What does the y-int of a velocity-time graph represent?
  • Thread starter PhysicsJunkie
  • Tags
    Graph
In summary, the y-intercept of a velocity-time graph represents the initial velocity of an object and is important because it provides information about the object's motion at the beginning. It can be calculated by finding the value of velocity on the y-axis when time is equal to 0. The y-intercept can be negative, indicating an initial velocity in the opposite direction, and can be affected by changes in velocity, starting point, or direction of motion.
PhysicsJunkie
I collected data from a cart accelerating down an inclined track and made a velocity-time graph from the position-time graph.
What does the y-int of my v-t graph represent?
2. The attempt at a solution
I know that it represents the initial velocity of the motion. But what exatly does this initial velocity represent?
What more can be said about initial velocity?
This is the speed at the time you called zero.
Did you start your timing immediately after releasing the cart from rest?
The y-intercept of a velocity-time graph represents the initial velocity of an object, or the velocity at which the object starts moving.
Why is the y-int of a velocity-time graph important?
The y-intercept is important because it provides information about the motion of an object at the beginning of its movement. It can also help determine the acceleration of the object.
How is the y-int of a velocity-time graph calculated?
The y-intercept can be calculated by finding the value of velocity on the y-axis when time is equal to 0. This can be done by looking at the coordinates of the point where the graph intersects the y-axis.
Can the y-int of a velocity-time graph be negative?
Yes, the y-intercept of a velocity-time graph can be negative. This indicates that the initial velocity of the object is in the opposite direction of the positive direction on the graph.
What changes can affect the y-int of a velocity-time graph?
The y-intercept can be affected by changes in the initial velocity of the object, changes in the starting point of the object, or changes in the direction of the object's motion.
