Thompson's Jumping Ring with the ring in the centre of the solenoid
In summary, the conversation discusses the behavior of a Thompson's Jumping Ring apparatus with a horizontal solenoid and a free-moving ring on an iron core. It is explained that when the ring is in the center, there is no net force generated due to the opposing magnetic fields created by the ring and the solenoid. It is also suggested that the apparatus could be made more effective by terminating the iron core and using a magnetically inert guide for the ring to maximize the non-axial component of the magnetic flux. The conversation also raises a question about the force needed to accelerate the ring in the axial direction and the role of the radial component of the magnetic field.
catkin
218
This is a personal enquiry, not a homework question. I think I understand but would like confirmation.
In a modified Thompson's Jumping Ring apparatus, the solenoid is horizontal and the ring free to move on the iron core. If the ring is either side of the central position when the current is switched on the ring is accelerated away from the centre of the solenoid. If the current is already flowing and the ring is positioned either side of the central position then, when the current is turned off the ring is accelerated toward the centre. If the ring is in the centre when the current is switched on or off it does not move.
What is happening, in terms of induced currents and magnetic fields, when the ring is in the centre and why is no net force generated?
  • Faraday: e.m.f. = - dΦ/dt
  • Magnetic flux density in a long solenoid: B = μ0 n I
  • Magnetic flux: Φ = BA
  • Lenz' law: "An induced current is always in such a direction as to oppose the motion or change causing it"
  • Fleming's left hand rule
With the ring at the centre, when the current is switched on the flux density in the solenoid rises. The flux passes through the ring, changing the ring's flux linkage (proportional to its cross-sectional area), the changing linkage generates an e.m.f in the ring which generates a current in the ring which generates a magnetic field. By Lenz' law this opposes the change that produced it; the direction of the ring's magnetic field is opposite to the solenoid's.
There is a magnetic field (the ring's field only opposes the solenoid's, it does not cancel it out) and there is a current so there must be force. Applying Fleming's left hand rule the current flows around the ring, the magnetic flux passes axially through it. The resultant force is radial and evenly distributed around the circumference resulting in no net force to accelerate the ring.
The implication of this reasoning is that it is only the the non-axial component of the magnetic flux that causes the ring to move. The classic Thompson's Jumping Ring apparatus has an iron-cored solenoid and I understand that an iron core is so effective at containing the flux that approximately no flux escapes; it is ~all contained within the core. But it cannot be or the ring would not move! Am I getting this right?
This line of reasoning also suggests that a Thompson's Jumping Ring apparatus could be made more effective by terminating the core at the end of the solenoid, replacing its extension beyond the solenoid with a magnetically inert guide for the ring. This should produce a flared magnetic field where gravity positions the ring thus maximising the non-axial component of the magnetic flux and increasing the force on the ring. Does that make sense?
Your reasoning is generally correct however I think you need to pay careful attention to the force that would accelerate the ring in one direction or another.
Why is the resultant force radial? An axial force component is needed to accelerate the ring in the axial direction. That can only come from a radial component of the field. Think about ##\vec F=I~\vec L\times \vec B## and what component of $$\vec B## provides an axial acceleration.
1. How does the Thompson's Jumping Ring work?
The Thompson's Jumping Ring is an experiment that demonstrates the phenomenon of electromagnetic induction. The ring consists of a conducting metal, such as aluminum, with a small gap in the center. When placed inside a solenoid, which is a coil of wire, and connected to a power source, the ring experiences a changing magnetic field. This changing magnetic field creates an electric current in the ring, which in turn creates a magnetic field that interacts with the solenoid's magnetic field. This interaction causes the ring to jump or move upwards, defying gravity.
2. What is the purpose of the ring being placed in the center of the solenoid?
The solenoid's magnetic field is strongest at its center, so placing the ring in this location allows for maximum interaction between the two magnetic fields. This results in a stronger force on the ring, causing it to jump higher.
3. What are some real-world applications of the Thompson's Jumping Ring?
The Thompson's Jumping Ring experiment is primarily used as a demonstration of electromagnetic induction in physics classrooms and science museums. However, the concept of electromagnetic induction is also used in many modern technologies, such as electric generators, transformers, and induction cooktops.
4. Does the size or material of the ring affect its jumping ability?
Yes, the size and material of the ring can affect its jumping ability. A larger ring will have more surface area for the magnetic field to interact with, resulting in a stronger force and higher jump. Additionally, different materials have different electrical conductivities, which can also affect the strength of the electric current and magnetic field generated in the ring.
5. Can the Thompson's Jumping Ring experiment be done with different types of solenoids?
Yes, the experiment can be done with different types of solenoids, as long as they are capable of producing a changing magnetic field. For example, instead of a long cylindrical solenoid, a flat solenoid or a toroidal solenoid can also be used. The key is to have a strong and changing magnetic field to induce an electric current in the ring.
