Defining Anhydrides: What Is the Most Accurate Definition?
  • Thread starter JeffEvarts
  • Tags
    Definition
In summary: Personally I just avoid the term whenever I can, it's not a huge deal but it's one less thing to worry about.
JeffEvarts
74
A question about an anhydride that has nothing to to with acetic acid! How novel!
I am not entirely sure I understand what an anhydride is.
I found a reference to disulfuric acid, H2S2O7, and thought "Ah! Sulfuric Anhydride", but when I went to my other references, specifically the oxoacid entry on wikipedia, they listed SO3 as the anhydride.
I get it to one of three possibilities:
1) The anhydride is what you get when you take water out of the acid (SO3)
2) The anhydride is what you get when you link two acid residues via an oxygen (H2S2O7)
3) The anhydride of something without a C-O-H group (such as H2SO4) does not exist, so the question is moot
What sayeth the authorities?
-Jeff Evarts
Chemistry news on Phys.org
Anything that can be obtained by removing a (chemically bond) molecule of water can be called anhydrite.
Another example is gypsum that when heated transforms to "anhydride":
CaSO4·2H2O + heat → CaSO4·½H2O + 1½H2O (steam)
http://en.wikipedia.org/wiki/Calcium_sulfate
I am not sure if any formal definition exists. Unfortunately, IUPAC goldbook site at the moment is not working, so I can't check to be sure.
I would say acid anhydride is a substance that will produce acid on the reaction with water - so SO3 classifies, while disulfuric acid doesn't.
I too am not sure there is an a confining formal definition but I think your definition (a) is as good a definition as any. And better than some other nomenclature used for such things. I mean H2S2O7 is called persulphuric but the equivalent with phosphoric acid is called pyrophosphoric acid. You can call the molecules of an acid with various numbers of H2O removed anhydrides, and except for the one with water completely removed you can all them all oxyacids or poly oxyacids. (I worried about this a bit I remember at school, and noticed there were a number of these pairs coming up which I tried to learn and fix in mind, then I had the inspiration you didn't need to stop at two and proudly announced you must have an infinite number of oxyacids of any element! This was at first ridiculed and then congratulated.http://www.puma-project.eu/yacs/smileys/images/medal_full.gif)
Anyway I just googled "phosphoanhydride" and exactly the right kind of molecules tumble out. In the lab you use acetic anhydride for acetylatinng, in your cells you use phosphoanhydride (mainly triphosphates) for phosphorylating, or pyrophosphphorylating or for adenylylating etc. - no molecules are more important!
Three authorities, 2.5 answers. :)
Perhaps I shall just avoid the term when I can. That sounds like the smartest path.
Thank you,
-Jeff
That's because reality doesn't care about tight definitions :wink:
I don't think there is a serious difference between what I suggested and your (a) definition - sure, there are compounds that will fit one, but won't fit the other, but in the majority of cases molecule that you get by removing water molecule from the acid will - given a chance - happily react with water to produce acid back, so both approaches are more or less equivalent.
It is also a matter of a personal preference - when there is no agreed on definition, everyone will tell you what they think when they hear the word (actually that happens even sometimes where the definition exists).
1. What is the definition of anhydride?
Anhydride refers to a compound that is formed by the removal of water molecules from a substance. It can also refer to a compound that reacts with water to form an acid or base.
2. How are anhydrides formed?
Anhydrides are typically formed through a dehydration reaction, where water molecules are removed from a substance. This can occur through heating, exposure to strong acids, or other chemical reactions.
3. What are the different types of anhydrides?
There are two main types of anhydrides: acid anhydrides and basic anhydrides. Acid anhydrides form acidic solutions when reacted with water, while basic anhydrides form basic solutions.
4. What are the properties of anhydrides?
Anhydrides are typically highly reactive and corrosive compounds. They have a high melting and boiling point, and can be soluble in water or other solvents depending on their chemical composition.
5. What are the practical uses of anhydrides?
Anhydrides have a variety of uses in industries such as pharmaceuticals, plastics, and agriculture. They can be used as catalysts, intermediates in chemical reactions, and as components in the production of resins and polymers.
  • Chemistry
12K
  • Chemistry
  • Biology and Chemistry Homework Help
