Possibility to see Higgs particles at the International Linear Collider
In summary, the International Linear Collider is likely able to probe the 125 GeV region more thoroughly than the current LHC, but it's also unlikely that the ILC as originally envisioned will ever be built.
roberto85
53
I was wondering, if there was a hint or a strong signal of a Higgs particle existing around the 125 GeV region whether the possible future International Linear Collider would be able to probe that energy and produce Higgs to study? Also, if this is true, is it also true that the linear collider would be able to study such a Higgs in more detail than the LHC can?
The answer is yes and yes, but it's also unlikely that an ILC as originally envisioned will ever be built. The other rationale for the ILC, to study low energy SUSY, is in trouble given the LHC results. A cheaper, less capable machine is something that might be considered: a Higgs factory could be built using a synchrotron, for example.
Given the ILC's projected high cost (~$10B) and effort required, capability to study the Higgs boson is an absolute must if it's ever going to be built. Especially the design hinges on what the Higgs mass is, and therefore how much energy will be required. For a low-mass Higgs (e.g. 125 GeV) the original ILC at 500 GeV would be enough. They've also considered a 1 TeV design, as well as a 3 GeV CLIC. People will probably argue for higher energy anyway, enough that supersymmetry will also be within reach.
All of these machines are electron-positron colliders. Proton colliders like the LHC are really quark colliders, and the individual quarks inside the proton have a considerable spread in energy, which limits the energy resolution of your results. But if you're colliding electrons you know the energy more precisely, and that's their big advantage.
The LEP, which previously occupied the site where the LHC is now, was an electron-positron ring collider which operated at energies up to 200 GeV. Such colliders must cope with a large amount of synchrotron radiation - the main difficulty is radiation damage to the instrumentation.
Bill_K said:
...Proton colliders like the LHC are really quark colliders, and the individual quarks inside the proton have a considerable spread in energy, which limits the energy resolution of your results...
I've read somewhere that the LHC actually collides gluons rather than quarks.
(Still don't fully understand this myself even just at phenomenology level, so if anyone can provide further enlightenment, please do. Naively, I would have thought that colliding gluons means that the ones involved would carry even lower proportions of the originating protons' momenta than the valence quarks.)
:redface: Sorry, I should have said partons, which includes both gluons and quarks.
I do hope they build some sort of linear collider to investigate the higgs further. Perhaps plans will emerge and become more concrete once more data is accumulated at the LHC. Thanks for the info :)
Bill_K said:
...which limits the energy resolution of your results. But if you're colliding electrons you know the energy more precisely, and that's their big advantage.
Another advantage is that e+/e- energy can be tuned to match the Higgs resonance, which enhances cross sections considerably.
1. What is the International Linear Collider (ILC)?
The International Linear Collider is a proposed particle accelerator that would be used to study the fundamental particles and forces of the universe. It would be a linear collider, meaning that it accelerates particles in a straight line, unlike the Large Hadron Collider which is circular.
2. Why is the ILC being built?
The ILC is being built to further our understanding of the Higgs boson, also known as the "God particle." The Large Hadron Collider discovered the Higgs boson in 2012, but the ILC would allow for more precise measurements and potential new discoveries in particle physics.
3. What is the significance of finding Higgs particles at the ILC?
Finding Higgs particles at the ILC would confirm our current understanding of the Standard Model of particle physics. It would also provide further evidence for the existence of the Higgs field, which gives particles their mass.
4. How would the ILC be able to see Higgs particles?
The ILC would work by colliding high-energy electrons with high-energy positrons. When these particles collide, they produce energy that can be converted into other particles, including Higgs particles. The detectors at the ILC would then be able to measure the properties and behavior of these particles.
5. When is the ILC expected to be operational?
The ILC is still in the planning and development stages, so an exact timeline is not yet known. However, it is estimated that it could potentially be operational in the 2030s. This timeline may change depending on funding and technological advancements.
