hand side.
It's also a little confusing to use the same letter of the alphabet (v) for the basis vectors and the arbitrary vector. I will write ##\mathbf x=\sum x_i\mathbf v_i## instead.
If you want to prove that ##A\mathbf v_j=\sum_{i=1}^n A_{ij}\mathbf v_i##, where ##A_{ij}## is the row i, column j component of the matrix representation of A, you really only have to realize the left-hand side is a vector, and can therefore be expressed as a linear combination of the basis vectors: ##A\mathbf v_j = \sum_{i=1}^n (A\mathbf v_j)_i \mathbf v_i##. Then you recall that ##A_{ij}## is defined by ##A_{ij}=(A\mathbf v_j)_i##.
Then you can use this result to evaluate ##A\mathbf x##, where ##\mathbf x## is an arbitrary vector.
$$A\mathbf x =A\bigg(\sum_j x_j \mathbf v_j\bigg) =\sum_j x_j A\mathbf v_j =\sum_j x_j\bigg(\sum_i A_{ij}\mathbf v_i\bigg) =\sum_i\bigg(\sum_j A_{ij}x_j\bigg)\mathbf v_i.$$ This implies that the ith component of ##A\mathbf x## is
$$(A\mathbf x)_i =\sum_j A_{ij} x_j.$$
Cheers Fredrik, that's most helpful!
Yes, the formula [itex] \mathcal{A} \left[ \left(\mathbf{v} \right) \right]_{\mathcal{B}} = \left(\sum_{j=1}^{n} A_{ij} a_{j}\right) [/itex] was just laziness on my part - I didn't want to write out all the components of the column vector, so I implied it, all be it a bit ambiguously, through the parentheses around the sum. Apologies for the confusion though, and thank you very much for your help once again.
Either way works. They are just picking one way. The notation is simpler.
The question features basis vectors, whereas a routine operation is calculation of components; one rarely refers to the basis directly. For components we have, in standard notation, an intuitive order of indices (Tv)k = Tkv, where k is the index of a row and enumerates both columns of the matrix Tk and components v.
Original poster wants to see how images of basis vectors of the first space are expressed from basis vectors of the second space. Yes, there is a reversion, because bases are a concept dual to components, namely (ei)k = δki.
1. What is a linear operator?
A linear operator is a function that maps a vector space to itself, while preserving the vector space structure. This means that the operation of scalar multiplication and vector addition are preserved under the linear operator.
2. How is a linear operator different from a linear mapping?
A linear operator is a special case of a linear mapping, where the vector spaces being mapped are the same. A linear mapping can map between different vector spaces, while a linear operator only maps within the same vector space.
3. What is the difference between a linear operator and a matrix?
A linear operator and a matrix are similar in that they both represent a certain transformation of a vector space. However, a matrix is a concrete representation of a linear operator, while a linear operator is a more abstract concept that does not require a specific representation.
4. Can a linear operator have an inverse?
Yes, a linear operator can have an inverse if it is bijective, meaning it is both injective (one-to-one) and surjective (onto). In this case, the inverse linear operator will also be bijective.
5. How are linear operators used in real-world applications?
Linear operators are used in many areas of science and engineering, such as physics, economics, and computer graphics. They are essential in solving systems of linear equations and modeling linear systems, making them useful in fields where linearity is a fundamental concept.
  • Linear and Abstract Algebra
