Register to reply
Speed of the moon at perigee
by ryanie
Tags: moon, perigee, speed
Share this thread:
ryanie
#1
Apr6-14, 08:57 AM
P: 9
Hi
Im trying to calculate the speed of the moon at perigee but i dont know where im going wrong.
As i know the formula is v = sqrt[ GM( (2/p) - (1/a) ) ]
where
g = gravitation constant
m = mass of the earth
p = distance perigee from the earth
a = semi major axis
The values im using are
g= 6.67384e-11
m = 5.97219e+24kg
p = 363295km
a = 384399km
the result im getting is 75.5524m/s
Im not even sure if this is correct, could someone advice me in the correct method
*EDIT, showed the unit im working in. Also as a side note i pulled the data of wikipedia*
Phys.Org News Partner Physics news on Phys.org
Physicists discuss quantum pigeonhole principle
First in-situ images of void collapse in explosives
The first supercomputer simulations of 'spin?orbit' forces between neutrons and protons in an atomic nucleus
jbriggs444
#2
Apr6-14, 09:15 AM
P: 907
Show your units. There is at least one error in this regard that would be more easily visible if you did.
Nugatory
#3
Apr6-14, 09:17 AM
Sci Advisor
Thanks
P: 3,455
What units are you using?
D H
#4
Apr6-14, 10:28 AM
Mentor
P: 15,065
Quote Quote by ryanie View Post
That's not even close.
You did not show all of the units you are working in. G has units, too, and this is the source of your problem. You are using inconsistent units.
ryanie
#5
Apr6-14, 01:06 PM
P: 9
ok so
the new values im using
G = 6.67384 10^-11 m3 kg-1
m = 5.97219*10^24 kg
p = 363295000 m
a = 384399000 m
im getting a result of 1075.7984 m/s
wrong? correct?
D H
#6
Apr6-14, 01:15 PM
Mentor
P: 15,065
That's much closer, but it's still wrong. That result would be correct if the Moon's mass was much, much less than the mass of the Earth. It isn't. The mass of the Moon is about 0.0123 times the mass of the Earth. That's small but it is not negligible.
BTW, please stop using text speech. It's "I', not "i", "I'm", not "im".
ryanie
#7
Apr6-14, 01:23 PM
P: 9
The formula I'm using does not take into account the mass of the moon, only the mass of the earth. Am I using the wrong formula?
D H
#8
Apr6-14, 01:28 PM
Mentor
P: 15,065
Yes.
ryanie
#9
Apr6-14, 01:29 PM
P: 9
What is the correct formula?
ryanie
#10
Apr6-14, 01:44 PM
P: 9
is the correct answer 1076040.527 m/s ?
jbriggs444
#11
Apr6-14, 02:09 PM
P: 907
You have proposed three answers now, varying from 75 meters per second to over one million meters per second. A tiny bit of sanity checking would show you that at least two of those answers are unreasonable.
You know that the radius of the moon's orbit is roughly 360,000 km.
You should know that the period of the moon's orbit is roughly 28 days.
That is enough for a back-of-the-envelope estimate of 360,000,000*2*pi meters in 28*24*60*60 seconds. That's roughly 1000 meters per second.
DH has given you a big hint by saying of your second answer, the one close to 1000 meters per second: "that answer would be correct..."
Register to reply
Related Discussions
Calculation of the Distance to the Moons Apogee/Perigee ? Astronomy & Astrophysics 2
Speed of Satellite at Perigee and Apogee Calculus & Beyond Homework 1
Perigee Apogee Ratio Introductory Physics Homework 12
The Ratio of Velocities at Perigee and Apogee Proof General Math 1
Apogee and perigee Astronomy & Astrophysics 2
