Power Spectrum vs. Power Spectral Density Spectrum
In summary: So P = |V(t)|2. This is the power into a 1 ohm load. This is the power spectrum. The power spectral density is given by Psd(f) = G(f) * W/Hz. So if you have a 1 watt signal at 1000Hz, the power spectral density would be 1 watt/1000Hz. If you want the power at a specific frequency, you would need to find G(f) and then use the following equation to find P at that frequency: P = 2∫G(f)df.
paul_harris77
52
Does anyone know the difference between the power spectrum of a signal and the power spectral density (PSD) spectrum of a signal?
I've read on the net lots of things ranging from:
i) They are identical
ii) Power spectrum is units of Watts, power spectral density spectrum units of Watts/Hz, so not identical (conflicts with i))
iii) PSD spectrum is the magnitude spectrum of a signal squared
iv) Power spectrum is magnitude spectrum of a signal squared (conflicts with iii))
v) Power spectrum is for periodic time signals (which are discrete in frequency domain) and PSD spectrum is for non-periodic time signals (which are continuous in frequency domain)
Which of these is correct, and what are the fundatmental differences between the power spectrum and the PSD spectrum?
Thanks!
Paul
For signals of continuous frequency content like white noise, it's Watts/Hz. But that term is also used in other disciplines. E.g. in vibration analysis the units are g2/Hz.
For signals with spot frequency content only, the units are simply Watts.
Thanks for the reply. Ok, that's fine, but now I have a question about obtaining the PSD of a signal that is continuous in the frequency domain. I have read it is simply the square of the magnitude of the spectrum.
If we assume that the spectrum was obtained with the Fourier Transform, surely the units of the spectrum are Volt seconds ([itex]Vs[/itex]) since we integrate the voltage signal across time. Now if this is squared we get [itex]V^2s^2[/itex]. If we assume a 1ohm load, then we can take out [itex]V^2[/itex] as the power into that load (J/s). Hence we get the units J/s * s^2 = Js. Joule seconds are equivalent to Joules per Hz, so it looks like the square of the magnitude of the spectrum is in fact an energy density spectrum (ESD), not a power density spectrum (PSD)? Surely they are not equivalent, in which case why do lots of websites say the magnitude squared is the PSD instead of the ESD?
Thanks!
Paul
OK this is how the game is played.
Take a time-continuous signal y(t). It has no Fourier transform since it doesn't meet the Dirichlet conditions (finite energy, for one). So you cut off all time except -T < t < T. Call this new function x(t). It does have a Fourier transform = X(f). The energy in this signal is ∫x(t)2dt = ∫X|(f)|2df, both integrated over -∞ to ∞ (Parseval theorem).
So the power P = averaged energy = lim T→∞ of (1/2T)∫|X(f)|2df integrated from -∞ to ∞.
Define the power spectrum as G(f) = lim T→∞ of (1/2T)|X(f)|2. The power between two frequencies is now given as P = 2∫G(f)df integrated from f1 to f2. (The reason for the "2" is based on neglecting negative frequencies in the above derivation. I hate negative frequencies! :mad:)
In sum, G(f) is the power spectrum and the power spectral density. Don't be waylaid by the terminology, concentrate on the math.
In your case, x(t) = V(t) and as you state a 1 ohm resistor is assumed.
The power spectrum and power spectral density (PSD) spectrum are two different ways of analyzing the frequency components of a signal. While they may seem similar, there are some fundamental differences between the two.
The power spectrum is a measure of the power or energy contained in different frequency components of a signal. It is calculated by taking the Fourier transform of the signal and squaring the magnitude of each frequency component. The result is a plot of the power at each frequency, typically displayed as a graph with frequency on the x-axis and power on the y-axis. The units of the power spectrum are generally in Watts or some other unit of energy.
On the other hand, the PSD spectrum is a measure of the power density of a signal at different frequencies. It is calculated by dividing the power spectrum by the frequency interval, resulting in a measure of power per unit frequency. This allows for a more accurate comparison of the power at different frequencies, since the frequency intervals may vary. The units of the PSD spectrum are typically in Watts/Hz or some other unit of power per unit frequency.
In summary, the power spectrum and PSD spectrum both provide information about the frequency components of a signal, but they differ in their units and the way they are calculated. The power spectrum is a measure of power at each frequency, while the PSD spectrum is a measure of power per unit frequency. The choice of which to use depends on the specific application and the type of signal being analyzed.
What is the difference between power spectrum and power spectral density spectrum?
The power spectrum is a mathematical representation of the power contained in a signal at different frequencies. It is typically calculated by taking the squared magnitude of the Fourier transform of the signal. On the other hand, the power spectral density spectrum is a normalized version of the power spectrum, which takes into account the bandwidth of the frequencies being analyzed. It is calculated by dividing the power spectrum by the frequency resolution.
Which one is more commonly used in signal processing?
The power spectral density spectrum is more commonly used in signal processing, as it provides a more accurate representation of the power at different frequencies. It takes into account the bandwidth of the frequencies being analyzed, whereas the power spectrum does not.
What is the unit of measurement for both power spectrum and power spectral density spectrum?
The unit of measurement for both power spectrum and power spectral density spectrum is power per frequency. The specific unit used will depend on the type of signal being analyzed and the units of the input signal.
How do power spectrum and power spectral density spectrum relate to each other?
The power spectral density spectrum is derived from the power spectrum, so they are closely related. The power spectral density spectrum is the normalized version of the power spectrum, taking into account the bandwidth of the frequencies being analyzed. In some cases, the power spectrum may be more useful for comparing the overall power between different signals, while the power spectral density spectrum may be more useful for analyzing the power at specific frequencies.
Can power spectrum and power spectral density spectrum be used interchangeably?
No, power spectrum and power spectral density spectrum should not be used interchangeably. While they are related, they represent different aspects of a signal's power at different frequencies. The power spectral density spectrum provides a more accurate representation of the power at different frequencies, while the power spectrum does not take into account the bandwidth of the frequencies being analyzed.
  • Electrical Engineering
  • Mechanical Engineering
  • General Engineering
