Finding total charge from volume charge density
In summary, the conversation discusses the integration of volume charge density inside a solid sphere to find the total charge as a function of distance from the center. The conversation also touches on the concept of redundancy when integrating and the fact that the charge density increases with increasing distance from the center.
emr564
Why do I have to integrate? Isn't it redundant?
The volume charge density inside a solid sphere of radius a is given by ρ=ρnaught*r/a, where ρnaught is a constant. Find the total charge as a function of distance r from the center.
Q=ρV
Q=(ρnaught*r/a)*(4/3)(∏a^3)
Q=(4/3)∏ρnaught*r*a^2
but the solution manual says it's supposed to be Q=∏ρnaught*a^3
It says that you have to integrate ρ with respect to V, and that's what confuses me. If you integrate, you're taking the charge of one tiny sphere and adding it the the charge of a concentric sphere a little bigger, so on and so forth, so doesn't that mean that each time you move up to a bigger sphere, you're being redundant? Why can't you multiply the total volume by the charge per volume to get charge?
The charge density is zero at the center and gets larger with increasing r, as you wrote,
ρ=ρnaught*r/a
Thank you! I finally noticed that after way too long...
1. What is volume charge density?
Volume charge density is a measure of the amount of electric charge per unit volume of a material. It is usually denoted by the symbol ρ and is expressed in units of coulombs per cubic meter (C/m³) in the SI system.
2. How do you calculate total charge from volume charge density?
To find the total charge, we multiply the volume charge density (ρ) by the volume (V) of the material. The formula is Q = ρV. For example, if the volume charge density of a material is 5 C/m³ and its volume is 2 m³, the total charge would be 10 Coulombs (C).
3. What is the difference between volume charge density and surface charge density?
Volume charge density is a measure of charge per unit volume, while surface charge density is a measure of charge per unit area. Volume charge density is used for three-dimensional objects, while surface charge density is used for two-dimensional objects.
4. How is volume charge density related to electric field?
The electric field (E) is directly proportional to the volume charge density (ρ). This means that as the volume charge density increases, the electric field also increases. The relationship between E and ρ is given by the equation E = ρ/ε, where ε is the permittivity of the material.
5. Can volume charge density be negative?
Yes, volume charge density can be negative. This indicates that the material has a net negative charge. However, in most cases, volume charge density is positive as it represents the amount of positive charge per unit volume of a material.
11K
